Home » Eclipse Projects » SWTBot » NoClassDefFound Error org/hamcrest/Matchers
NoClassDefFound Error org/hamcrest/Matchers [message #40588] Thu, 25 June 2009 15:34 Go to next message
Ok so I updated to the latest version of SWTBot and after updating I
switch all SWTEclipseBot to SWTWorkbenchBot. Anyways when I run the line
below I get a NoClassDefFound Error for org/hamcrest/Matchers
bot.viewByTitle("Welcome").close();
Any help is apperciated.
Re: NoClassDefFound Error org/hamcrest/Matchers [message #40680 is a reply to message #40588] Thu, 25 June 2009 21:00 Go to previous messageGo to next message
You will need to add org.hamcrest as a dependency.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
Re: NoClassDefFound Error org/hamcrest/Matchers [message #40710 is a reply to message #40680] Fri, 26 June 2009 06:49 Go to previous messageGo to next message
I am pretty sure I did that but I will double check.
Jeremy
Re: NoClassDefFound Error org/hamcrest/Matchers [message #40740 is a reply to message #40680] Fri, 26 June 2009 09:19 Go to previous messageGo to next message
I checked and I do have org/hamcrest as a dependency.
Re: NoClassDefFound Error org/hamcrest/Matchers [message #40770 is a reply to message #40740] Fri, 26 June 2009 10:24 Go to previous messageGo to next message
What version of swtbot are you on ?
Do you have the following hamcrest plugins installed
org.hamcrest_1.1.0.v20090501071000.jar
org.hamcrest.text_1.1.0.v20090501071000.jar
org.hamcrest.integration_1.1.0.v20090501071000.jar
org.hamcrest.core_1.1.0.v20090501071000.jar
org.hamcrest.library_1.1.0.v20090501071000.jar
Ketan
Re: NoClassDefFound Error org/hamcrest/Matchers [message #40799 is a reply to message #40770] Fri, 26 June 2009 11:11 Go to previous message
I am on SWTBot 358 and I do have those hamcrest plugins installed.
Jeremy
Previous Topic:This is a great tool.
Next Topic:MultiPageEditor Support
Current Time: Sun Jul 20 06:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.03509 seconds
