Home » Modeling » EMF » OCL query with EDate
OCL query with EDate [message #415097] Thu, 29 November 2007 08:37 Go to next message
Originally posted by: bryan.bulten.ca
I am trying to use OCL for queries in which the application user will pick
a query and enter specific parameters.
For a simple query to find users in the system created after a specified
date,
"self.userAccount->select(creationDate > '???')"
I am unsure how to go about entering a literal for creationDate (type is
EDate).
I've tried:
"self.userAccount->select(creationDate.getTime() > 1234567)"
in an attempt to convert the EDate to a long for comparison in OCL, but am
told that the operation 'getTime' does not exist for type 'EDate'.
I'm new to EMF and OCL, and am not sure if I'm going about this the right
way. Is there a better method/tool for this type of query?
Bryan
Re: OCL query with EDate [message #415100 is a reply to message #415097] Thu, 29 November 2007 09:05 Go to previous messageGo to next message
Hi, Bryan,
OCL doesn't have a representation for date literals. I suggest using a
variable in your expression, for which you provide the date value when
executing the query.
So, you can do the following OCL expression:
self.userAccount->select(creationDate > _date_)
The tricky part comes next :-)
Construct your BooleanOCLCondition with an Environment that has the "_date_"
variable defined and a Query (from OCL API) that has an
EvaluationEnvironment supplying the value for the "_date_" variable, using
the BooleanOCLCondition(Environment,Query,C,PruneHandler) constructor.
Something like this (not real, tested code):
OCL<...> ocl = OCL.newInstance(...);
Environment<...> env = ocl.getEnvironment();
Variable<...> dateVar = env.getOCLFactory().createVariable();
dateVar.setName("_date_");
dateVar.setType(EcorePackage.Literals.EDATE);
env.addElement(dateVar.getName(), dateVar, true);
OCLHelper<...> helper = OCL.createOCLHelper();
helper.setContext(/* "self" type */);
Constraint constraint = helper.parseInvariant(
"self.userAccount->select(creationDate > _date_)");
Query<...> query = ocl.createQuery(constraint);
query.getEvaluationEnvironment().add(dateVar.getName(), theDateValue);
BooleanOCLCondition cond = new BooleanOCLCondition(
env, query, /* "self" type */, PruneHandler.NEVER);
... construct the SELECT statement ---
When you get this working, it will be a great contribution to the OCL Query
Example for the SDK! (hint, hint)
HTH,
Christian
Bryan Bulten wrote:
> Hello,
> date,
> EDate).
> I've tried:
> Bryan
Re: OCL query with EDate [message #415101 is a reply to message #415100] Thu, 29 November 2007 09:07 Go to previous message
Bryan,
I hope your newsreader doesn't do what mine does, which is to show an
underline under the word "date" instead of the leading and trailing
underscore. Imagine <underscore>date<underscore> ...
cW
Previous Topic:recommendation on custom factory methods
Next Topic:Updating custom label text
Current Time: Sat Jul 19 12:26:55 EDT 2025
Powered by FUDForum. Page generated in 0.04217 seconds
