Home » Modeling » EMF » ecore.ecore
ecore.ecore [message #419060] |
Fri, 09 May 2008 13:33  |
This question may be silly, but since my XMl-knowledge seems to be very
limited, I need to pose it here. In the ecore.ecore file I find that all
the elements start with <eClassifiers ...> Even the class EClassifier
itself. Also, I see <eAnnotations ...> <eStructuralFeatures ...> etc.
My question is where do these tags from from?
I have looked at XMLNamespace.ecore file also, it has the same kind of tags.
-aru
Re: ecore.ecore [message #419062 is a reply to message #419060] |
Fri, 09 May 2008 15:38   |
Adrian,
When an instance of some type (EClass) is serialized, the element and
attribute names that are used correspond to the feature names, just as a
serialized instance of a complex type uses the element and attribute
names within the complex type. Generally you should expect type names
to appear only on xsi:type references, and for XMI serializations, as
the name of root element.
Adrian Rutle wrote:
> Hi
> very limited, I need to pose it here. In the ecore.ecore file I find
> that all the elements start with <eClassifiers ...> Even the class
> EClassifier itself. Also, I see <eAnnotations ...>
> <eStructuralFeatures ...> etc. My question is where do these tags from
> from?
> tags.
> -aru
Re: ecore.ecore [message #419145 is a reply to message #419062] |
Fri, 09 May 2008 16:21   |
Ed Merks skrev:
> Adrian,
Aha, thank you Ed,
I think know I understand...
<eClassifiers xsi:type="ecore:EClass" name="EPackage"
eSuperTypes="#//ENamedElement">
<eStructuralFeatures xsi:type="ecore:EReference"
name="eClassifiers" upperBound="-1"
eType="#//EClassifier" containment="true"
eOpposite="#//EClassifier/ePackage"/>
</eClassifiers>
One more question; inside the <eClassifiers xsi:type="ecore:EClass"
name="EClass" eSuperTypes="#//EClassifier"> element we have both
<eOperations name="isSuperTypeOf" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EBoolean">
<eParameters name="someClass" eType="#//EClass"/>
</eOperations>
and
<eStructuralFeatures xsi:type="ecore:EReference" name="eOperations"
upperBound="-1"
eType="#//EOperation" containment="true" resolveProxies="false"
eOpposite="#//EOperation/eContainingClass"/>
, the first one is used in the same way as the <eClassifiers ...> tag
is used in EPackage, am I right? Thus there is not difference betwenn
the operation isSuperTypeOf(someClass : EClass) boolean and the
operations that will be returned by eOperations. And this would be the
case for eAttributes also; there is no difference between the attributes
interface and abstract on one side and the attributes that will be
returned by calling eAttributes on an EClass. I even expect that
eAttributes would return the attributes abstract and interface.
> Adrian Rutle wrote:
>> Hi
>> from?
>> tags.
>> -aru
Re: ecore.ecore [message #419147 is a reply to message #419145] |
Fri, 09 May 2008 16:46   |
Adrian,
Comments below.
Adrian Rutle wrote:
> Ed Merks skrev:
>> Adrian,
>> as a serialized instance of a complex type uses the element and
>> attribute names within the complex type. Generally you should expect
>> type names to appear only on xsi:type references, and for XMI
>> serializations, as the name of root element.
> Aha, thank you Ed,
> </eClassifiers>
> </eOperations>
> and
> upperBound="-1"
> resolveProxies="false" eOpposite="#//EOperation/eContainingClass"/>
Yes, EClass has an eOperations feature.
> Thus there is not difference betwenn the operation
> isSuperTypeOf(someClass : EClass) boolean and the operations that will
> be returned by eOperations. And this would be the case for eAttributes
> also; there is no difference between the attributes interface and
> abstract on one side and the attributes that will be returned by
> calling eAttributes on an EClass. I even expect that eAttributes would
I almost couldn't parse any of this. Maybe you could try rephrasing the
question...
