Home » Modeling » EMF » TransactionalEditingDomain in EMF generated editors
TransactionalEditingDomain in EMF generated editors [message #414759] |
Tue, 20 November 2007 14:42  |
After reading the Workspace Integration example and some posts about use of
the TransactionalEditingDomain, I am still a little unsure about the simples
way to use a TransactionalEditingDomain in generated EMF editors.
Is it indeed as simple as replacing
editingDomain = new AdapterFactoryEditingDomain(adapterFactory,
commandStack, new HashMap<Resource, Boolean>());
with the construction of a TransactionalEditingDomain in the
initializeEditingDomain method?
As I understand it the Workspace Integration example adds support for
multiple editors on the same resource which is not (yet) what I am after.
I need to use the RecordingCommand and for that I need the right
EditingDomain so my naive solution would be to just replace the
editingDomain construction.
Would that work out right?
Hans
Re: TransactionalEditingDomain in EMF generated editors [message #414760 is a reply to message #414759] |
Tue, 20 November 2007 15:06   |
Hi, Hans,
Replacing your editing domain and command stack with their transactional
counterparts is not the whole story but, as you have discovered, the
example editor does more than the bare minimum to demonstrate other
capabilities of the API. Also, it isn't very clear what all of the
customizations in that editor are, as we haven't been able to keep it
up-to-date with changes in the codegen templates.
There are some other considerations, including at least
- replacing the property sheet and its property sources with the
transactional variants from the org.eclipse.emf.transaction.ui
plug-in
- replacing the tree content provider with its transactional variant
from the org.eclipse.emf.transaction.ui plug-in
- (for operation history integration) replacing the the Undo and Redo
actions created by the generated action-bar contributor with the
actions in the org.eclipse.emf.workspace.ui plug-in
The handling of the content and property sheet providers is important for
ensuring that refreshes use the transactional editing domain for read-only
transactions.
The example also tries to simplify the editor by removing all pages but the
default tree view.
So, you might start by progressively replacing the various pieces listed
above and see where that takes you.
On the other hand, if all that you are looking for is to be able to use
RecordingCommand, then perhaps you don't need transactions at all and the
ChangeCommand will work for you? (it similarly uses the ChangeRecorder for
automatic undo/redo)
HTH,
Christian
> of the TransactionalEditingDomain, I am still a little unsure about the
> simples way to use a TransactionalEditingDomain in generated EMF editors.
> Regards,
> Hans
Re: TransactionalEditingDomain in EMF generated editors [message #414763 is a reply to message #414760] |
Tue, 20 November 2007 17:07   |
Thx for the quick and thorough reply, Christian.
I think I will do both (start from the example and also try out the
ChangeCommand) to learn the most.
Maybe a good idea to create a genmodel switch to generate a Transactional
version of the EMF editors?
Hans
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fhveom$ld7$1@build.eclipse.org...
> Hi, Hans,
> plug-in
> transactions.
> the
> default tree view.
> HTH,
> Christian
>> Regards,
>> Hans
Re: TransactionalEditingDomain in EMF generated editors [message #414765 is a reply to message #414763] |
Tue, 20 November 2007 17:53   |
--------------010103000602090500020505
Hans,
Open a bugzilla to ask for the generator property. It's not so likely
we'll get to it any time soon without a contribution but at least we can
record the desire to have it.
> Regards,
> Hans
>> Hi, Hans,
>> plug-in
>> transactions.
>> the
>> default tree view.
>> HTH,
>> Christian
>>> Regards,
>>> Hans
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hans,<br>
<br>
can record the desire to have it.<br>
<br>
<br>
<blockquote cite="mid:fhvlrl$f0g$1@build.eclipse.org" type="cite">
<pre wrap="">Thx for the quick and thorough reply, Christian.
Hans
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@ca.ibm.com"><cdamus@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fhveom$ld7$1@build.eclipse.org">news:fhveom$ld7$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi, Hans,
plug-in
transactions.
the
default tree view.
HTH,
Christian
</pre>
<pre wrap="">After reading the Workspace Integration example and some posts about use
Hans
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010103000602090500020505--
Re: TransactionalEditingDomain in EMF generated editors [message #415108 is a reply to message #414765] |
Thu, 29 November 2007 17:55  |
Just added the enhancement request as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211524
Hans
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fhvoh5$r3k$2@build.eclipse.org...
Hans,
Open a bugzilla to ask for the generator property. It's not so likely we'll
get to it any time soon without a contribution but at least we can record
Hans
Hi, Hans,
plug-in
transactions.
the
default tree view.
HTH,
Christian
Hans
Current Time: Sat Jul 19 18:30:52 EDT 2025
Powered by FUDForum. Page generated in 0.51594 seconds
