Home » Modeling » EMF » RCP editor behavior
RCP editor behavior [message #419010] Wed, 07 May 2008 17:24 Go to next message
Originally posted by: emf.klmusic.no
I've got a fresh emf-generated rcp editor. The only parameter I changed in
the genmodel was setting rcp to true. When I run it I can create a new
file using the wizard, but I'm not allowed to edit this file until I use
the SaveAs command on it.
1. Is this behavior normal?
2. Can I change it in the genmodel or do I have to dig into the code?
Knut
Re: RCP editor behavior [message #419011 is a reply to message #419010] Wed, 07 May 2008 17:38 Go to previous messageGo to next message
Knut,
That sounds a little odd. What version of EMF are you using?
Knut L wrote:
> changed in the genmodel was setting rcp to true. When I run it I can
> create a new file using the wizard, but I'm not allowed to edit this
> file until I use the SaveAs command on it. 1. Is this behavior normal?
> Knut
Re: RCP editor behavior [message #419019 is a reply to message #419011] Wed, 07 May 2008 19:37 Go to previous messageGo to next message
Ed,
I'm using EMF 2.3.2.v20080205 on Eclipse 3.3.2 M20080221
Knut
> Knut,
> Knut L wrote:
>> Hi,
>> Thanks,
>> Knut
Re: RCP editor behavior [message #419020 is a reply to message #419019] Wed, 07 May 2008 19:43 Go to previous messageGo to next message
Knut,
That's the latest released version. This is the first I've heard of
such a problem... It sounds like something related to the editing
domain's computation of isReadOnly...
Knut L wrote:
> Ed,
> Knut
>> Knut,
>> Knut L wrote:
>>> Hi,
>>> normal? 2. Can I change it in the genmodel or do I have to dig into
>>> the code?
>>> Thanks,
>>> Knut
Re: RCP editor behavior [message #419022 is a reply to message #419020] Wed, 07 May 2008 20:32 Go to previous messageGo to next message
Ed,
I created a minimal model in a fresh workspace, and yes, it's
reproducable. Is it just me, or is it a bug? If so it should be reported,
and I'm not sure how to do that...
Ed Merks wrote:
> Knut,
> Knut L wrote:
>> Ed,
>> Knut
>>> Knut,
>>> Knut L wrote:
>>>> Hi,
>>>> the code?
>>>> Thanks,
>>>> Knut
Re: RCP editor behavior [message #419023 is a reply to message #419022] Wed, 07 May 2008 21:16 Go to previous messageGo to next message
Knut,
The release is quite old, so I'd be kind of surprised that there'd be
such a bug only just now reported. Can you try EMF 2.4 with Eclipse
3.4? M7 is just out..
Knut L wrote:
> Ed,
> reported, and I'm not sure how to do that...
> Ed Merks wrote:
>> Knut,
>> Knut L wrote:
>>> Ed,
>>> Knut
>>>> Knut,
>>>> Knut L wrote:
>>>>> Hi,
>>>>> can create a new file using the wizard, but I'm not allowed to
>>>>> edit this file until I use the SaveAs command on it. 1. Is this
>>>>> behavior normal? 2. Can I change it in the genmodel or do I have
>>>>> Thanks,
>>>>> Knut
Re: RCP editor behavior - Solution! [message #419027 is a reply to message #419023] Thu, 08 May 2008 05:26 Go to previous message
Ed,
Problem solved (or found, depending on how you look at it...). The thing
is that I have to enter the new file name as a complete path in the wizard
(I only entered the filename).
Maybe the File label in the NewFile wizard should be changed from "File"
to "File (complete path)"?
Sorry I'm a newbie :-)
Knut
Previous Topic:Re: forcing emf to save object ref as @
Next Topic:Help to start
Current Time: Sat Jul 19 13:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.04423 seconds
