Home » Modeling » EMF » generate Integer type from schema attribute
generate Integer type from schema attribute [message #419182] Sun, 11 May 2008 20:18 Go to next message
From
http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf,
the only schema type that maps to Integer is xs:int with
nillable="true". This is only possible for elements since attributes
don't use the nillable property.
I am wondering if there is a way to map an optional xs:int attribute in
xsd to an Integer in the Java code where a missing attribute in a
document would correspond to null. This would seem analogous to how a
missing optional xs:string attribute corresponds to a null String object.
I have a feeling it's possible, just haven't found the right trick ;o)
-Will
Re: generate Integer type from schema attribute [message #419186 is a reply to message #419182] Sun, 11 May 2008 21:39 Go to previous messageGo to next message
Will,
You'd really have to defineda new simple type and specify its
ecore:instanceClassName to be java.lang.Integer. For primitive types,
it seems better to make use the fact that the feature unsettable and
isSetX == false can be used to detect if the feature is missing.
Will Horn wrote:
> From
> in xsd to an Integer in the Java code where a missing attribute in a
> a missing optional xs:string attribute corresponds to a null String
> object.
> -Will
Re: generate Integer type from schema attribute [message #419202 is a reply to message #419186] Mon, 12 May 2008 11:10 Go to previous messageGo to next message
Okay. It is not a big issue. There is also xs:integer which maps to
BigInteger if an object is really necessary.
However, I am curious - there is no way to use the IntObject EDataType
unless you have an element with type xs:int and xs:nillable="true"?
-Will
Ed Merks wrote:
> Will,
> Will Horn wrote:
>> From
>> object.
>> -Will
Re: generate Integer type from schema attribute [message #419206 is a reply to message #419202] Mon, 12 May 2008 12:27 Go to previous messageGo to next message
Will,
Most people don't want to use wrapper types anyway. They take a lot
more storage. The "Object" versions of the data types are provided
purely to support nillable where it's obvious that the data is supposed
to include an additional value representing nil which is different from
just the absence of a value...
> -Will
> Ed Merks wrote:
>> Will,
>> types, it seems better to make use the fact that the feature
>> unsettable and isSetX == false can be used to detect if the feature
>> is missing.
>> Will Horn wrote:
>>> From
>>> attributes don't use the nillable property.
>>> how a missing optional xs:string attribute corresponds to a null
>>> String object.
>>> -Will
Re: generate Integer type from schema attribute [message #419209 is a reply to message #419206] Mon, 12 May 2008 19:11 Go to previous messageGo to next message
Yeah, that is true. In my experience, though, for databinding purposes
it seems easier to deal with Objects and null than with isSetX. But I
am still getting the hang of databinding...
Ed Merks wrote:
> Will,
>> -Will
>> Ed Merks wrote:
>>> Will,
>>> is missing.
>>> Will Horn wrote:
>>>> From
>>>> String object.
>>>> -Will
Re: generate Integer type from schema attribute [message #419213 is a reply to message #419209] Mon, 12 May 2008 21:47 Go to previous message
Will,
Yes, the whole concept of unsettable along with isSet and unset does
tend to bend people's minds a bit... But if you need to deal with large
amounts of data, wrapper objects can be a bit of a space killer
> purposes it seems easier to deal with Objects and null than with
> isSetX. But I am still getting the hang of databinding...
> Ed Merks wrote:
>> Will,
>> supposed to include an additional value representing nil which is
>> different from just the absence of a value...
>>> to BigInteger if an object is really necessary.
>>> EDataType unless you have an element with type xs:int and
>>> xs:nillable="true"?
>>> -Will
>>> Ed Merks wrote:
>>>> Will,
>>>> is missing.
>>>> Will Horn wrote:
>>>>> From
>>>>> attribute in xsd to an Integer in the Java code where a missing
>>>>> attribute in a document would correspond to null. This would
>>>>> seem analogous to how a missing optional xs:string attribute
>>>>> ;o)
>>>>> -Will
Previous Topic:Using EMF with an existing well-defined code
Next Topic:[DataBinding] Default validation in EMFUpdateValueStrategy
Current Time: Sun Jul 20 03:45:19 EDT 2025
Powered by FUDForum. Page generated in 0.04437 seconds
