Home » Modeling » EMF » How to add namespace info into XMLResource
How to add namespace info into XMLResource [message #416139] Fri, 18 January 2008 10:58 Go to next message
Originally posted by: a.rahman.distilinteractive.com
I am trying to add namespce info before saving an XMLResource. It is
someting like <anyElement
xsi:noNamespaceSchemaLocation="someLocation">.
I have checked the ExtendedMetaData and BasicExtendedMetaData classes, but
not very clear on how to use this classess for this issue.
I have tried :
((BasicExtendedMetaData)((XMLResource)resource).getDefaultSa veOptions().get(XMLResource.OPTION_EXTENDED_META_DATA)).setN amespace(somePackage.eINSTANCE.getDocumentRoot_SomeElemnt(),
"test");
which produeces : <test:anyElement xmlns:test="test" >.
-Anisur.
Re: How to add namespace info into XMLResource [message #416147 is a reply to message #416139] Fri, 18 January 2008 13:21 Go to previous messageGo to next message
Anisur,
Do you generate this model from a schema with no target namespace?
Generated models typically don't save a schemaLocation but if you are
using the resource factory generated for the package to create the
resource you could use the trick of doing
XyzPackage.eINSTANCE.eResource().setURI(URI.createURI("someLocation ")
and then, since the location doesn't match the namespace and since the
generated resource impl as the OPTION_SCHEMA_LOCATION set to true, it
should save an xsi:schemaLocation...
Anisur wrote:
> I have tried :
> "test");
> -Anisur.
Re: How to add namespace info into XMLResource [message #416160 is a reply to message #416147] Fri, 18 January 2008 16:09 Go to previous messageGo to next message
Hi Ed,
Thank you for your reply. I am using the resource factory generated for the
package., and included
XyzPackage.eINSTANCE.eResource().setURI(URI.createURI("someLocation ") , but
still does not generates the output.
Following is the code sample:
My..Package.eINSTANCE.eResource().setURI(someURI);
My..ResourceFactoryImpl factory = new My..ResourceFactoryImpl();
Resource resource = factory.createResource(uri);
((XMLResource)resource).getDefaultSaveOptions().put(XMLResou rce.OPTION_SCHEMA_LOCATION,Boolean.TRUE);
DocumentRoot root = My..Factory.eINSTANCE.createDocumentRoot();
root.set......(someObject);
resource.getContents().add(root);
try {
resource.save(null);
} catch (IOException e) { }
-Anisur.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fmqqms$emg$1@build.eclipse.org...
> Anisur,
> XyzPackage.eINSTANCE.eResource().setURI(URI.createURI("someLocation ") and
> Anisur wrote:
>> Hi,
>> but not very clear on how to use this classess for this issue.
>> I have tried :
>> "test");
>> Thanks,
>> -Anisur.
Re: How to add namespace info into XMLResource [message #416161 is a reply to message #416160] Fri, 18 January 2008 16:32 Go to previous messageGo to next message
--------------070101020503030100060809
Anisur,
I'm looking into why this doesn't work for a null namespace package like
it does for any other package... In the meantime, you can use:
root.getXSISchemaLocation().put(null, "someLocation");
Anisur wrote:
> Hi Ed,
> try {
> -Anisur.
>> Anisur,
>> Anisur wrote:
>>> Hi,
>>> I have tried :
>>> "test");
>>> Thanks,
>>> -Anisur.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Anisur,<br>
<br>
like it does for any other package...&nbsp; In the meantime, you can use:<br>
<blockquote>root.getXSISchemaLocation().put(null, "someLocation");<br>
</blockquote>
<br>
Anisur wrote:
<blockquote cite="mid:fmr4nm$hif$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
try {
-Anisur.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fmqqms$emg$1@build.eclipse.org">news:fmqqms$emg$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Anisur,
Anisur wrote:
</pre>
<pre wrap="">Hi,
someting like &lt;anyElement
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xsi:noNamespaceSchemaLocation="someLocation"&gt;.
I have tried :
"test");
which produeces : &lt;test:anyElement xmlns:test="test" &gt;.
-Anisur.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070101020503030100060809--
Re: How to add namespace info into XMLResource [message #416191 is a reply to message #416161] Mon, 21 January 2008 11:40 Go to previous messageGo to next message
Hi Ed,
Thank you for your reply. Using root.getXSISchemaLocation().put(null,
"someLocation") saves the schema location. However, the scheman location is
changed changed intor relative to the current resource location. I am using
the locations as "file:/.........someXsdFile.xsd", however it is changed
into "../.../someXsdFile.xsd", doing so, if the file copied into different
filelocation of the same computer, xsd info becomes invalid.
Thank you,
-Anisur.
news:fmr5tf$to0$1@build.eclipse.org...
> Anisur,
> Anisur wrote:
>> Hi Ed,
>> the
>> but
>> try {
>> Thanks,
>> -Anisur.
