Home » Eclipse Projects » Nebula » Gallery Widget + ISelectionProvider
Gallery Widget + ISelectionProvider [message #40227] Tue, 18 September 2007 23:57 Go to next message
Originally posted by: swetha.yahoo.co.in
I have a Rcp view which is developed using Gallery Widget... I want this
to be registered as a selection provider.. For this I need to implement
the ISelectionProvider...
getSite().addSelectionProvider(ISelectionProvider)....just like
TreeViewer..
How can implement ISelectionProvider for the gallery.. Is this posiible?
Can anyone point me in the right direction?
Swetha
Re: Gallery Widget + ISelectionProvider [message #40601 is a reply to message #40227] Sat, 29 September 2007 12:50 Go to previous messageGo to next message
You can implement ISelectionProvider for the Gallery, I did it actually.
But my case is more complicated than yours because my selection provider
can use selection from several widgets, which are defined through
extension points.
You will have to write yourself a simpler implementation. Just implement
all methods of ISelectionProvider in a new class.
If you want to see how I did this, you can look at :
http://sharemedia.svn.sourceforge.net/viewvc/sharemedia/trun k/org.sharemedia.core/src/org/sharemedia/gui/views/AbstractS electionProviderViewPart.java?view=log
http://sharemedia.svn.sourceforge.net/viewvc/sharemedia/trun k/org.sharemedia.core/src/org/sharemedia/gui/views/library2/ LibraryView2.java?view=log
and
http://sharemedia.svn.sourceforge.net/viewvc/sharemedia/trun k/org.sharemedia.library.view.gallery/src/org/sharemedia/gui /libraryviews/GalleryLibraryView.java?view=log
This could be the beginning of the gallery viewer :-)
Nicolas
Swetha a écrit :
> this to be registered as a selection provider.. For this I need to
> implement the ISelectionProvider...
> TreeViewer..
> Swetha
Re: Gallery Widget + ISelectionProvider [message #44784 is a reply to message #40601] Thu, 13 December 2007 23:01 Go to previous message
BTW,
I have posted a patch for an implementation of a JFace Viewer for
Gallery, in the style of TreeViewer. I also included an adapter that
lets you use Gallery with an IStructuredContentProvider if you don't
care about groups. This code inherits the ISelectionProvider
implementation from AbstractTreeViewer. You might want to follow the bug:
212071: GalleryTreeViewer
https://bugs.eclipse.org/bugs/show_bug.cgi?id=212071
Peter
Re: Gallery Widget + ISelectionProvider [message #585044 is a reply to message #40227] Sat, 29 September 2007 12:50 Go to previous message
extension points.
and
Nicolas
Swetha a écrit :
> TreeViewer..
> Swetha
Re: Gallery Widget + ISelectionProvider [message #586975 is a reply to message #40601] Thu, 13 December 2007 23:01 Go to previous message
BTW,
Peter
Previous Topic:CDateTime stable release date
Next Topic:Horisontal scrolling during column draging
Current Time: Sat Jul 19 06:07:52 EDT 2025
Powered by FUDForum. Page generated in 0.25125 seconds
