Home » Modeling » EMF » Unable to View contents in EMF Editor
Unable to View contents in EMF Editor [message #417322] |
Wed, 05 March 2008 08:31  |
I am playing with the Generated EMF editor by removing the inline pages
and creating the Pages as Seperate EditorParts and adding the same to the
Multipage editor.
When my input to the Editor Part is called i see the a XXXResourceImpl is
passed as input
I have added the AdapterFactoryContent and LabelProvider to my tree, when
the editor is opened I am unable to see the Root Element Object or
anything else in the Tree , just an empty tree is visible ..
Can anyone let me know where i would have gone wrong ??
My EditorPart code snippet :
public class TableTreeEditorPart extends AbstractPortalStructureEditPart {
private TreeViewer treeViewer;
private Tree tree;
public TableTreeEditorPart(PortalStructureEditor editor) {
super(editor);
* (non-Javadoc)
* @see
org.eclipse.ui.part.WorkbenchPart#createPartControl(org.ecli pse.swt.widgets.Composite)
public void createPartControl(Composite parent) {
treeViewer = new TreeViewer(parent, SWT.NONE);
tree = treeViewer.getTree();
tree.setLayout(new FillLayout());
tree.setLinesVisible(true);
tree.setHeaderVisible(true);
treeViewer.setContentProvider(new AdapterFactoryContentProvider(
getAdapterFactory()));
treeViewer.setLabelProvider(new AdapterFactoryLabelProvider(
createContextMenuFor(treeViewer);
getEditorSite().setSelectionProvider(treeViewer);
* (non-Javadoc)
* @see org.eclipse.ui.part.WorkbenchPart#setFocus()
public void setFocus() {
tree.setFocus();
* (non-Javadoc)
* @see
com.accenture.portal.tools.xasgen.portalstructure.presentati on.parts.AbstractPortalStructureEditPart#setInput(java.lang. Object)
public void setInput(Object input) {
System.out.println("TableTreeEditorPart.setInput() : " + input);
assert input != null;
assert treeViewer != null;
treeViewer.setInput(input);
Re: Unable to View contents in EMF Editor [message #417333 is a reply to message #417331] |
Wed, 05 March 2008 11:01   |
Thanks Ed. I am able to rectify it .. Also i do have a one more question on
the Selection ,
I am using the MultipageSelectionProvider for the Editor , in my tree when i
click on the node and add a child or sibling my Selection still remains on
the Node from which I initiated the Command , my question is how do I move
the selection to the newly added element ???
This works fine with the Generated editor , my doubt is that am making a
mess with the Selection with my dissected EMF editor ???
Thoughts please ...
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fqmfqi$du0$2@build.eclipse.org...
> Kamesh,
> The generated editor's handleContentOutlineSelection shows how to do that
> doesn't it?
> Kamesh Sampath wrote:
>> Hi Ed,
>> I debugged the issue , the issue was with the ContentOutlineSelection.
>> Its not able to provide the proper selection element since there was a
>> bug in the code that I wrote..
>> I also gave a treeviwer.refresh() after setting the input ..
>> I have one quick question, how to make the Tree listen to the
>> ContentOutlineSelection by just navigating to the Selected Element in the
>> Outline view , I dont need it to go to its children , just stay at the
>> same element selected by the Outline.
Re: Unable to View contents in EMF Editor [message #417335 is a reply to message #417333] |
Wed, 05 March 2008 11:13   |
--------------070604040008000608000209
Kamesh,
The generated editor's setCurrentView method handles updating the
selection and listening to the current view to forward its selection.
So I guess you need to hook up your MultipageSelectionProvider thing so
that it serves the same kind of purpose...
> the Selection ,
> Thoughts please ...
>> Kamesh,
>> doesn't it?
>>> Hi Ed,
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kamesh,<br>
<br>
that it serves the same kind of purpose...<br>
<br>
<br>
<blockquote cite="mid:fqmg51$hjj$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks Ed. I am able to rectify it .. Also i do have a one more question on
the Selection ,
Thoughts please ...
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fqmfqi$du0$2@build.eclipse.org">news:fqmfqi$du0$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kamesh,
doesn't it?
</pre>
<pre wrap="">Hi Ed,
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070604040008000608000209--
Re: Unable to View contents in EMF Editor [message #417337 is a reply to message #417335] |
Wed, 05 March 2008 12:25  |
------=_NextPart_000_000B_01C87F14.09C1FA00
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed,
Thanks for your toughts ! The reason it was not working is that 1. As =
you said the currentViewer was not set and there by when the commands =
are fired the setSelectionToViewer method was not able to perform its =
task of setting the selection to recentlyAffectedObjects .
So I tried to set the CurrentViewer on pageChange where each page of my =
multipage editor part is associated with an StructuredViewer.
~Kamesh
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fqmgs9$o5b$1@build.eclipse.org...
Kamesh,
The generated editor's setCurrentView method handles updating the =
selection and listening to the current view to forward its selection. =
So I guess you need to hook up your MultipageSelectionProvider thing so =
Kamesh Sampath wrote:=20
Thanks Ed. I am able to rectify it .. Also i do have a one more question =
on=20
the Selection ,
I am using the MultipageSelectionProvider for the Editor , in my tree =
when i=20
click on the node and add a child or sibling my Selection still remains =
on=20
the Node from which I initiated the Command , my question is how do I =
move=20
This works fine with the Generated editor , my doubt is that am making =
a=20
Thoughts please ...
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Kamesh,
The generated editor's handleContentOutlineSelection shows how to do =
that=20
doesn't it?
Hi Ed,
I debugged the issue , the issue was with the ContentOutlineSelection.=20
Its not able to provide the proper selection element since there was a=20
I have one quick question, how to make the Tree listen to the=20
ContentOutlineSelection by just navigating to the Selected Element in =
the=20
Outline view , I dont need it to go to its children , just stay at the=20
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.6000.16608" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DVerdana size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2></FONT> </DIV>
<DIV><FONT face=3DVerdana size=3D2>Thanks for your toughts ! The reason =
it was not=20
working is that 1. As you said the currentViewer was not set and =
there by=20
when the commands are fired the setSelectionToViewer method was not able =
to=20
perform its task of setting the selection to recentlyAffectedObjects=20
..</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>So I tried to set the CurrentViewer =
on pageChange=20
where each page of my multipage editor part is associated with an=20
StructuredViewer.</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>~Kamesh</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fqmgs9$o5b$1@build.eclipse.org">news:fqmgs9$o5b$1@build.ecli=
pse.org</A>...</DIV>Kamesh,<BR><BR>The=20
selection and=20
listening to the current view to forward its selection. So I =
guess you=20
need to hook up your MultipageSelectionProvider thing so that it =
serves the=20
same kind of purpose...<BR><BR><BR>Kamesh Sampath wrote:=20
<BLOCKQUOTE cite=3Dmid:fqmg51$hjj$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Thanks Ed. I am able to rectify it .. Also =
i do have a one more question on=20
the Selection ,
when i=20
on=20
move=20
a=20
Thoughts please ...
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fqmfqi$du0$2@build.eclipse.org">news:fqmfqi$du0$2@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Kamesh,
that=20
doesn't it?
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Ed,
the=20
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000B_01C87F14.09C1FA00--
Current Time: Sat Jul 19 06:26:49 EDT 2025
Powered by FUDForum. Page generated in 0.17062 seconds
