Home » Modeling » EMF » running validation from an application (or a junit test)
running validation from an application (or a junit test) [message #412679] Sun, 02 September 2007 11:02 Go to next message
I was trying to run validation from an application (also tried from a
junit test) using the extlibrary example, with the following code:
EXTLibraryFactory factory = EXTLibraryFactory.eINSTANCE;
Library library = factory.createLibrary();
Book book = factory.createBook();
book.setTitle("foo");
library.getBooks().add(book);
System.out.println("book: " + book);
IBatchValidator validator = (IBatchValidator) ModelValidationService
.getInstance().newValidator(EvaluationMode.BATCH);
IStatus status = validator.validate(library);
System.out.println("result: " + status);
but I get the following error:
Exception in thread "main" java.lang.ExceptionInInitializerError
at
org.eclipse.emf.validation.internal.service.BatchValidator$D efaultRecursiveTraversalStrategy.initDelegates(BatchValidato r.java:338)
at
org.eclipse.emf.validation.internal.service.BatchValidator$D efaultRecursiveTraversalStrategy.startTraversal(BatchValidat or.java:259)
at
org.eclipse.emf.validation.internal.service.BatchValidator.v alidate(BatchValidator.java:169)
at
org.eclipse.emf.validation.internal.service.BatchValidator.d oValidate(BatchValidator.java:137)
at
org.eclipse.emf.validation.internal.service.AbstractValidato r.validate(AbstractValidator.java:141)
at
org.eclipse.emf.validation.internal.service.AbstractValidato r.validate(AbstractValidator.java:120)
at
org.eclipse.emf.examples.extlibrary.tests.EXTLibraryExample. main(EXTLibraryExample.java:74)
at
org.eclipse.emf.validation.internal.EMFModelValidationPlugin .getPluginId(EMFModelValidationPlugin.java:203)
at
org.eclipse.emf.validation.internal.service.TraversalStrateg yManager.initStrategies(TraversalStrategyManager.java:100)
at
org.eclipse.emf.validation.internal.service.TraversalStrateg yManager. <init>(TraversalStrategyManager.java:62)
at
org.eclipse.emf.validation.internal.service.TraversalStrateg yManager. <clinit>(TraversalStrategyManager.java:54)
... 7 more
what am I doing wrong?
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: running validation from an application (or a junit test) [message #412680 is a reply to message #412679] Sun, 02 September 2007 12:00 Go to previous messageGo to next message
Lorenzo,
I don't think the validation framework supports standalone execution.
Are you running this as a JUnit Plugin test?
Lorenzo Bettini wrote:
> Hi
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 7 more
> thanks in advance
> Lorenzo
Re: running validation from an application (or a junit test) [message #412690 is a reply to message #412680] Mon, 03 September 2007 05:23 Go to previous messageGo to next message
Ed Merks wrote:
> Lorenzo,
you're right: if I run it as a Junit Plugin test it runs without
exception (let alone that I still have problems since no constraint is
used, see my other post "problems with validation tutorial").
Re: running validation from an application (or a junit test) [message #655555 is a reply to message #412680] Mon, 21 February 2011 13:15 Go to previous messageGo to next message
I'm just wondering if there is still a limitation on the emf validation framework working in a standalone execution environment i.e. Headless.
When I run my validation code in Eclipse/IBM RSA it runs fine. When I run it headless the validation framework never sets the IStatus to anything but "Status OK: org.eclipse.emf.validation code=10 No constraints were evaluated" The validation is being performed on exactly the same model
The validator itself is just a simple UML Batch validator using IBatchValidator.
Any ideas?
Ronan
Re: running validation from an application (or a junit test) [message #655639 is a reply to message #655555] Tue, 22 February 2011 01:07 Go to previous messageGo to next message
Ronan,
Comments below.
Ronan wrote:
> i.e. Headless.
Stand alone and headless don't mean the same thing. The later is
running an Eclipse/Equinox application without a UI the former is
running directly from some Java class' main() method.
Perhaps something it's relying on is missing. E.g.,
org.eclipse.core.resources I think is necessary.
> IBatchValidator.
> Any ideas?
> Ronan
Re: running validation from an application (or a junit test) [message #655900 is a reply to message #412679] Wed, 23 February 2011 04:12 Go to previous message
My bad Sad Your right I should have said just Headless Smile
Yes I have org.eclipse.core.resources included as a dependency.
With some more debugging we have found that the ClientContext is not getting setup correctly in Headless mode. This means we get no validation rules returned. It looks like perhaps the IBM UMLvalidation code we rely on is creating an EditingDomain that has dependencies on GMF. Obviously this is bad news as GMF has no place in our headless environment. I'll try and follow this up further and report back.
Ronan
Previous Topic:Losing atributes after saving and reopening Dynamic Instances
Next Topic:[CDO] TimeoutRuntime Exception while opening a session
Current Time: Sun Jul 20 09:04:19 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