>> Adrian Rutle wrote:
>>> Hi
>>> from from?
>>> of tags.
>>> -aru
Re: ecore.ecore [message #419149 is a reply to message #419145] |
Fri, 09 May 2008 16:49   |
Adrian Rutle skrev:
> Ed Merks skrev:
>> Adrian,
>> a serialized instance of a complex type uses the element and attribute
> Aha, thank you Ed,
now
> <eStructuralFeatures xsi:type="ecore:EReference" name="eClassifiers"
> upperBound="-1"
> </eClassifiers>
> </eOperations>
> and
> upperBound="-1"
Did some testing, the getEAttributes() which returns the list
EAttributes returned only the attributes of the instance. While the call
<instance-object-name>.eClass().eClass().getEAttributes() returned
interface and abstract. So the difference is in that these two
<eStructuralFeatures xsi:type="ecore:EAttribute" name="abstract"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="interface"
are attributes of the EClass itself, but these two (and many others)
<eStructuralFeatures xsi:type="ecore:EReference" name="eAllAttributes"
upperBound="-1"
eType="#//EAttribute" changeable="false" volatile="true"
transient="true"
derived="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="eAttributes"
upperBound="-1"
transient="true"
derived="true"/>
are for instances of EClass.
Adrian
>> Adrian Rutle wrote:
>>> Hi
>>> from from?
>>> of tags.
>>> -aru
Re: ecore.ecore [message #419150 is a reply to message #419149] |
Fri, 09 May 2008 16:54   |
Adrian,
I think so. :-P
Adrian Rutle wrote:
> Adrian Rutle skrev:
>> Ed Merks skrev:
>>> Adrian,
>>> and attribute names that are used correspond to the feature names,
>>> just as a serialized instance of a complex type uses the element and
>>> expect type names to appear only on xsi:type references, and for XMI
>> Aha, thank you Ed,
> now
>> </eClassifiers>
>> </eOperations>
>> and
>> upperBound="-1"
>> tag is used in EPackage, am I right? Thus there is not difference
>> betwenn the operation isSuperTypeOf(someClass : EClass) boolean and
>> the operations that will be returned by eOperations. And this would
>> be the case for eAttributes also; there is no difference between the
>> attributes interface and abstract on one side and the attributes
>> that will be returned by calling eAttributes on an EClass. I even
>> expect that eAttributes would return the attributes abstract and
>> interface.
> call <instance-object-name>.eClass().eClass().getEAttributes()
> returned interface and abstract. So the difference is in that these two
> upperBound="-1"
> transient="true"
> derived="true"/>
> name="eAttributes" upperBound="-1"
> transient="true"
> derived="true"/>
> Adrian
>>> Adrian Rutle wrote:
>>>> Hi
>>>> find that all the elements start with <eClassifiers ...> Even the
>>>> class EClassifier itself. Also, I see <eAnnotations ...>
>>>> from from?
>>>> of tags.
>>>> -aru
Re: ecore.ecore [message #419151 is a reply to message #419150] |
Fri, 09 May 2008 17:02  |
Ed Merks skrev:
> Adrian,
> I think so. :-P
Thank you again!
;-D
> Adrian Rutle wrote:
>> Adrian Rutle skrev:
>>> Ed Merks skrev:
>>>> Adrian,
>>> Aha, thank you Ed,
>> now
>>> </eClassifiers>
>>> </eOperations>
>>> and
>>> upperBound="-1"
>>> interface.
>> upperBound="-1"
>> transient="true"
>> derived="true"/>
>> transient="true"
>> derived="true"/>
>> Adrian
>>>> Adrian Rutle wrote:
>>>>> Hi
>>>>> from from?
>>>>> of tags.
>>>>> -aru
Current Time: Sun Jul 20 10:33:32 EDT 2025
Powered by FUDForum. Page generated in 0.08770 seconds
