Problem with aliasings of ID values [message #418442] |
Wed, 16 April 2008 08:26  |
Hello!
I have stumbled upon an aliasing problem when dealing with an attribute
with its ID set to true in the core model for a particular class
hierarchy. The situation is the following. Consider an EClass hierarchy
with 'NamedElement' as its root. As expected, this NamedElement has an
EAttribute of type EString, and incidentally, its ID has been set to 'true'.
Now, suppose that we create two subclasses from NamedElement, namely 'A'
and 'B', and 'A' has a non-containment reference to 'B'. Now if a model is
created where both instances of 'A' and 'B' share the same name, and
the 'B' instance is set as the value of that reference for the 'A'
instance, the Editor gets confused and outputs the following exception:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'IDAliasing.impl.ModelImpl@166e555 (name: hello)' is not legal. (platform:/resource/test/My.idaliasing, 3, 58)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2637)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2622)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2778)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2695)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:85)
Also the reference to 'B' from 'A' appears void in the Properties View.
What I don't know is if this is what is expected for this case, or the
Editor could be capable of properly identify the static type encoded
for the reference and search only among the model elements that comply
with such type, which would seem to effectively avoid the aliasing that is
currently being produced. I also don't know if that would be compatible
with more general/complex cases.
A test case to reproduce this issue follows. It consists of a simple
core model and a conforming model that shows the explained problem. This
has been tested in EMF 2.4M5, but I'm pretty sure it also happens with EMF
2.3, at least.
Thank you very much!!!
Victor Sánchez
- IDAliasing.ecore:
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="IDAliasing"
nsURI="http://IDAliasing" nsPrefix="idaliasing">
<eClassifiers xsi:type="ecore:EClass" name="NamedElement" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
iD="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="A" eSuperTypes="#//NamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="b" eType="#//B"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="B" eSuperTypes="#//NamedElement"/>
<eClassifiers xsi:type="ecore:EClass" name="Model" eSuperTypes="#//NamedElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="items" upperBound="-1"
eType="#//NamedElement" containment="true"/>
</eClassifiers>
</ecore:EPackage>
- My.idaliasing:
<idaliasing:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:idaliasing="http://IDAliasing" name="hello">
<items xsi:type="idaliasing:A" name="hello" b="hello"/>
<items xsi:type="idaliasing:B" name="hello"/>
</idaliasing:Model>
Re: Problem with aliasings of ID values [message #418446 is a reply to message #418442] |
Wed, 16 April 2008 09:38   |
Victor,
Comments below.
Victor Sanchez wrote:
> Hello!
It seems likely that names might well not be unique across all objects
in a resource. Certainly ENamedElement.name in the Ecore model could
not be made an ID.
> at
Yep, I'd expect that. I doubt a "name" would really be an ID.
You mean after the above exception? I'd expect that when the ID doesn't
resolve to an object of the correct type.
No, that's not how IDs generally work. Resource.getEObject just takes a
string...
> 2.3, at least.
EMF does have support for EReference.eKeys, which might be more
appropriate...
> Victor Sánchez
> - IDAliasing.ecore:
> iD="true"/>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> - My.idaliasing:
> </idaliasing:Model>
Re: Problem with aliasings of ID values [message #418452 is a reply to message #418446] |
Wed, 16 April 2008 10:59  |
> string...
Ok, that's conclusive. Making the 'name' attribute become an ID for its
EClass seemed like a good idea at the time. And it has had its moments of
glory, when dealing with the XMI textual format. Now it is
clear that it has to be undone.
> appropriate...
I'll take a look at that. Thank you very much, Ed, for your quick answer!!!
Victor
FUDForum. Page generated in 0.09249 seconds
