Home » Eclipse Projects » Equinox » jboss plugin
jboss plugin [message #40916] Wed, 28 April 2004 18:46 Go to next message
Originally posted by: sg.media-style.removeme.com
Call for contributions.
after bombing this news group and some mailing list with a lot of
question finally I got jboss 3.2.3 running as eclipse 3 m8 plugin.
I had serializing my code to the cvs of jstaff.sf.net, it's still a
moving target and a lot to do but the concept is working.
I would be happy if someone would be interested to join the project to
contribute ideas, knowledge and code. Its open source. :-)
Thanks for the help so far to Ted Stockwell for sample code and Pascal
Rapicault for some pointers.
Greetings
Stefan
Re: jboss plugin [message #40947 is a reply to message #40916] Thu, 29 April 2004 09:12 Go to previous messageGo to next message
Originally posted by: jm.nospam.steranka.com
In article <c6pbrd$d1i$1@eclipse.org>, sg@media-style.removeme.com says...
Can you please post what you did to get JBoss 3.2.3 running under Eclipse 3.0M8?
It's something that I also want to do, but haven't gotten around to it yet.
If you know of any pitfalls or how to make it work, I'd love to read them
and avoid the pitfalls.
Thanks, in advance,
Patrick Steranka
Re: jboss plugin [message #40978 is a reply to message #40947] Thu, 29 April 2004 13:57 Go to previous messageGo to next message
Why not just use JBoss-IDE? It already is a plugin. Lets you
configure severs, start stop and deploy, etc.
On Thu, 29 Apr 2004 09:12:51 -0400, Patrick Steranka
>Thanks, in advance,
>Patrick Steranka
Re: jboss plugin [message #41009 is a reply to message #40978] Fri, 30 April 2004 08:01 Go to previous messageGo to next message
Originally posted by: sg.removeme.media-style.com
Well, i was involved in the jboss ide development. The jboss ide starts
jboss as an external application
in a seperate vm but in debugging mode. See launching applications in
eclipse documentation.
So eclipse and jboss run not in the same vm.
The jstaff plugin run jboss and eclipse in the same vm.
Stefan
3.0M8?
> >Thanks, in advance,
> >Patrick Steranka
Re: jboss plugin [message #41040 is a reply to message #40947] Fri, 30 April 2004 08:02 Go to previous messageGo to next message
it is open source,
actually the code is broken but you can download the code from the cvs.
http://sf.net/projects/jstaff
HTH
Stefan
3.0M8?
> Thanks, in advance,
> Patrick Steranka
Re: jboss plugin [message #41102 is a reply to message #41009] Fri, 30 April 2004 12:03 Go to previous messageGo to next message
Stefan, can you give compare jbos ide and jstaff more in details?
10x,
Sam Mesh - http://openrules.com
Re: jboss plugin [message #41134 is a reply to message #41102] Fri, 30 April 2004 14:02 Go to previous messageGo to next message
What you wish to know excatly?
let me tried it with two sentence.
The jboss ide is an tool that helps you writing and debugging ejb
applications for jboss. The jstaff plugin is a tool that allow you to
writing j2ee Gui's by connecting a internal jboss plugin to a jboss
cluster and so call ejbs in your cluster as they would be in a local vm
similar you do web ui's inside a application server.
Make that any sense to you?
Stefan
Re: jboss plugin [message #41163 is a reply to message #41134] Fri, 30 April 2004 18:10 Go to previous messageGo to next message
Use *live ejbs* in design time aka Java beans in UI designer? Cool :)
Re: jboss plugin [message #41837 is a reply to message #41009] Tue, 04 May 2004 10:09 Go to previous message
Thanks for the info on jstaff plugin.
I'll try both plugins out (jstaff and jboss-ide)
Patrick Steranka
In article <c6tf69$psr$1@eclipse.org>, sg@removeme.media-style.com says...
> Stefan
> 3.0M8?
> > >Thanks, in advance,
> > >Patrick Steranka
Previous Topic:Running the Equinox Runtime standalone with the defaultAdaptor
Next Topic:[classloading] dynamic import / class cast exception
Current Time: Sat Jul 19 14:37:54 EDT 2025
Powered by FUDForum. Page generated in 0.04515 seconds
