Home » Modeling » EMF » derived features with volatile=false, transient=false, changeable=true
derived features with volatile=false, transient=false, changeable=true [message #415338] Wed, 12 December 2007 15:29 Go to next message
Hi.
Are such features working?
I asked on the OCL group, and someone asked, whether such a feature
would work.
I do not see any problem for such a feature. Is there one?
Best, Philipp
> 1. Access to a field, if the getter is overwritten
> > We use OCL to define "derived" attributes, as in Christian Damus's
> > Example. These attributes have derive=true, volatile=true,
> > transient=true, changeable=false, and everything works well.
> > Now, in EMF I can have derived attributes with only derive=true,
> > but volatile=false, transient=false, changeable=false. In these
> > attributes a derived getter will typically read the field.
Does this really work? I would expect this to confuse some parts of the EMF
run-time, that would expect a derived property to be unchangeable. I know
that some corners of the GMF run-time make this assumption.
Re: derived features with volatile=false, transient=false, changeable=true [message #415340 is a reply to message #415338] Wed, 12 December 2007 18:04 Go to previous message
Philipp,
Comments below.
Philipp W. Kutter wrote:
> Hi.
Where you define working how?
> would work.
You need to write the code for the methods.
> Best, Philipp
> the EMF
> know
It's assumed that derived properties are computed from other values, so
they aren't copied, but as part of being computed they could be set and
hence produce notification...
Previous Topic:Notification for eSetResource
Next Topic:[Announce] Joint Eclipse/OMG Symposia
Current Time: Sat Jul 19 19:33:49 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
