Home » Modeling » EMF » Save level?
Save level? [message #414998] Tue, 27 November 2007 16:35 Go to next message
Hello.
I defined my model as genmodel file and generated Java source. In application I create my Objects tree and
some of attributes was filed. After that I tried to save model to file. Model was saved but not complete. Save
method which I used:
Resource resource = new ResourceSetImpl().createResource(uri);
Map<String, Object> options = new HashMap<String, Object>();
options.put( XMLResource.OPTION_PROCESS_DANGLING_HREF, XMLResource.OPTION_PROCESS_DANGLING_HREF_RECORD );
EObject toSave = model.getStages().get(0).getActivities().get(0).getTasks().g et(0)
resource.getContents().add(toSave);
try {
resource.save(options);
} catch (IOException ioe) {}
This is example when I saved Task:
<?xml version="1.0" encoding="ASCII"?>
<org.uz.iie.gs.wwPP.eclipse.model:Task xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:org.uz.iie.gs.wwPP.eclipse.model="org.uz.iie.gs.wwPP.eclipse.model " id="TASK_1_1_1"
name="TASK1">
<steps id="STEP_1_1_1_1" name="STEP_1"/>
<steps id="STEP_1_1_1_2" name="STEP_2"/>
</org.uz.iie.gs.wwPP.eclipse.model:Task>
Unfortunately save didn't complete, because Steps contain nested elements which didn't save. When I directly
saved nested ArtifactsList element:
EObject toSave = model.getStages().get(0).getActivities().get(0).getTasks().g et(0).getArtifactsIn();
try {
the result was:
<org.uz.iie.gs.wwPP.eclipse.model:ArtifactsList xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:org.uz.iie.gs.wwPP.eclipse.model="org.uz.iie.gs.wwPP.eclipse.model " id="ARTIFACTS_LIST_IN_1_1_1"
name="In" maxSize="1"/>
What I should change if I want to save complete emf model as xml file? Do save method has possibility to set
level which can be save from emf model?
Tomasz
Re: Save level? [message #415012 is a reply to message #414998] Wed, 28 November 2007 06:57 Go to previous messageGo to next message
Tomasz,
Comments below.
exquisitus wrote:
> Hello.
That makes me wonder about whether you are using containment
references. It's very important that every object as eResource() !=
null. Without that, you'll get exceptions while saving and these
dangling references will disappear.
Another hint to me that you have some dangling reference issues.
> try {
> name="TASK1">
You say "contain" nested elements, but I'll bet the reference isn't
marked as a containment reference, i.e., EReference.containment == true....
> try {
> the result was:
It sounds like you simply intended it to be a containment reference but
didn't mark it that way in the model...
> Best regards,
> Tomasz
Re: Save level? [message #415124 is a reply to message #415012] Fri, 30 November 2007 07:38 Go to previous message
Ed Merks pisze:
> Tomasz,
> Comments below.
> exquisitus wrote:
>> Hello.
>> EObject toSave =
>> try {
>> id="TASK_1_1_1"
>> name="TASK1">
>> EObject toSave =
>> try {
>> the result was:
>> Best regards,
>> Tomasz
Thank you Ed.
Tom
Previous Topic:What techniques are EMF applying to improve performace and reduce memory footprint?
Next Topic:Restrict combo box objects values in properties view to a single resource
Current Time: Sat Jul 19 16:38:26 EDT 2025
Powered by FUDForum. Page generated in 0.03084 seconds
