Home » Modeling » EMF » Sharing EMF instances across an application?
Sharing EMF instances across an application? [message #418678] Wed, 23 April 2008 15:49 Go to next message
I'm developing an RCP application with EMF, and I'm at a crossroads where
I could really use some design advice from an Eclipse/EMF perspective.
I have several views and editors which need to share model instances and
receive change notification. I think I understand how to do this with
adapters, but I still need to ensure that all the listeners (the views and
editors) add their adapter to the same EObject instance.
My views and editors currently load and save models independently of one
another, which obviously needs to change. Many EObjects are stored in
separate file resources, and contain cross-file references to each other.
I was considering creating a singleton "model store" object that fetches
and stores EObject instances in a hashmap keyed by resource path, to
ensure everyone registers with the same object... but I feel like I'm
about to rediscover a wheel that's (hopefully) already been invented.
How do other Eclipse/EMF/RCP applications handle this from a design
perspective? Is there something already available in EMF or related
technologies that provides this kind of "shared EMF instance" container?
Much thanks in advance,
Casey Marshall
AMD
Re: Sharing EMF instances across an application? [message #418680 is a reply to message #418678] Wed, 23 April 2008 16:02 Go to previous messageGo to next message
Casey,
Comments below.
Casey Marshall wrote:
> where I could really use some design advice from an Eclipse/EMF
> perspective.
Isn't it great that it's free!
> and receive change notification. I think I understand how to do this
> with adapters, but I still need to ensure that all the listeners (the
> views and editors) add their adapter to the same EObject instance.
Sharing objects across editors implies having a single editing domain
and coordinating undo and redo across editors. There was a long thread
about this last week...
> one another, which obviously needs to change. Many EObjects are
> stored in separate file resources, and contain cross-file references
> to each other.
> fetches and stores EObject instances in a hashmap keyed by resource
> path, to ensure everyone registers with the same object... but I feel
> like I'm about to rediscover a wheel that's (hopefully) already been
> invented.
I think the best approach would be to try to use this idea to share an
editing domain since from there the rest will just happen for free...
Check out "shared model in multiple editors" from 4/14/2008 7:15 PM.
> Casey Marshall
> AMD
Re: Sharing EMF instances across an application? [message #418726 is a reply to message #418680] Fri, 25 April 2008 08:07 Go to previous messageGo to next message
I have pb with refresh an editor depending on resources edited in another
editor.
Here is the structure.
I have 2 static instances of Resource representing 2 models: resource1 and
resource2.
resource2 has elements referencing resource1 elements.
I created 2 editors for each of these resources: editor1 and editor2.
So
editor1 has a EditingDomain with a ResourceSet holding resource1 and
editor2 has another EditingDomain with a ResourceSet holding resource2 and
resource1 set as read-only (using the
EditingDomain.setResourceToReadOnlyMap()) because I do not want editor2 to
modify resource1.
Ok, now I modify resource1 via editor1, the editor2 showing references on
resource1 is correctly updated and on all is fine.
Now the user closes editor1 and refuse to save resource1. I looked for a
way to revert resource1 to the previously saved data and used
resource1.unload().
My problem is that the editor2 is not notified of the changes of resource1
How can I notify that the resource as changed to all viewers ???
Thank you.
SeB.
Re: Sharing EMF instances across an application? [message #418727 is a reply to message #418726] Fri, 25 April 2008 08:26 Go to previous messageGo to next message
SeB,
Comments below.
SeB.fr wrote:
> Hello,
> another editor.
> and resource2.
I'm not sure what you mean by "static"
> So editor1 has a EditingDomain with a ResourceSet holding resource1
> and editor2 has another EditingDomain with a ResourceSet holding
> resource2 and resource1 set as read-only (using the
> editor2 to modify resource1.
> on resource1 is correctly updated and on all is fine.
Don't they each have their own copy. I guess this is the static thing
you were were getting at earlier?
> a way to revert resource1 to the previously saved data and used
> resource1.unload().
> resource1 ???
Yet three sentences up you said it responds to changes? Maybe the other
editor, when it closes without saving, needs to do the unload (assuming
the second editor is sharing the instance from the first one).
