ExceptionInitializationError [message #417252] |
Mon, 03 March 2008 17:29  |
I just generated a model with EMF. I've got the core, edit, editor and
tests plugin projects in my workspace. When I run the JUnit Tests from the
tests projects, I get the following error, because the
call to
eclipse.emf.ecore.impl.EPackageRegistryImpl,delegateRegistry (Thread.currentThread().getContextClassLoader())
takes null as a parameter, or said another way, the value of
Thread.currentThread().getContextClassLoader() is null.
The problem occurs on MacOSX 10.5 with Eclipse 3.3.2 / EMF 2.3.0 (build
20080205)
Here is the statcktrace :
java.lang.ExceptionInInitializerError
at
org.log4jconfig.model.DocumentOutputTest.setUp(DocumentOutpu tTest.java:65)
at junit.framework.TestCase.runBare(TestCase.java:128)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl$Delegator.ge tEPackage(EPackageRegistryImpl.java:245)
at
org.log4jconfig.metadata.Log4jElementsPackage.init(Log4jElem entsPackage.java:984)
at
org.log4jconfig.metadata.Log4jElementsPackage.<clinit>(Log4jElementsPackage.java:78)
... 14 more
Thanks in advance
Xavier
Re: ExceptionInitializationError [message #417254 is a reply to message #417252] |
Mon, 03 March 2008 18:02   |
Xavier,
I've never seen a case there the thread context class loader is null,
except during process shutdown. I think this is a problem in the SDK
itself. I think changes in EMF 2.4 avoid this problem as well...
Xavier wrote:
> Hello,
> the tests projects, I get the following error, because the call to
> (build 20080205)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 14 more
> Thanks in advance
> Xavier
Re: ExceptionInitializationError [message #417302 is a reply to message #417301] |
Tue, 04 March 2008 17:01  |
Xavier,
Very odd indeed. I'm glad it's working for you now...
Xavier wrote:
> Ed,
> I clean every project (removed all generated classes), then
> re-generated all classes from the gen model. It works now, but i still
> can't say what was wrong...
> Thanks anyway for your help.
> /Xavier
FUDForum. Page generated in 0.03891 seconds
