Home » Modeling » EMF » autoincremented id
autoincremented id [message #415199] Wed, 05 December 2007 02:44 Go to next message
Originally posted by: marsha.rohrer.swisscom.com
For my GMF editor I want to add a autoincremented id for my Step object.
The step object has a name, which was basically used as ID. Since this
name may contain spaces it is no suitable anymore. My idea is now to have
an additional EAttribute ID for the Step EClass. This id may not be set by
the user but is set automatically.
So in the ecore model I would set the properties, unique ture and
unsettable true. But how can I set the id programmatically? Where do I
have to do this? In the StepItemProvider?
Thanks.
Marsha
Re: autoincremented id [message #415202 is a reply to message #415199] Wed, 05 December 2007 07:02 Go to previous messageGo to next message
Marsha,
It's quite easy to define an EDataType that wraps java.lang.String and
encodes non-NCName characters in some fashion, i.e., you might encode
space as _. and _ as __. Then you can use that as the type of your ID
attribute. This seems better if you know those things are unique within
the resource.
The unique property only has significance for a multi-valued property in
which case is specifies that the same value can't appear more than
once. Unsettable likely doesn't mean what you assume either. It
doesn't mean you can't set it but rather than there is a meaningful
difference between the feature's value being in the default state verses
having been explicitly set to a value that's the same as the default
value, i.e., it adds one additional state to the set of states a feature
can take on. And you don't want to make it unchangeable, since you need
to read it in from a serialization. You don't want to just let the
resource assign an ID for you? If you specialize
XMLResourceImpl.useUUIDs to return true, unique IDs will be generated
for you...
Marsha wrote:
> Hello,
> have an additional EAttribute ID for the Step EClass. This id may not
> be set by the user but is set automatically.
> Thanks.
> Marsha
Re: autoincremented id [message #415205 is a reply to message #415202] Wed, 05 December 2007 07:45 Go to previous messageGo to next message
Hi Ed,
Thank you for your promt answer. I haven't thought of wrapping the
java.lang.String Class yet, but this is a good idea.
I can't find that XMLResourceImpl.useUUIDs in my classes that were
generated with GMF. Do I have to add it? Or is this a configuration of the
genmodel? How do I have to configure my ID EAttribute in that case? The
IDs that get generated are these of the form \\@object.0 etc.?
Thank you.
Marsha
Ed Merks wrote:
> Marsha,
> the resource.
> for you...
> Marsha wrote:
>> Hello,
>> Thanks.
>> Marsha
Re: autoincremented id [message #415206 is a reply to message #415205] Wed, 05 December 2007 07:57 Go to previous messageGo to next message
--------------050302020903080100090008
Marsha,
It looks like this:
protected boolean useUUIDs()
return false;
With this approach, you don't need to have IDs in your model. The
resource will maintain them for you.
Marsha wrote:
> Hi Ed,
> the genmodel? How do I have to configure my ID EAttribute in that
> case? The IDs that get generated are these of the form \\@object.0 etc.?
> Thank you.
> Marsha
> Ed Merks wrote:
>> Marsha,
>> and encodes non-NCName characters in some fashion, i.e., you might
>> encode space as _. and _ as __. Then you can use that as the type of
>> your ID attribute. This seems better if you know those things are
>> unique within the resource.
>> in which case is specifies that the same value can't appear more than
>> verses having been explicitly set to a value that's the same as the
>> default value, i.e., it adds one additional state to the set of
>> states a feature can take on. And you don't want to make it
>> unchangeable, since you need to read it in from a serialization. You
>> don't want to just let the resource assign an ID for you? If you
>> specialize XMLResourceImpl.useUUIDs to return true, unique IDs will
>> be generated for you...
>> Marsha wrote:
>>> Hello,
>>> object.
>>> this name may contain spaces it is no suitable anymore. My idea is
>>> now to have an additional EAttribute ID for the Step EClass. This id
>>> may not be set by the user but is set automatically.
>>> I have to do this? In the StepItemProvider?
>>> Thanks.
>>> Marsha
<html>
<head>
http-equiv="Content-Type">
</head>
Marsha,<br>
<br>
It looks like this:<br>
<blockquote><small>
Re: autoincremented id [message #415219 is a reply to message #415206] Wed, 05 December 2007 11:13 Go to previous messageGo to next message
Hi Ed,
I don't have this method in my code, where to I have to add it?
Marsha
Ed Merks wrote:
> Marsha,
> It looks like this:
> return false;
> Marsha wrote:
>> Hi Ed,
>> case? The IDs that get generated are these of the form \@object.0 etc.?
>> Thank you.
>> Marsha
>> Ed Merks wrote:
>>> Marsha,
>>> Marsha wrote:
>>>> Hello,
>>>> object.
>>>> Thanks.
>>>> Marsha
Re: autoincremented id [message #415220 is a reply to message #415219] Wed, 05 December 2007 11:16 Go to previous message
Marsha,
This method must exist in org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl
and you'd override it in your own derived class to return true. You'd
then need to register your own factory to create your specialized
resource. If you change the GenPackage's Resource Type property to XMI,
the scaffolding would be generated for you. Note that the plugin.xml
registration wouldn't appear unless you delete your MANIFEST.MF and
plugin.xml and regenerate them.
Marsha wrote:
> Hi Ed,
> Thanks
> Marsha
> Ed Merks wrote:
>> Marsha,
>> It looks like this:
>> return false;
>> Marsha wrote:
>>> Hi Ed,
>>> of the genmodel? How do I have to configure my ID EAttribute in that
>>> Thank you.
>>> Marsha
>>> Ed Merks wrote:
>>>> Marsha,
>>>> of your ID attribute. This seems better if you know those things
>>>> are unique within the resource.
>>>> property in which case is specifies that the same value can't
>>>> appear more than once. Unsettable likely doesn't mean what you
>>>> assume either. It doesn't mean you can't set it but rather than
>>>> there is a meaningful difference between the feature's value being
>>>> in the default state verses having been explicitly set to a value
>>>> that's the same as the default value, i.e., it adds one additional
>>>> state to the set of states a feature can take on. And you don't
>>>> want to make it unchangeable, since you need to read it in from a
>>>> serialization. You don't want to just let the resource assign an
>>>> ID for you? If you specialize XMLResourceImpl.useUUIDs to return
>>>> true, unique IDs will be generated for you...
>>>> Marsha wrote:
>>>>> Hello,
>>>>> object.
>>>>> id may not be set by the user but is set automatically.
>>>>> do I have to do this? In the StepItemProvider?
>>>>> Thanks.
>>>>> Marsha
Previous Topic:SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-deserialize then access via *static* SDO API?
Next Topic:Fully qualified package name
Current Time: Sat Jul 19 22:43:25 EDT 2025
Powered by FUDForum. Page generated in 0.04257 seconds