If you're sharing resources across editors, I think you'd need to be
more explicit about reverting all the changes when the editor is closed
without saving...
> Thank you.
> SeB.
Re: Sharing EMF instances across an application? [message #418743 is a reply to message #418727] Fri, 25 April 2008 12:18 Go to previous messageGo to next message
Ed, my comments below,
Ed Merks wrote:
> SeB,
> Comments below.
> SeB.fr wrote:
>> Hello,
>> another editor.
>> and resource2.
Ok I should have said singleton (sorry), as in there is only 1 instance of
resource1 and 2 during my rcp execution.
the editingDomain2 shares the instance of resource1 with editingDomain1
>> resource1.unload().
>> resource1 ???
Yes that is why I do not understand.
>Maybe the other
This is done by the editor1, when closing it does resource1.unload()
> without saving...
I do not get your sentence here ???
>> Thank you.
>> SeB.
Re: Sharing EMF instances across an application? [message #418744 is a reply to message #418743] Fri, 25 April 2008 12:41 Go to previous messageGo to next message
SeB,
Have you also tried forcing the unloaded resource to load again too?
Keep in mind that unload turns all the objects into proxies and that any
references to the old objects your editor might be holding on to need to
be update. How can you tell the second editor is still referring to the
modified version of resource1?.
> Ed Merks wrote:
>> SeB,
>> Comments below.
>> SeB.fr wrote:
>>> Hello,
>>> another editor.
>>> resource1 and resource2.
> instance of resource1 and 2 during my rcp execution.
>>> references on resource1 is correctly updated and on all is fine.
>> thing you were were getting at earlier?
>>> for a way to revert resource1 to the previously saved data and used
>>> resource1.unload().
>>> resource1 ???
>> Maybe the other editor, when it closes without saving, needs to do
>> the unload (assuming the second editor is sharing the instance from
>> the first one).
>> closed without saving...
>>> Thank you.
>>> SeB.
Re: Sharing EMF instances across an application? [message #419045 is a reply to message #418744] Thu, 08 May 2008 17:33 Go to previous messageGo to next message
Originally posted by: eclipse.gandon.name
Yes I do a load eveytime the editor1 is initialized and an unload
everytime it is disposed and still dirty (this means the user did not want
to save it).
I can tell the editor2 is still holding previously unsaved data because
there is a viewer in the editor2 showing instances of elements from model1.
If a new element was created in model1 then the tableviewer show the new
element in editor2 but when doing the unload and load again, the
tableviewer still show the newly created instance that was not saved.
Shall I write explicit code to update the editor2 that model1 as been
reloaded?
SeB.
Ed Merks wrote:
> SeB,
>> Ed Merks wrote:
>>> SeB,
>>> Comments below.
>>> SeB.fr wrote:
>>>> Hello,
>>>> another editor.
>>>> resource1.unload().
>>>> resource1 ???
>>> the first one).
>>>> Thank you.
>>>> SeB.
Re: Sharing EMF instances across an application? [message #419047 is a reply to message #419045] Thu, 08 May 2008 19:16 Go to previous messageGo to next message
SeB,
I wonder if it might be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=230908.
ekaii wrote:
> Hello,
> want to save it).
> because there is a viewer in the editor2 showing instances of elements
> from model1.
> new element in editor2 but when doing the unload and load again, the
If any views have old objects as inputs it's important that their inputs
be set again.
If you care to create a test case you can share that reproduces the
problem it would be a lot easier to understand...
> reloaded?
> SeB.
> Ed Merks wrote:
>> SeB,
>> any references to the old objects your editor might be holding on to
>> need to be update. How can you tell the second editor is still
>> referring to the modified version of resource1?.
>>> Ed Merks wrote:
>>>> SeB,
>>>> Comments below.
>>>> SeB.fr wrote:
>>>>> Hello,
>>>>> another editor.
>>>>> resource1 and editor2 has another EditingDomain with a ResourceSet
>>>>> holding resource2 and resource1 set as read-only (using the
>>>>> used resource1.unload().
>>>>> resource1 ???
>>>> the first one).
>>>> be more explicit about reverting all the changes when the editor is
>>>>> Thank you.
>>>>> SeB.