>>> Anisur,
>>> and
>>> Anisur wrote:
>>>> Hi,
>>>> I have tried :
>>>> "test");
>>>> Thanks,
>>>> -Anisur.
Re: How to add namespace info into XMLResource [message #416192 is a reply to message #416191] Mon, 21 January 2008 11:48 Go to previous messageGo to next message
--------------090609030500030102070105
Anisur,
That's true, but if the project containing both the instance and the
schema is both moved, then it will remain valid whereas the absolute
location would be correct. The absolute location is also not likely to
be correct across machines. You'd of course be best to use a schema
location that's truly portable across machines, like an http URI. Or
you could use a "symbolic" URI and define a URI mapping from the
symbolic location to a physical location...
You can use this option to influence/control how URIs are deresolved and
resolved:
* A {@link URIHandler} value that will be used to control how
URIs are {@link URI#resolve(URI) resolved} during load
* and {@link URI#deresolve(URI) deresolved} during save.
* @see URI
* @see URIHandler
* @see XMLHelper#resolve(URI, URI)
* @see XMLHelper#deresolve(URI)
* @see URIHandlerImpl
String OPTION_URI_HANDLER = "URI_HANDLER";
Anisur wrote:
> Hi Ed,
> Thank you,
> -Anisur.
>> Anisur,
>> Anisur wrote:
>>> Hi Ed,
>>> the
>>> but
>>> try {
>>> Thanks,
>>> -Anisur.
>>>> Anisur,
>>>> and
>>>> Anisur wrote:
>>>>> Hi,
>>>>> I have tried :
>>>>> "test");
>>>>> Thanks,
>>>>> -Anisur.
<html>
<head>
</head>
Anisur,<br>
<br>
location would be correct.&nbsp; The absolute location is also not likely to
be correct across machines.&nbsp; You'd of course be best to use a schema
location that's truly portable across machines, like an http URI.&nbsp; Or
symbolic location to a physical location...<br>
<br>
and resolved:<br>
<blockquote>&nbsp; /**<br>
&nbsp;&nbsp; * A {@link URIHandler} value that will be used to control how URIs
are {@link URI#resolve(URI) resolved} during load <br>
&nbsp;&nbsp; * and {@link URI#deresolve(URI) deresolved} during save.<br>
&nbsp;&nbsp; * @see URI<br>
&nbsp;&nbsp; * @see URIHandler<br>
&nbsp;&nbsp; * @see XMLHelper#resolve(URI, URI)<br>
&nbsp;&nbsp; * @see XMLHelper#deresolve(URI)<br>
&nbsp;&nbsp; * @see URIHandlerImpl<br>
&nbsp;&nbsp; */<br>
&nbsp; String OPTION_URI_HANDLER = "URI_HANDLER";<br>
</blockquote>
<br>
<br>
Anisur wrote:
<blockquote cite="mid:fn2i2i$iah$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
the locations as <a class="moz-txt-link-rfc2396E" href="file:/.........someXsdFile.xsd">"file:/.........someXsdFile.xsd "</a>, however it is changed
Thank you,
-Anisur.
<a class="moz-txt-link-freetext" href="news:fmr5tf$to0$1@build.eclipse.org">news:fmr5tf$to0$1@build.eclipse.org</a>...
</pre>
Anisur wrote:
</pre>
<pre wrap="">Hi Ed,
the
but
try {
-Anisur.
</pre>
and
Anisur wrote:
</pre>
<pre wrap="">Hi,
I have tried :
"test");
-Anisur.
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090609030500030102070105--
Re: How to add namespace info into XMLResource [message #416193 is a reply to message #416192] Mon, 21 January 2008 12:11 Go to previous message
Thank you very much Ed for the information. I got the point of this
behaviour. This behaviour allows to copy the whole project. Actually, I am
working on a RCP , where the schema is located in the installatin directory,
and never changes the location. However, the user is free to chose the
resource loaction any where in the local PC. Thank you again for helping me
and providing all the info.
-Anisur.
news:fn2icd$kcn$1@build.eclipse.org...
> Anisur,
> resolved:
> * @see URI
> * @see URIHandler
> Anisur wrote:
>> Hi Ed,
>> is
>> using
>> different
>> Thank you,
>> -Anisur.
>>> Anisur,
>>> Anisur wrote:
>>>> Hi Ed,
>>>> the
>>>> but
>>>> try {
>>>> Thanks,
>>>> -Anisur.
>>>>> Anisur,
>>>>> and
>>>>> Anisur wrote:
>>>>>> Hi,
>>>>>> classes,
>>>>>> I have tried :
>>>>>> "test");
>>>>>> Thanks,
>>>>>> -Anisur.
Previous Topic:EMF model gobal registry lazy load?
Next Topic:ItemProvider and changeNotification
Current Time: Sat Jul 19 21:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.04662 seconds
