Home » Modeling » EMF » DanglingHREFs and few other problems
DanglingHREFs and few other problems [message #419312] Sat, 17 May 2008 19:58 Go to next message
Hi all,
Initially I had faced a danglinghref exception, which got solved when the
EObjects were set with the proxy URIs.
Now the problem is not dangling exceptions, but as mentioned below.
Feature:
The work is to serialize (to xml files) data available from the database.
The data were loaded from xml files only (using ecore). Now to complete
the entire flow we need to getback the original data back from database.
Existing functionality -
The XML file loaded to the database using Ecore.
<Entity-1 id="id1">
<Entity-2 href="../CPM_KP25/CPM_KP25.xml#//ent_mt1"/>
</Entity-1>
XMl serialized through EMF by getting info from the database.
<Entity-1 id="id1" Entity-2 ="../CPM_KP25/CPM_KP25.xml#//ent_mt1"/>
I had used the ((entity-1EObject).setEntity-2()) method. The entity-2 had
the proxy URI set, along with its associated attributes. Other internal
EObjects for which the HREF s are coming properly are set on the parent
EObject using setListofEntities() method, while the problematic ones are
the the ones having the method as setEntity() type.
The difference in methods is only because according to schema, there can
be only one child for these parent eobjects but for others there can be
more than one (thats why they have setListOfEntities())
I would request you to suggest me ways of overcoming this.
Regs
Shankar
Re: DanglingHREFs and few other problems [message #419313 is a reply to message #419312] Sat, 17 May 2008 21:43 Go to previous message
--------------090709030205090700020400
Shankar,
Comments below.
Shankar wrote:
> Hi all,
> the EObjects were set with the proxy URIs.
> Feature:
> database. The data were loaded from xml files only (using ecore). Now
> to complete the entire flow we need to getback the original data back
> from database.
> <Entity-1 id="id1">
> </Entity-1>
This might well be correct. It's expect this style if the resource was
created by a factory which set the following option:
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
> had the proxy URI set, along with its associated attributes.
Generally a proxy will have no attributes set and will need to be
resolved first (as in EcoreUtil.resolve) and replaced by the resolved
result.
> Other internal EObjects for which the HREF s are coming properly are
> set on the parent EObject using setListofEntities() method, while the
> problematic ones are the the ones having the method as setEntity() type.
> can be only one child for these parent eobjects but for others there
> can be more than one (thats why they have setListOfEntities())
Trying having a look at what's happening in this block of code in
XMLSaveImpl.saveFeatures(EObject)
case OBJECT_HREF_SINGLE:
if (useEncodedAttributeStyle)
saveEObjectSingle(o, f);
continue LOOP;
else
switch (sameDocSingle(o, f))
case SAME_DOC:
saveIDRefSingle(o, f);
continue LOOP;
case CROSS_DOC:
break;
default:
continue LOOP;
break;
> Regs
> Shankar
<html>
<head>
http-equiv="Content-Type">
</head>
Shankar,<br>
<br>
Comments below.<br>
<br>
Shankar wrote:
<blockquote
cite="mid:32944df5cf34d20c796c3523dbcfd4fc$1@www.eclipse.org"
type="cite">Hi all,
<br>
<br>
<br>
<br>
<br>
Feature:
<br>
<br>
from database.
<br>
<br>
<br>
<br>
<br>
<br>
&lt;Entity-1 id="id1"&gt;
<br>
Previous Topic:What is the best approach to change existing model class names
Next Topic:custom Label from a referenced reference (EMF-Recipe does not work)?
Current Time: Sat Jul 19 16:38:24 EDT 2025
Powered by FUDForum. Page generated in 0.22788 seconds