Re: Sharing EMF instances across an application? [message #419215 is a reply to message #419047] Tue, 13 May 2008 07:10 Go to previous messageGo to next message
I am not sure is related because my 2 editors work on the singleton
resources and not on the files themself.
Both editors share the same Resource instance all the time, on editor to
edit the resource and the other to be able to reference it.
Since you said unload creates proxies, I have tried to resolve all proxies
after unload and re-load using the EcoreUtil.resolveAll(Resource resource)
on the re-loaded resource but nothing changes on the table viewer in the
editor 2.
I do not know what to do?
Is there a way to be notified that a resource as been unload and loaded
again?
Is there a way to be notified that an EObject becomes a proxy or not?
Thank Ed for your effort helping out lost people such as myself.
SeB.
Ed Merks wrote:
> SeB,
> ekaii wrote:
>> Hello,
>> want to save it).
>> from model1.
> be set again.
>> reloaded?
>> SeB.
>> Ed Merks wrote:
>>> SeB,
>>>> Ed Merks wrote:
>>>>> SeB,
>>>>> Comments below.
>>>>> SeB.fr wrote:
>>>>>> Hello,
>>>>>> another editor.
>>>>>> resource1 ???
>>>>> the first one).
>>>>>> Thank you.
>>>>>> SeB.
Re: Sharing EMF instances across an application? [message #419221 is a reply to message #419215] Tue, 13 May 2008 10:27 Go to previous messageGo to next message
SeB,
Comments below.
> to edit the resource and the other to be able to reference it.
> proxies after unload and re-load using the
> EcoreUtil.resolveAll(Resource resource) on the re-loaded resource but
> nothing changes on the table viewer in the editor 2.
Do you know if the input object to the viewer is a proxy?
> loaded again?
Resources produce notification like any other Notifier, e.g.,
Resource.RESOURCE__IS_LOADED.
No, the proxy URI is not a reflective feature and doesn't produce
notification.
> SeB.
> Ed Merks wrote:
>> SeB,
>> ekaii wrote:
>>> Hello,
>>> not want to save it).
>> inputs be set again.
>>> been reloaded?
>>> SeB.
>>> Ed Merks wrote:
>>>> SeB,
>>>> too? Keep in mind that unload turns all the objects into proxies
>>>> and that any references to the old objects your editor might be
>>>> holding on to need to be update. How can you tell the second
>>>> editor is still referring to the modified version of resource1?.
>>>>> Ed Merks wrote:
>>>>>> SeB,
>>>>>> Comments below.
>>>>>> SeB.fr wrote:
>>>>>>> Hello,
>>>>>>> in another editor.
>>>>>>> editor2.
>>>>>>> ResourceSet holding resource2 and resource1 set as read-only
>>>>>>> (using the EditingDomain.setResourceToReadOnlyMap()) because I
>>>>>>> do not want editor2 to modify resource1.
>>>>> editingDomain1
>>>>>>> looked for a way to revert resource1 to the previously saved
>>>>>>> data and used resource1.unload().
>>>>>>> resource1 ???
>>>>>> do the unload (assuming the second editor is sharing the instance
>>>>>> is closed without saving...
>>>>>>> Thank you.
>>>>>>> SeB.
Re: Sharing EMF instances across an application? [message #419309 is a reply to message #419221] Sat, 17 May 2008 17:57 Go to previous messageGo to next message
Hi Ed,
The input object of my viewer is not a proxy, why would it be ?
During a debug session I have realized that doing unload and then load
again recreates the model objects, this means the viewer input instance
does not exists anymore after the unload-load.
This is surely why me viewer does not get notified anymore.
Would there be any attribute during the load that would tell the resource
not to create new items if not necessary ?
I there a way to revert to previously saved values without doing a
unload-load ?
Thanks Ed.
Ed Merks wrote:
> SeB,
> Comments below.
>> loaded again?
> notification.
>> SeB.
>> Ed Merks wrote:
>>> SeB,
>>> ekaii wrote:
>>>> Hello,
>>>> been reloaded?
>>>> SeB.
>>>> Ed Merks wrote:
>>>>> SeB,
>>>>>> Ed Merks wrote:
>>>>>>> SeB,
>>>>>>> Comments below.
