Home » Modeling » EMF » Access EcoreModel instance
Access EcoreModel instance [message #416420] Thu, 31 January 2008 04:17 Go to next message
Originally posted by: harkon.ogame.gmail.com
Hi everybody...
I encountered a problem in accessing an instance of a Ecore modell
residing in my workspace of Eclipse.
Situation: I want to access an Ecore Modell from a newly created Plugin
existing in the current Eclipse instance. This can be done via an URL file
based. if I now open die URL I can access the content and everything is
fine.
Now if an Ecore Model editor is open in the same time the model won't be
updated immediately. I have to refresh the display.
Question: The Ecore Model Editor owns a Ecore Model reference itself
(EObject root node). How can I access this root node of the opened Ecore
Model Editor?
The background is: I want to alter the content of an Ecore model via EMF
techniques and whenever a change was registered the EMF fires various
events about this update and the Ecore Model Editor changes its display
"on the fly". Now if I change the model from another Eclipse Plugin via
this root node instance of the opened Ecore Model Editor I can "see" the
changes in the moment they happen...
I hope I made myself clear enough that some one could help me ;)
Cheers
harkon
Re: Access EcoreModel instance [message #416423 is a reply to message #416420] Thu, 31 January 2008 05:35 Go to previous messageGo to next message
Harkon,
Comments below.
harkon wrote:
> Hi everybody...
> Plugin existing in the current Eclipse instance. This can be done via
> an URL file based. if I now open die URL I can access the content and
> everything is fine.
> be updated immediately. I have to refresh the display.
You haven't talked about making modifications yet, so I'm missing the
connection or a step as to why the display needs refreshing.
> Ecore Model Editor?
All generated editors implement IEditingDomainProvider so you can cast
the editor to that, get the editing domain, and from that you have
access to the resource set in which all the resources being edited are kept.
> EMF techniques and whenever a change was registered the EMF fires
> various events about this update and the Ecore Model Editor changes
> its display "on the fly".
Be sure to use the command stack of the editing domain to make all your
changes so that the editor can undo the changes and knows that it's
dirty and needs to save.
> Now if I change the model from another Eclipse Plugin via this root
> node instance of the opened Ecore Model Editor I can "see" the changes
> Cheers
> harkon
Re: Access EcoreModel instance [message #416455 is a reply to message #416423] Fri, 01 February 2008 09:47 Go to previous messageGo to next message
Hi Ed!
Yes, my intention is to make a m2m transformation on Ecore models and to
see the changes on the fly.
Okay, all editors implement the interface you mentioned below but now:
The user chooses which model is the source and which one is the
destiantion. This decision is made via a workspace browser and the files
are selected.
After that decision the model shall be opened with the default editor
(e.g. Ecore Model Editor).
Maybe one model is already opened.
How to find now the corresponding editor? And above all how to
automatically open a file in an editor from another plugin?
Hmm, weird ;)
Cheers
harkon
Ed Merks wrote:
> Harkon,
> Comments below.
> harkon wrote:
>> Hi everybody...
>> everything is fine.
>> Ecore Model Editor?
>> Cheers
>> harkon
Re: Access EcoreModel instance [message #416459 is a reply to message #416455] Fri, 01 February 2008 12:16 Go to previous messageGo to next message
Karkon,
Comments below.
harkon wrote:
> Hi Ed!
> to see the changes on the fly.
> files are selected.
Each workbench page provides access to all the open editors, so I guess
you could scan them all...
> And above all how to automatically open a file in an editor from
> another plugin?
The generated wizard's performFinish shows how to do that.
I could imagine another way to implement such a thing is as a popup
action on an EPackage...
> Hmm, weird ;)
> Cheers
> harkon
> Ed Merks wrote:
>> Harkon,
>> Comments below.
>> harkon wrote:
>>> Hi everybody...
>>> via an URL file based. if I now open die URL I can access the
>>> content and everything is fine.
>>> won't be updated immediately. I have to refresh the display.
>>> Ecore Model Editor?
>> cast the editor to that, get the editing domain, and from that you
>> have access to the resource set in which all the resources being
>> edited are kept.
>> your changes so that the editor can undo the changes and knows that
>> it's dirty and needs to save.
>>> Cheers
>>> harkon
Re: Access EcoreModel instance [message #416465 is a reply to message #416459] Sun, 03 February 2008 09:00 Go to previous messageGo to next message
Hi Ed!
>>> edited are kept.
Yes - now I see it ;) and i can cast it... But now how to access the
EObject within?
I find no way to even identify the correct class -.-
Can I iterate to all EObjects within the model via this resource set?
Cheers
harkon
Re: Access EcoreModel instance [message #416467 is a reply to message #416465] Sun, 03 February 2008 23:19 Go to previous message
Hi Harkon,
The method EcoreUtil.getAllContents(ResourceSet, boolean) returns an
iterator that allows you to do what you are looking for. If you pass
true as the 2nd argument, you will end up loading any resource that has
instances related to the model you are inspecting.
Analyzing the code of this method will probably help you understanding
EMF a bit more.
Marcelo.
harkon wrote:
> Hi Ed!
>>>> edited are kept.
> EObject within?
> Cheers
> harkon
Previous Topic:Serialization: additional date formats
Next Topic:Using Rose2GenModel command
Current Time: Sat Jul 19 11:49:21 EDT 2025
Powered by FUDForum. Page generated in 0.05637 seconds
