Home » Modeling » EMF » How to initialize a XMLCalendar
How to initialize a XMLCalendar [message #416068] Wed, 16 January 2008 18:19 Go to next message
The fix for https://bugs.eclipse.org/bugs/show_bug.cgi?id=203510 is in,
which solves one direction of the comparison issue, but as mentioned in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191219, a class cast
exception can still occur if equals is called on a
XMLGregorianCalendarImpl with an XMLCalendar as the argument.
I ran into this because I had programatically initialized a
XMLGregorianCalendar field on my eobject to the current date using
DatatypeFactory.newXMLGregorianCalendarDate (which creates a
XMLGregorianCalendarImpl). Later, a new date was set which was an
XMLCalendar. During NotificationImpl.isTouch(), equals is called and
the Sun JVM throws the exception.
It seems to me that due to the Sun bug, all EMF code should be careful
to use XMLCalendar implementations, which leads me to the question of
how best to initialize one.
The only way I see is use XMLTypeFactory.createDate, but this requires a
string. Is there any other way? XMLTypeFactory.convertDate looks like
it should work off a java.util.Date, but it's deprecated. What's the
reason for deprecation?
Will
Re: How to initialize a XMLCalendar [message #416069 is a reply to message #416068] Wed, 16 January 2008 19:16 Go to previous messageGo to next message
Will,
It would be good to open a bug against the Sun JVM because there is no
reason for any one implementation to assume there it is the one and
only implementation of a public abstract class provided by the JDK. All
methods should respect the public class' API and should be written only
to assume that the public abstract class' method are implemented...
The Object-based methods in the XMLTypeFactory are superseded for Java
5.0 by the more strongly typed methods that use the actual XML Schema
appropriate types that weren't available in a 1.4 JDK. Even the types
of the methods generated for the XML Schema data types not supported in
1.4 will have changed from java.lang.Object to XMLGregorianCalendar,
Duration, or QName...
> in, which solves one direction of the comparison issue, but as
> mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=191219, a
> class cast exception can still occur if equals is called on a
> a string. Is there any other way? XMLTypeFactory.convertDate looks
> like it should work off a java.util.Date, but it's deprecated. What's
> the reason for deprecation?
> Will
Re: How to initialize a XMLCalendar [message #416070 is a reply to message #416069] Wed, 16 January 2008 20:22 Go to previous messageGo to next message
I have to pipe up here and say that my company has had a litany of
problems with XMLGregorianCalender implementations.
We've had all kinds of fun such as:
- Different vendors using different calendar implementations
(like the com.sun.org.apache packages! What the hey is that!?!?)
- CCE during comparisons
- CCE during hibernate persistence
- All manner of SOAP / XML mapping problems
For us it has gotten bad enough for us to abandon all of the XSD
calendar and time functionality. The sad fact is that these features
simply don't work reliably. I can blame anyone I want but knowing who
to blame doesn't help me deliver anything.
Instead we've defined a new type in XSD which has a date attribute and a
time attribute. We let both attributes be strings and use XSD to
restrict the valid values. We make the restrictions match what the DB
wants a date string to look like and we provide some utility methods to
convert the strings into date types for java code uses. It's a pity we
have to do this ourselves, but out implementation always works while the
sun/ibm/apache stuff just doesn't play nicely together.
In then end their stuff is doing to same parsing and conversions as our
code, so it doesn't really hurt anything to do this. Plus, you're
company will spend way more money on developer wasted due to XMLCalendar
problems than it will lose in lost performance due to String/Date
conversions.
Just letting you know,
Jason Henriksen
Ed Merks wrote:
> Will,
>> Thanks,
>> Will
Re: How to initialize a XMLCalendar [message #416075 is a reply to message #416070] Thu, 17 January 2008 04:27 Go to previous message
Jason,
Comments below.
Can you imagine the fun of taking open source, changing it arbitrarily,
including package renames, and giving nothing back, not even bug fixes?
All too often such changes produce incompatible behavior. APL is so
flexible and lenient. To their defense, by renaming it, which the IBM
JVM doesn't do, they do make it easier to use Apache's libraries
directly, given there are no name collisions.
Isn't it obvious how to do this right you might ask? You have a public
abstract class and all methods should assume only that much about the
implementation. Didn't the implementation start out right before it was
butchered? And why exactly do we need different implementations of this
anyway? Doesn't that just represent a problem for java.io.Serializeable
support? Of course there's another wonderful bit of technology...
I find it incredible that important XML functionality should be all to
often impaired by incompatibilities. The number of times I've had to
deal with problem like hasAttributeNS(null, "name") throwing null
pointer exceptions is just too ridiculous. And why should basic things
like getting the XML encoding or the XML version out of an XML header be
so obscure as to require reflection and then have it behave differently
for different implementations; will it be known yet during
startDocument, or only after the first startElement? Will it still be
correct during endDocument. Well that depends on the implementation
doesn't it...
> a time attribute. We let both attributes be strings and use XSD to
> to convert the strings into date types for java code uses. It's a
> pity we have to do this ourselves, but out implementation always works
> while the sun/ibm/apache stuff just doesn't play nicely together.
It's too sad. And that with a plethora of standards, TCKs, and bodies
to govern all this...
> our code, so it doesn't really hurt anything to do this. Plus, you're
> XMLCalendar problems than it will lose in lost performance due to
> String/Date conversions.
Personally I find it all too often frustrating and annoying. It makes
me wonder how XML worship became one of the world's most popular cult
practices. XML is so simple though? Yep, I realize how simple it is
the thousandth time I have to explain the implications of xmlns="abc",
or the ever popular xmlns="', on the rest of the document. That's
right, the elements are implicitly qualified, but no, the attributes are
not. So don't let the lack of element qualification make you think the
element isn't qualified, look up, look way up to see the error in your
thinking. Yes, your global elements declarations in your schema will be
qualified, but no your local elements will not be, unless of course you
declare form="qualified" or elementFormDefault="qualified". And no,
your type names in the schema will not correspond to element names in
your XML. Are you following me still? Where did you get lost? It's all
so simple. Maybe there's something wrong with you? :-P
> Jason Henriksen
Now look what you've done. In sharing your frustrations you've made me
rant! I'll have to add the disclaimer that the opinions I've expressed
are my own not someone else's and that I woke up really early...
> Ed Merks wrote:
>> Will,
>> no reason for any one implementation to assume there it is the one
>> and only implementation of a public abstract class provided by the
>> JDK. All methods should respect the public class' API and should be
>> written only to assume that the public abstract class' method are
>> implemented...
>> Java 5.0 by the more strongly typed methods that use the actual XML
>> Schema appropriate types that weren't available in a 1.4 JDK. Even
>> the types of the methods generated for the XML Schema data types not
>> supported in 1.4 will have changed from java.lang.Object to
>> XMLGregorianCalendar, Duration, or QName...
>>> and the Sun JVM throws the exception.
>>> careful to use XMLCalendar implementations, which leads me to the
>>> question of how best to initialize one.
>>> requires a string. Is there any other way?
>>> XMLTypeFactory.convertDate looks like it should work off a
>>> java.util.Date, but it's deprecated. What's the reason for
>>> deprecation?
>>> Thanks,
>>> Will
Previous Topic:problems with headless invocation of Ecore2GenModel
Next Topic:Loading EMF model instances with different xml namespace prefix
Current Time: Sun Jul 20 09:38:43 EDT 2025
Powered by FUDForum. Page generated in 0.03380 seconds