>>>>>>> SeB.fr wrote:
>>>>>>>> Hello,
>>>>>>>> in another editor.
>>>>>>>> editor2.
>>>>>> editingDomain1
>>>>>>>> resource1 ???
>>>>>>>> Thank you.
>>>>>>>> SeB.
Re: Sharing EMF instances across an application? [message #419311 is a reply to message #419309] Sat, 17 May 2008 19:25 Go to previous messageGo to next message
SeB,
I'm having a hard time following this endless thread with many days of
silence. I don't really care to read the whole history again each time...
ekaii wrote:
> Hi Ed,
No, I believe I was asking if it is...
> instance does not exists anymore after the unload-load.
The input instance might well be turned into a proxy and they you'll
want to get the new replacement instance instead. EcoreUtil.resolve can
be used for that.
Yes.
> resource not to create new items if not necessary ?
No, that's just what unloading and reloading does...
> unload-load ?
Not really. A ChangeRecorder could be used to record all the changes
and roll them back, I suppose, but if you're having trouble with the
current details, I hate to think about trying to get a change recorder
to work...
> Thanks Ed.
> Ed Merks wrote:
>> SeB,
>> Comments below.
>>> editor to edit the resource and the other to be able to reference it.
>>> but nothing changes on the table viewer in the editor 2.
>>> loaded again?
>> notification.
>>> SeB.
>>> Ed Merks wrote:
>>>> SeB,
>>>> ekaii wrote:
>>>>> Hello,
>>>>> the new element in editor2 but when doing the unload and load
>>>>> again, the tableviewer still show the newly created instance that
>>>>> was not saved.
>>>>> been reloaded?
>>>>> SeB.
>>>>> Ed Merks wrote:
>>>>>> SeB,
>>>>>>> Ed Merks wrote:
>>>>>>>> SeB,
>>>>>>>> Comments below.
>>>>>>>> SeB.fr wrote:
>>>>>>>>> Hello,
>>>>>>>>> in another editor.
>>>>>>>>> editor2.
>>>>>>>> static thing you were were getting at earlier?
>>>>>>> editingDomain1
>>>>>>>>> of resource1 ???
>>>>>>> resource1.unload()
>>>>>>>> to be more explicit about reverting all the changes when the
>>>>>>>> editor is closed without saving...
>>>>>>>>> Thank you.
>>>>>>>>> SeB.
Re: Sharing EMF instances across an application? [message #419359 is a reply to message #419311] Tue, 20 May 2008 07:56 Go to previous messageGo to next message
Hi Ed and sorry for this endless post,
I did not realize that it would be hard to follow with all the other
thread you care to answer. You do a great job helping us out and I really
appreaciate it. I will now be more carefull.
A few questions though.
Is it possible to share the same Resource instance between two
EditingDomains ? It seems that the ResourceSet.add(Resource) removes the
resource from previous ResourceSet, so I do not see how to do it?
I Then thought about sharing ResourceSet betwwen editing domain but could
not find how ?
My problem is that I have an editor1 to edit model1 and editor2 to edit
model2 referencing model1.
is it possible to share resources or do I have to create new resources
that means observe that the underliyng file has changed to update model2
references?
Thanks SeB.
Ed Merks wrote:
> SeB,
> ekaii wrote:
>> Hi Ed,
> be used for that.
> Yes.
>> unload-load ?
> to work...
>> Thanks Ed.
Re: Sharing EMF instances across an application? [message #419360 is a reply to message #419359] Tue, 20 May 2008 08:24 Go to previous messageGo to next message
SeB,
Comments below.
> really appreaciate it. I will now be more carefull.
Sometimes I get a bit cranky when the thread is really long and I know
I'm starting to lose track of it...
> EditingDomains ?
It's generally a bit problematic because things like
AdapterFactoryEditingDomain.getEditingDomainFor wants to be able to
determine the editing domain for a given object and a resource shared
between editing domains can't give multiple answers for this...
> It seems that the ResourceSet.add(Resource) removes the resource from
Yes. ResourceSet.getResources and Resource.getResourceSet are like
bidirectional containment references. I.e., a resource be contained by
at most one resource set.
