Home » Modeling » EMF » Problem with EFeatureMapEntry
Problem with EFeatureMapEntry [message #417652] Thu, 20 March 2008 09:50 Go to next message
Originally posted by: nima.mazloumi.gmx.de
I have defined the following model. Basically a Container may contain
Element1, Element2 and Element3 elements in any order. After gernerating
the editor I am not able to add any Element1-3 children. When I add them
manually in the XML and open it with the editor they are displayed in
the outline tree view.
Any idea what might be missing?
Nima
<eClassifiers xsi:type="ecore:EClass" name="Container"
eSuperTypes="#//UniqueElement">
<eStructuralFeatures xsi:type="ecore:EAttribute"
name="ContainerNodes" upperBound="-1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="group"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EReference" name="Element1"
upperBound="-1"
eType="#//Element1" volatile="true" transient="true"
containment="true">
<eAnnotations
<details key="group" value="#ContainerNodes"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Element2"
upperBound="-1"
eType="#//Element2" volatile="true" transient="true"
containment="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="Element3"
upperBound="-1"
eType="#//Element3" volatile="true" transient="true"
containment="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
Re: Problem with EFeatureMapEntry [message #417656 is a reply to message #417652] Thu, 20 March 2008 11:02 Go to previous messageGo to next message
Nima,
Because we don't yet have validation for extended metadata, it's usually
best if your stuck to write a schema example that corresponds to what
you want. I get the sense that because you've not specified
kind->"element" in the other features it's not wanting to associate the
other features with the group.
Nima Mazloumi wrote:
> gernerating the editor I am not able to add any Element1-3 children.
> When I add them manually in the XML and open it with the editor they
> are displayed in the outline tree view.
> Nima
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> containment="true">
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> containment="true">
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> containment="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
Re: Problem with EFeatureMapEntry [message #417659 is a reply to message #417656] Thu, 20 March 2008 12:37 Go to previous messageGo to next message
Hi Ed,
this used to work with older EMF versions. And I used ecore xmi as well.
Can it be, that latest EMF behavior is different?
Nima
Re: Problem with EFeatureMapEntry [message #417665 is a reply to message #417659] Thu, 20 March 2008 14:44 Go to previous messageGo to next message
Nima,
Perhaps it did change. I don't recall any changes that would have
affected this, but definitely a group must correspond to an XML Schema
model group and hence the things in it must be elements. Does adding
this information fix the problem?
> Hi Ed,
> Nima
Re: Problem with EFeatureMapEntry [message #417672 is a reply to message #417665] Thu, 20 March 2008 15:25 Go to previous messageGo to next message
>Does adding this information fix the problem?
What would the corresponding ecore markup look like? Do I use annotation kind element?
Re: Problem with EFeatureMapEntry [message #417673 is a reply to message #417672] Thu, 20 March 2008 16:50 Go to previous messageGo to next message
--------------000106010603030406020800
Nima,
<details key="kind" value="element"/>
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Nima,<br>
<blockquote>&lt;details key="kind" value="element"/&gt;
<br>
</blockquote>
<br>
<blockquote cite="mid:frudlv$ksj$1@build.eclipse.org" type="cite">&gt;Does
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000106010603030406020800--
Re: Problem with EFeatureMapEntry [message #417694 is a reply to message #417673] Fri, 21 March 2008 09:22 Go to previous messageGo to next message
Hello Ed,
I tried this:
<eClassifiers xsi:type="ecore:EClass" name="Container">
<eStructuralFeatures xsi:type="ecore:EReference" name="Element1" upperBound="-1"
eType="#//Element1" volatile="true" transient="true" containment="true">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
</eAnnotations>
</eClassifiers>
as well as:
</eAnnotations>
</eAnnotations>
</eClassifiers>
as well as:
<eClassifiers xsi:type="ecore:EClass" name="Element1">
</eAnnotations>
</eClassifiers>
But none of them works. Something must have changed from EMF 2.1.x to 2.3.x.
Generating a new editor with my old model results to the same problem, that now no children can be created.
Any idea? I would like to avoid redefining everything now using XML Schema.
Nima
Re: Problem with EFeatureMapEntry [message #417697 is a reply to message #417694] Fri, 21 March 2008 11:31 Go to previous message
Nima,
It definitely won't be necessary to redefine in schema, but defining an
analogous example in schema and comparing the annotations would help.
Just glancing at XMI serialized Ecore snippets it's hart to see problems
jump out. If you care to send me the complete Ecore model, I can have a
look using the tools, to try to reproduce the problem.
> Hello Ed,
> I tried this:
> upperBound="-1"
> containment="true">
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> as well as:
> upperBound="-1"
> containment="true">
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> as well as:
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> 2.3.x.
> Schema.
> Nima
Previous Topic:km3 -> ecore - bad practice in metamodeling?
Next Topic:using ecore-model in eclipse view
Current Time: Sat Jul 19 18:49:13 EDT 2025
Powered by FUDForum. Page generated in 0.04214 seconds
