Home » Modeling » EMF » generic arguments to eOperations
generic arguments to eOperations [message #415323] Wed, 12 December 2007 08:17 Go to next message
Originally posted by: jaehemail-eclipse.yahoo.co.uk
I ran into a problem while trying to reload one of my models - after some
investigation I found that trying to generate a model from the following
java code(in a project on its own) just didn't work. The problem is
generics in the signature for an eOperation. While trying to generate a
model, or reload, the following error is reported:
The type must be specified for 'IOp.op(values)'
code:
package test.emf.problem;
import java.util.List;
* @model
public interface IOp
* @model
void op(List<Integer> values);
by specifying the parameters for the operation with '@model
parameters="java.util.List"' the model does generate but the generated
implementation just has the vanilla List argument (no parameterised type).
Are there plans to recognise parameterised types any time soon and is
there a way to have it generate the correct implementation signature at
present?
Any help appreciated,
Jae.
Re: generic arguments to eOperations [message #415332 is a reply to message #415323] Wed, 12 December 2007 10:33 Go to previous messageGo to next message
Jae,
This doesn't seem to be handled very gracefully. Using this approach
should work
* @model valuesDataType="java.util.List<java.lang.Integer>"
Please open a bugzilla with this example and I'll try to figure out why
it's handled so poorly...
Jae Hossell wrote:
> some investigation I found that trying to generate a model from the
> following java code(in a project on its own) just didn't work. The
> problem is generics in the signature for an eOperation. While trying
> to generate a model, or reload, the following error is reported:
> code:
> * @model
> * @model
> type). Are there plans to recognise parameterised types any time soon
> and is there a way to have it generate the correct implementation
> signature at present?
> Jae.
Re: generic arguments to eOperations [message #415335 is a reply to message #415332] Wed, 12 December 2007 11:57 Go to previous message
The bug has been added: Bug 212780
cheers,
Jae.
Previous Topic:Generating code without EMF dependencies
Next Topic:Notification for eSetResource
Current Time: Sat Jul 19 21:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.06919 seconds
