ocl operation and parameter type. [message #41594] |
Thu, 25 October 2007 06:41  |
Originally posted by: firstname.name.gmail.com
I would like to create an operation in a custom UMLEnvironment, which will be
evaluated with its proper Java method. One of its parameter should accept /any
type/ of parameter. (In java I would have used java.lang.Object)
for example, I would like to make possible to do:
myOperation('a String')
myOperation(Bag{'StringA','StringB')
my problem is that I can't find out any common type for this parameter.
To do the trick, I created two distinct operations to properly handle collection
parameter, but my custom operation is still never matched.
here it is how I declare the type of the parameter:
for a non-collection parameter:
variable.setType(getOCLStandardLibrary().getOclAny())
for a collection parameter:
org.eclipse.ocl.util.TypeUtil.resolveCollectionType(this,
CollectionKind.COLLECTION_LITERAL, getOCLStandardLibrary().getAny)
thanks in advance.
F. Lagarde
Re: ocl operation and parameter type. [message #41640 is a reply to message #41594] |
Thu, 25 October 2007 09:13   |
Hi, François,
OCL collection types are defined as specifically *not* conforming to OclAny
(they are the only exception), so you would need to distinct signatures
anyway. The look-up of collection parameters currently, I think, requires
an EList signature. I suspect that OclAny mapping to Object is not
supported (the only usage so far of OclAny is in the OCL Standard Library
types, for which matching operations to Java is not an issue).
Of course, you can customize the operation signature look-up in your custom
environment, as well, to suit your requirements. However, it seems useful
in general to be able to match OclAny to Object and OCL collections to
their corresponding Java types. Feel free to raise an enhancement for
this. And feel even freer to include a patch! :-)
Christian
François Lagarde wrote:
> Hello,
> be
> /any type/ of parameter. (In java I would have used java.lang.Object)
> collection parameter, but my custom operation is still never matched.
> thanks in advance.
Re: ocl operation and parameter type. [message #41656 is a reply to message #41640] |
Thu, 25 October 2007 11:08  |
In the last post, on 10/25 about 03h, "Christian" (Christian W Damus) wrote:
Christian> Hi, François, OCL collection types are defined as specifically
Christian> *not* conforming to OclAny (they are the only exception), so
Christian> you would need to distinct signatures anyway.
thanks for your prompt reply.
I solved my problem with two distinct methods having two distinct
signatures. Correct type for collection is:
TypeUtil.resolveCollectionType(this, CollectionKind.COLLECTION_LITERAL, getOCLStandardLibrary().getOclAny())
Christian> However, it seems useful in general to be able to match
Christian> OclAny to Object and OCL collections to their corresponding
Christian> Java types.
could be nice, but really don't know how easy is to integrate. I was also facing
to convert Java type to UML type. Maybe an additional helper could be helpful
(for both UML or UML.OCL plugin)
thanks for the quality of this plugin.
F. Lagarde
FUDForum. Page generated in 0.25713 seconds
