Home » Modeling » EMF » Feature Map Changes -> NPE
Feature Map Changes -> NPE [message #419779] Fri, 06 June 2008 17:41 Go to next message
Ed et. al.,
I have an NPE issue that hs shown up under 2.4.0.v200805270202 (RC2
Bundle) but doesn't occur under 2.4.0.v200805052017 and earlier. I'm
guessing this is related to something that I've implemented incorrectly
and is finally biting me. In brief, I have an implementation of the
delgated item provider in the book, where directly contained memebers
are grouped together under a tranisient item provider.
Before laying a bug out there, I thought I'd check and see if this
might be the likely case where I've implemnted something incorrectly or
am using a seprecated approach. The error is:
at
org.eclipse.emf.ecore.util.FeatureMapUtil.isFeatureMap(Featu reMapUtil.java:150)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getCreateC hildDescription(ItemProviderAdapter.java:1690)
at
org.eclipse.emf.edit.command.CreateChildCommand.getDescripti on(CreateChildCommand.java:326)
at
org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction. configureAction(StaticSelectionCommandAction.java:194)
at
org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:53)
at
org.eclipse.emf.edit.ui.action.CreateChildAction.<init>(CreateChildAction.java:63)
at
org.metaabm.ide.MetaABMEditorActionBarContributor.generateCr eateChildActions(MetaABMEditorActionBarContributor.java:420)
at
org.metaabm.ide.MetaABMEditorActionBarContributor.selectionC hanged(MetaABMEditorActionBarContributor.java:371)
at
org.metaabm.ide.MetaABMEditor.setSelection(MetaABMEditor.jav a:1736)
at org.metaabm.ide.MetaABMEditor$8.selectionChanged(MetaABMEdit or.java:856)
The most relevant change I've been able to find is:
685
1686
1687
     Object sibling = selectionObject;
1688
     Object siblingFeature = getChildFeature(owner, sibling);
     EStructuralFeature siblingFeature = getChildFeature(owner, sibling);
1689
1690
     if (siblingFeature instanceof EStructuralFeature &&
FeatureMapUtil.isFeatureMap((EStructuralFeature)siblingFeatu re))
     if (FeatureMapUtil.isFeatureMap(siblingFeature))
1691
1692
       FeatureMap.Entry entry = (FeatureMap.Entry)sibling;
1693
       siblingFeature = entry.getEStructuralFeature();
Let me know if you need more info.
Re: Feature Map Changes -> NPE [message #419781 is a reply to message #419779] Fri, 06 June 2008 19:10 Go to previous messageGo to next message
Miles,
Comments below.
Miles Parker wrote:
> Ed et. al.,
> incorrectly and is finally biting me. In brief, I have an
> implementation of the delgated item provider in the book, where
> directly contained memebers are grouped together under a tranisient
> item provider.
> or am using a seprecated approach. The error is:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 685
> 1686
> 1687
> 1688
> 1689
> 1690
I suppose this acted as a null guard before; something I hadn't
considered. We should add the null guard in to do this properly.
Please open a bugzilla and I'll do that.
> 1691
> 1692
> 1693
Re: Feature Map Changes -> NPE [message #419808 is a reply to message #419781] Sat, 07 June 2008 01:41 Go to previous messageGo to next message
Done. Can you think of any Q&D work-arounds? I tried returning a new
EAttribute, but that jsut broke a little further downstream..
On 2008-06-06 16:10:05 -0700, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> Comments below.
> Miles Parker wrote:
>> Ed et. al.,
>> at
at
at
at
at
at
at
at
at
at
>> 685
>> 1686
>> 1687
>> 1688
>> 1689
>> 1690
>> 1691
>> 1692
>> 1693
Re: Feature Map Changes -> NPE [message #419810 is a reply to message #419808] Sat, 07 June 2008 07:01 Go to previous messageGo to next message
Miles,
I attached the fixed .class to the bugzilla so you could patch the
jar. Returning a new EReference should work better...
>> Miles,
>> Comments below.
>> Miles Parker wrote:
>>> Ed et. al.,
>>> I'm guessing this is related to something that I've implemented
>>> item provider.
>>> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> 685
>>> 1686
>>> 1687
>>> 1688
>>> sibling);
>>> 1689
>>> 1690
>>> 1691
>>> 1692
>>> 1693
Re: Feature Map Changes -> NPE [message #419816 is a reply to message #419810] Sat, 07 June 2008 15:05 Go to previous message
On 2008-06-07 04:01:51 -0700, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> I attached the fixed .class to the bugzilla so you could patch the jar.
Right. :) I just copied the old code into the relevant item provider..
Previous Topic:cannot open session to latest (CVS) CDO Server
Next Topic:[CDO]: simple usage scenario?
Current Time: Sat Jul 19 19:37:03 EDT 2025
Powered by FUDForum. Page generated in 0.05612 seconds
