Home » Modeling » EMF » MultipageEditor and Databinding
MultipageEditor and Databinding [message #418983] Tue, 06 May 2008 16:33 Go to next message
I have customized the generated emf editor and added some form based
master-details pages. To synchronize, I use EMF databinding (and I am
quite happy with it).
Now I have the following problem:
In some pages I have tree viewers which have input of the form
" editingDomain.getResourceSet().getResources().get(0).getCont ents().get(0) ".
Then I do some changes and make the editor dirty. When I click on
"save", somehow(?) the content reference of the resource changes and my
viewer input gets kind of stale. I didn't find a good solution yet, I
tried to add a commandstack listener but it didn't get notified about
the "save" operation.
Does anybody have an idea?
Michael
Re: MultipageEditor and Databinding [message #418984 is a reply to message #418983] Tue, 06 May 2008 17:22 Go to previous messageGo to next message
Michael,
I don't expect saving to change the contents of the resource (although
in the XML with a DocumentRoot case, the prefixes in the
getXMLNSPrefixMap are updated to reflect the prefixes used in the
serialization. But you can listen to the resource itself. It is a
Notifier just like an EObject is a Notifier, so you can listen for when
the contents change...
Michael Haeberlen wrote:
> my viewer input gets kind of stale. I didn't find a good solution yet,
> I tried to add a commandstack listener but it didn't get notified
> about the "save" operation.
> Michael
Re: MultipageEditor and Databinding [message #418985 is a reply to message #418984] Wed, 07 May 2008 06:36 Go to previous messageGo to next message
Ed,
I made some progress in my investigations thanks to your hints. I
awkwardly forgot to mention that I also included two GMF diagrams in my
multipage editor. Those have a generated DiagramDocumentProvider with an
inner WorkspaceSynchronizer class which called a resource.unload().
I have to figure out how I need to customize the DiagramDocumentProvider.
Thanks again for responding!
Ed Merks wrote:
> Michael,
>> Hi,
>> Thanks,
>> Michael
Re: MultipageEditor and Databinding [message #418986 is a reply to message #418985] Wed, 07 May 2008 06:45 Go to previous messageGo to next message
Michael,
It sounds like the code might be taking an inappropriate action as a
result of a resource delta. In the generated EMF editor you'll see that
as the resource deltas are processed, it's important to know which
deltas are expected as a result of resources the editor itself has just
saved, i.e, savedResources is populated to influence a subsequent delta
processing is handled...
> Ed,
> my multipage editor. Those have a generated DiagramDocumentProvider
> with an inner WorkspaceSynchronizer class which called a
> resource.unload().
> Ed Merks wrote:
>> Michael,
>> (although in the XML with a DocumentRoot case, the prefixes in the
>> when the contents change...
>>> Hi,
>>> am quite happy with it).
>>> yet, I tried to add a commandstack listener but it didn't get
>>> notified about the "save" operation.
>>> Thanks,
>>> Michael
Re: MultipageEditor and Databinding [message #418988 is a reply to message #418986] Wed, 07 May 2008 08:41 Go to previous message
Ed,
yes, the problem really is how I integrated the GMF generated diagrams.
I followed the eclipse corner article (about integrating EMF and GMF
editors) which has the same kind of problem. The GMF generated part
needs some more modification, obviously.
Ed Merks wrote:
> Michael,
>> Ed,
>> resource.unload().
>> Ed Merks wrote:
>>> Michael,
>>>> Hi,
>>>> Thanks,
>>>> Michael
Previous Topic:How to hide attribute in property view
Next Topic:Synchronization problems between model resources
Current Time: Sun Jul 20 06:13:08 EDT 2025
Powered by FUDForum. Page generated in 0.07067 seconds
