Home » Modeling » EMF » Re-setting a property depending on another property
Re-setting a property depending on another property [message #418971] |
Tue, 06 May 2008 09:14  |
Originally posted by: marsha.rohrer.swisscom.com
In my editor property x only is editable if property y is set to true. To
achieve this I implemented an XXXItemProviderDescriptor which checks the
value of property y in the canSetProperty() method.
Like this if property y is true I can add a text to property x. Now if
property y is set to false again I would like to reset the value of x to
"". But I don't know how to notify x about that fact. Do I have to do it
in the notifyChanged() method of the corresponding XXXItemProvider? And if
yes how exactly?
Thank you for your help,
Greets
Marsha
Re: Re-setting a property depending on another property [message #419225 is a reply to message #419222] |
Tue, 13 May 2008 11:16   |
Hi Ed,
Thank you this works fine. But now I have another problem. The changes
aren't visualized in the properties sheet. I think the command does not go
through the whole stack. Can you see where is my mistake?
public void setPropertyValue(Object object, Object value) {
EditingDomain editingDomain = getEditingDomain(object);
if(value instanceof MaxInstances){
MaxInstances maxInst = (MaxInstances) value;
if(maxInst.getLiteral().equals("one")){
CompoundCommand cCmd = new CompoundCommand();
cCmd.append(SetCommand.create(editingDomain, getCommandOwner(object),
feature, value));
GamePackage.eINSTANCE.STEP__INSTANTIATION_CONDITION,
SetCommand.UNSET_VALUE));
editingDomain.getCommandStack().execute(cCmd);
}else super.setPropertyValue(object, value);
Marsha
Re: Re-setting a property depending on another property [message #419226 is a reply to message #419225] |
Tue, 13 May 2008 12:36   |
--------------030105060406000708000404
Marsha,
Comments below.
Marsha wrote:
> Hi Ed,
> not go through the whole stack. Can you see where is my mistake?
> @Override
> getCommandOwner(object), feature, value));
Have you stepped through the code to see if the command is actually
executable and being executed? Normally the properties view would be
updated because the code in the editor that listens to the command stack
executing a command will explicitly tell the properties view to refresh
itself.
// Add a listener to set the most recent command's affected objects
to be the selection of the viewer with focus.
commandStack.addCommandStackListener
(new CommandStackListener()
public void commandStackChanged(final EventObject event)
getContainer().getDisplay().asyncExec
(new Runnable()
public void run()
firePropertyChange(IEditorPart.PROP_DIRTY);
// Try to select the affected objects.
Command mostRecentCommand =
((CommandStack)event.getSource()).getMostRecentCommand();
if (mostRecentCommand != null)
setSelectionToViewer(mostRecentCommand.getAffectedObjects()) ;
if (propertySheetPage != null &&
!propertySheetPage.getControl().isDisposed())
propertySheetPage.refresh();
> Marsha
<html>
<head>
http-equiv="Content-Type">
</head>
Marsha,<br>
<br>
Comments below.<br>
<br>
Marsha wrote:
<blockquote
cite="mid:44075b2d52fa5c6eb6f54decfbedbe1f$1@www.eclipse.org"
type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
Re: Re-setting a property depending on another property [message #419234 is a reply to message #419226] |
Wed, 14 May 2008 03:58   |
Hi Ed,
Your help is very useful to me, but since I'm not that experienced with
Commands I still have some problems, sorry for that.
I debuged my code and I found out that my CompoundCommand is executed as
expected (update property sheet write changes into model) if I comment out
the reset of the InstantiationCondition:
GamePackage.STEP__INSTANTIATION_CONDITION, SetCommand.UNSET_VALUE));
Nevertheless if I check the isExecutable flag of my CompoundCommand it is
set to false.
As soon as I uncomment the line above the CompoundCommand isn't executed
correctly (property sheet and model not updated). What I found out is that
the feature in the SetCommand is null, where I want to reset the
Step_InstantiationCondition (line above). The isExecutable flag of the
cCmd still is false as before.
I tried to initialize the CompoundComand in those three ways, which had no
effect on the execution:
CompoundCommand(CompoundCommand.LAST_COMMAND_ALL);
CompoundCommand(CompoundCommand.MERGE_COMMAND_ALL);
What I tried to change as well is using
GamePackage.STEP__INSTANTIATION_CONDITION instead of
GamePackage.eINSTANCE.STEP__INSTANTIATION_CONDITION since I get a warning
saying that I should not access in a static manner.
Unfortunately now I already ran out of ideas...do you have an idea where
my problem is? Do I need a function to get the feature? Why is the
isExecutable flag of my CompoundComand false?
> itself.
Since my CompoundCommand does not update the model either I think that the
problem is in the command itself.
Thanks a lot,
Marsha
Re: Re-setting a property depending on another property [message #419240 is a reply to message #419234] |
Wed, 14 May 2008 10:10   |
--------------010407000600020607050204
Marsha,
Comments below.
Marsha wrote:
> Hi Ed,
> with Commands I still have some problems, sorry for that.
> as expected (update property sheet write changes into model) if I
> comment out the reset of the InstantiationCondition:
> is set to false.
> executed correctly (property sheet and model not updated). What I
> found out is that the feature in the SetCommand is null, where I want
> to reset the Step_InstantiationCondition (line above). The
> isExecutable flag of the cCmd still is false as before.
> had no effect on the execution:
> warning saying that I should not access in a static manner.
Oh dear. You're accessing the numeric feature ID not the actual feature
object. You need to use
GamePackage.*Literals*.STEP__INSTANTIATION_CONDITION which will be the
same object as GamePackage.eINSTANCE.getStep__InstantiationCondition()...
> where my problem is? Do I need a function to get the feature? Why is
> the isExecutable flag of my CompoundComand false?
>> Normally the properties view would be updated because the code in the
>> editor that listens to the command stack executing a command will
>> explicitly tell the properties view to refresh itself.
> the problem is in the command itself.
Yes.
> Thanks a lot,
> Marsha
<html>
<head>
</head>
Marsha,<br>
<br>
<br>
Comments below.<br>
<br>
Marsha wrote:
<blockquote
cite="mid:d063a560c6b531a8b8721c474766a68f$1@www.eclipse.org"
type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<blockquote type="cite">Have you stepped through the code to see if
the command is actually executable and being executed?
Current Time: Sat Jul 19 15:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
