Home » Modeling » EMF » XML namespaces in XMI documents
XML namespaces in XMI documents [message #418032] Wed, 02 April 2008 16:45 Go to next message
Originally posted by: Robertson_Don.emc.com
Firstly, my apologies for posting to eclipse.modeling as well. I only just
noticed this group.
I noticed that in generated XMI documents the root element is namespaced
with an explicit prefixed namespace declaration, but there is no default
namespace declaration and subordinate elements are not explicitly prefixed.
For example, "elements" below is not qualified (ecore and EMF from Ganymede
distribution) ...
<rdb:Schema xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:rdb="http://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb">
<elements xsi:type="rdb:Table"/>
</rdb:Schema>
My understanding of XML is that the subordinate elements are not within a
namespace - containment only offers visibility to in-scope namespace
declarations, not implicit namespace assignment (except to an in-scope
default namespace).
Is this the intended behavior? If so, it complicates the use of XMI
documents in an XML repository (eg. with XQuery). And I can't see a point to
it.
Hopefully I am just plain wrong. If not, I know I can control serialization,
but as a default behavior this means the whole organization will have to do
so if we are to have EMF-generated documents co-resident in a repository.
Any comments?
Re: XML namespaces in XMI documents [message #418033 is a reply to message #418032] Wed, 02 April 2008 17:12 Go to previous messageGo to next message
Don,
Comments below.
> noticed this group.
I'll let it go this time! :-P
That's the XMI way...
> distribution) ...
> </rdb:Schema>
> default namespace).
For sure that's true. For an XML element to have a namespace, it must
be qualified with prefix or an xmlns="..." declaration must be in scope.
> it.
It is the intended behavior. Features of classes are serialized as if
they are local element or attribute declarations in a complex type,
which by default are not qualified
(attribute/elementFormDefault="qualified" or form="qualified" on the
attribute/element would be necessary).
Well, it is the proper XMI default serialization. I'm not sure why
unqualified attributes are okay but unqualified elements concern you.
It's kind of the equivalent issue...
You can use extended meta data annotations to force them to be
serialized in a qualified form, but I don't think you should need to do
that. I don't think you'll find many XMI serializations which take that
approach...
> Any comments?
Hopefully you've had enough of my comments. :-P
Re: XML namespaces in XMI documents [message #418034 is a reply to message #418033] Wed, 02 April 2008 18:02 Go to previous messageGo to next message
Thanks for your response Ed.
The standard serialization works fine for "XML as documents", which is
exactly how we are using them now with EMF (successfully - thanks). My
problem arises when I want to aggregate these and potentially other XML data
sets (over which I have no control) into a common repository and reason
about them. Now the unqualified names become quite a nuisance because our
Xqueries cannot use qualified references and have to filter out potential
name collisions very deliberately.
I think I will have to consider an alternate serialization. Of course, the
serialization will have to work both for EMF consumption and for Xquery
consumption. I have to say though, that it doesn't seem like an uncommon use
case for EMF-generated XML to be consolidated in an XML repository for
non-EMF consumption.
I appreciate your explanation.
Don
On 4/2/08 2:12 PM, in article ft0ssh$f45$1@build.eclipse.org, "Ed Merks"
<merks@ca.ibm.com> wrote:
> Don,
> Comments below.
>> noticed this group.
>> distribution) ...
>> <?xml version="1.0" encoding="UTF-8"?>
>> </rdb:Schema>
>> default namespace).
>> it.
>>>They do concern me :-)
> approach...
>> Any comments?
Re: XML namespaces in XMI documents [message #418035 is a reply to message #418034] Wed, 02 April 2008 18:37 Go to previous message
--------------020901080909030908090103
Don,
Certainly my XQuery knowledge is thin at best but if there is no support
for proper schema-aware processing, i.e., processing which would make it
easy to find all instances of a given type, regardless of the fact that
there might be 1000 different elements (local or global) using that
type, then XQuery is pretty much useless. I kind of doubt XQuery is
useless, which makes me think that XQuery would be more than capable to
dealing with qualified and unqualified local element declarations in a
manner that makes the distinction between the two an irrelevant
syntactic detail. So I don't imagine this can be a big problem for a
fully functional XQuery processor...
In any case, it's pretty easy, though tedious, to produce a
serialization where all local element declarations are qualified.
Annotations on the Ecore model and options in the resource factory are
all that are needed.
> Don
>> Don,
>> Comments below.
>>> noticed this group.
>>> distribution) ...
>>> </rdb:Schema>
>>> default namespace).
>>> it.
>> approach...
>>> Any comments?
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Don,<br>
<br>
support for proper schema-aware processing, i.e., processing which
would make it easy to find all instances of a given type, regardless of
the fact that there might be 1000 different elements (local or global)
using that type, then XQuery is pretty much useless.&nbsp; I kind of doubt
XQuery is useless, which makes me think that XQuery would be more than
capable to dealing with qualified and unqualified local element
declarations in a manner that makes the distinction between the two an
irrelevant syntactic detail. So I don't imagine this can be a big
problem for a fully functional XQuery processor...<br>
<br>
serialization where all local element declarations are qualified.&nbsp;
all that are needed. <br>
<br>
<br>
<blockquote cite="mid:C419508B.2F4E%25Robertson_Don@emc.com" type="cite">
<pre wrap="">Thanks for your response Ed.
Don
On 4/2/08 2:12 PM, in article <a class="moz-txt-link-abbreviated" href="mailto:ft0ssh$f45$1@build.eclipse.org">ft0ssh$f45$1@build.eclipse.org</a>, "Ed Merks"
<a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Don,
Comments below.
</pre>
<pre wrap="">Firstly, my apologies for posting to eclipse.modeling as well. I only just
noticed this group.
</pre>
</blockquote>
<pre wrap="">I'll let it go this time! :-P
</pre>
<pre wrap="">I noticed that in generated XMI documents the root element is namespaced
</pre>
</blockquote>
<pre wrap="">That's the XMI way...
</pre>
<pre wrap="">For example, "elements" below is not qualified (ecore and EMF from Ganymede
distribution) ...
&lt;?xml version="1.0" encoding="UTF-8"?&gt;
&lt;rdb:Schema xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns:rdb=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb">"http://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb"</a>&gt;
&lt;elements xsi:type="rdb:Table"/&gt;
&lt;/rdb:Schema&gt;
default namespace).
</pre>
</blockquote>
<pre wrap="">For sure that's true. For an XML element to have a namespace, it must
</pre>
<pre wrap="">Is this the intended behavior? If so, it complicates the use of XMI
it.
</pre>
</blockquote>
<pre wrap="">It is the intended behavior. Features of classes are serialized as if
</pre>
<pre wrap="">Hopefully I am just plain wrong.
</pre>
</blockquote>
<pre wrap="">Well, it is the proper XMI default serialization. I'm not sure why
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">They do concern me :-)
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
<pre wrap="">If not, I know I can control serialization,
</pre>
</blockquote>
<pre wrap="">You can use extended meta data annotations to force them to be
approach...
</pre>
<pre wrap="">Any comments?
</pre>
</blockquote>
<pre wrap="">Hopefully you've had enough of my comments. :-P
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------020901080909030908090103--
Previous Topic:XSD generated from Ecore, why type="ecore:EString" for Strings and type="xsd:anyURI&q
Next Topic:Redefining features
Current Time: Sat Jul 19 08:30:56 EDT 2025
Powered by FUDForum. Page generated in 0.04619 seconds