> could not find how ?
The same kind of problem arises for those. Once you get to this level,
it's really better to share the editing domain themselves.
> edit model2 referencing model1.
That's a common issue.
> model2 references?
You can share editing domains and the transactional frameworks can help
with that. Or you can go with the more basic generated editor where
each edit has it's own copy of the model and is updated only when the
underlying workspace version is changed.
> Thanks SeB.
> Ed Merks wrote:
>> SeB,
>> of silence. I don't really care to read the whole history again each
>> time...
>> ekaii wrote:
>>> Hi Ed,
>>> load again recreates the model objects, this means the viewer input
>> can be used for that.
>> Yes.
>>> unload-load ?
>> recorder to work...
>>> Thanks Ed.
Re: Sharing EMF instances across an application? [message #419419 is a reply to message #419360] Thu, 22 May 2008 05:15 Go to previous messageGo to next message
Hi Ed,
You mentionned sharing EditingDomain for my 2 editors problem that is an
editor1 to edit model1 and editor2 to edit model2 referencing model1.
But if you do so, that means sharing the same Command Stack and therefor
the same dirty state (usually based on the command Stack state) that means
you modify model1 and then you see editor2 as dirty.
What is the point? I'd rather merge both model into one. Or do you forsee
a way around?
Do you think transactional would solve this problem ? I had a look at the
doc and I am not sure this would solve my problem.
Another point is if my problem is a common issue, why not modfy the
framework to accomodate this issue.
What do you think of enhancing an EditingDomain with another ResourceSet
that would only be used for referenced elements that would only be
read-only and not a container of the Resources. ie not modify the
containement of a resource if it is referenced in another Resource Set?
Today the read only state is handle by a map but this might be interesting
to enforce it with different special ResourceSet?
These are my thoughts for now and hope to find an anwer to my isssue soon.
SeB.
Ed Merks wrote:
> SeB,
> Comments below.
>> EditingDomains ?
>> model2 references?
>> Thanks SeB.
>> Ed Merks wrote:
>>> SeB,
>>> time...
>>> ekaii wrote:
>>>> Hi Ed,
>>> Yes.
>>>> unload-load ?
>>> recorder to work...
>>>> Thanks Ed.
Re: Sharing EMF instances across an application? [message #419429 is a reply to message #419419] Thu, 22 May 2008 07:36 Go to previous message
SeB,
Yes, I think the transactional framework has APIs for dealing with all
these kinds of issue. Maybe Christian will comment on that..
SeB.fr wrote:
> Hi Ed,
> an editor1 to edit model1 and editor2 to edit model2 referencing model1.
> therefor the same dirty state (usually based on the command Stack
> state) that means you modify model1 and then you see editor2 as dirty.
> forsee a way around?
> the doc and I am not sure this would solve my problem.
> ResourceSet that would only be used for referenced elements that would
> only be read-only and not a container of the Resources. ie not modify
> the containement of a resource if it is referenced in another Resource
> Set?
> interesting to enforce it with different special ResourceSet?
> soon.
> SeB.
> Ed Merks wrote:
>> SeB,
>> Comments below.
>> know I'm starting to lose track of it...
>>> EditingDomains ?
>> by at most one resource set.
>> level, it's really better to share the editing domain themselves.
>>> resources that means observe that the underliyng file has changed to
>>> update model2 references?
>> help with that. Or you can go with the more basic generated editor
>> where each edit has it's own copy of the model and is updated only
>> when the underlying workspace version is changed.
>>> Thanks SeB.
>>> Ed Merks wrote:
>>>> SeB,
>>>> each time...
>>>> ekaii wrote:
>>>>> Hi Ed,
>>>>> input instance does not exists anymore after the unload-load.
>>>> you'll want to get the new replacement instance instead.
>>>> EcoreUtil.resolve can be used for that.
>>>> Yes.
>>>>> unload-load ?
>>>> changes and roll them back, I suppose, but if you're having trouble
>>>> with the current details, I hate to think about trying to get a
>>>> change recorder to work...
>>>>> Thanks Ed.
Previous Topic:Generating xml with emf
Next Topic:problem with the model file
Current Time: Sun Jul 20 03:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.05296 seconds
