Home » Modeling » EMF » ExceptionInitializationError
ExceptionInitializationError [message #417252] Mon, 03 March 2008 17:29 Go to next message
I just generated a model with EMF. I've got the core, edit, editor and
tests plugin projects in my workspace. When I run the JUnit Tests from the
tests projects, I get the following error, because the
call to
eclipse.emf.ecore.impl.EPackageRegistryImpl,delegateRegistry (Thread.currentThread().getContextClassLoader())
takes null as a parameter, or said another way, the value of
Thread.currentThread().getContextClassLoader() is null.
The problem occurs on MacOSX 10.5 with Eclipse 3.3.2 / EMF 2.3.0 (build
20080205)
Here is the statcktrace :
java.lang.ExceptionInInitializerError
at
org.log4jconfig.model.DocumentOutputTest.setUp(DocumentOutpu tTest.java:65)
at junit.framework.TestCase.runBare(TestCase.java:128)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl$Delegator.ge tEPackage(EPackageRegistryImpl.java:245)
at
org.log4jconfig.metadata.Log4jElementsPackage.init(Log4jElem entsPackage.java:984)
at
org.log4jconfig.metadata.Log4jElementsPackage.<clinit>(Log4jElementsPackage.java:78)
... 14 more
Thanks in advance
Xavier
Re: ExceptionInitializationError [message #417254 is a reply to message #417252] Mon, 03 March 2008 18:02 Go to previous messageGo to next message
Xavier,
I've never seen a case there the thread context class loader is null,
except during process shutdown. I think this is a problem in the SDK
itself. I think changes in EMF 2.4 avoid this problem as well...
Xavier wrote:
> Hello,
> the tests projects, I get the following error, because the call to
> (build 20080205)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 14 more
> Thanks in advance
> Xavier
Re: ExceptionInitializationError [message #417294 is a reply to message #417254] Tue, 04 March 2008 13:23 Go to previous messageGo to next message
Hello Ed,
I just tried with the latest milestone of Eclipse Ganymede and the problem
still occurs...
What other pieces of information should I provide to solve this problem ?
Thank you in advance
/Xavier
Re: ExceptionInitializationError [message #417297 is a reply to message #417294] Tue, 04 March 2008 13:52 Go to previous messageGo to next message
Xavier,
I guess the null pointer exception has just moved elsewhere. Is
something fiddling with your thread's context class loader that it's
null? I've never seen a case of it being before. It's expect it to be
just ClassLoader.getSystemClassLoader...
You can use the VM option
-Dorg.eclipse.emf.ecore.EPackage.Registry.INSTANCE=org.eclip se.emf.ecore.impl.EPackageRegistryImpl
to use the other implementation...
Xavier wrote:
> Hello Ed,
> problem still occurs...
> /Xavier
Re: ExceptionInitializationError [message #417301 is a reply to message #417297] Tue, 04 March 2008 16:38 Go to previous messageGo to next message
Ed,
I clean every project (removed all generated classes), then re-generated
all classes from the gen model. It works now, but i still can't say what
was wrong...
Thanks anyway for your help.
/Xavier
Re: ExceptionInitializationError [message #417302 is a reply to message #417301] Tue, 04 March 2008 17:01 Go to previous message
Xavier,
Very odd indeed. I'm glad it's working for you now...
Xavier wrote:
> Ed,
> re-generated all classes from the gen model. It works now, but i still
> can't say what was wrong...
> /Xavier
Previous Topic:Question about persistence in EMF
Next Topic:Customized getters and setters
Current Time: Sat Jul 19 06:36:33 EDT 2025
Powered by FUDForum. Page generated in 0.04445 seconds
