Home » Eclipse Projects » SWTBot » Is SWTbot supposed to work with Eclipse 3.3.2?
Is SWTbot supposed to work with Eclipse 3.3.2? [message #40292] Wed, 24 June 2009 09:34 Go to next message
I'm completely new to SWTbot, and trying to install it under Eclipse 3.3.2.
The installation itself seems to work (using a locally unzipped
swtbot-update-site-2.0.0.358-dev.zip). I then created a test plug-in
project, added org.eclipse.swtbot.eclipse.finder,
org.eclipse.swtbot.swt.finder and org.junit4 as dependencies, and pasted
the TestSampleDialog class from
http://wiki.eclipse.org/SWTBot/UsersGuide#Getting_started_wi th_SWTBot in
there. The class compiled OK (although with many deprecation warnings),
but I don't know how to run it. I don't have the "SWTbot Test" entry in
my "Run as" menu.
I tried the exact same procedure under an Eclipse 3.4, and there I have
the "SWTbot Test" entry and can run the class.
Am I doing something wrong, or is SWTbot not supposed to work under
Eclipse 3.3?
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40322 is a reply to message #40292] Wed, 24 June 2009 12:33 Go to previous messageGo to next message
Eclipse 3.3 used to work fine about 6 months ago.
The only things that may not work are:
- support for any additional widgets or swt styles that were
introduced in eclipse 3.4. You may have to comment out such api.
- bundle manifests that have a minimum version requirement on bundles
that ship with eclipse 3.4. They may possibly work with eclipse 3.3.
Try checking out the swtbot source code from trunk and see what does not
compile and/or breaks and file a bug report. If it's not too much work
for me I'll try to provide some form of backport to 3.3.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 24/6/09 19:04, Pierre-Charles David wrote:
> my "Run as" menu.
> Eclipse 3.3?
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40352 is a reply to message #40322] Thu, 25 June 2009 07:37 Go to previous messageGo to next message
Is there an old release I can download which worked with 3.3? I don't
see any on the website.
> - support for any additional widgets or swt styles that were introduced
I'm not sure if/when I will have the time to do that, sorry.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40382 is a reply to message #40352] Thu, 25 June 2009 07:42 Go to previous messageGo to next message
http://download.eclipse.org/technology/swtbot/archives/.
Ketan
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40412 is a reply to message #40382] Thu, 25 June 2009 09:48 Go to previous messageGo to next message
Thanks for the link. I don't see the dates corresponding to the
versions, and even the oldest available (2.0.0.204-dev) only contains
directories for ganymede and galileo. No mention of Europa.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40441 is a reply to message #40412] Thu, 25 June 2009 09:49 Go to previous messageGo to next message
I guess your best bet is to get things from
http://sf.net/projects/swtbot or move to eclipse 3.4 even better 3.5 :)
Ketan
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40472 is a reply to message #40441] Thu, 25 June 2009 11:09 Go to previous messageGo to next message
I can't move to 3.4 or later, but I think I'll try the sf.net version.
Thanks.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #40503 is a reply to message #40472] Thu, 25 June 2009 11:23 Go to previous messageGo to next message
> Thanks.
I only tested the TestSampleDialog class, but I confirm that at least on
this case, version net.sf.swtbot.eclipse-1.2.0.921 from the URL above
works with Eclipse 3.3.2. I had to do the following changes to the code
of the sample test case:
- adjust the plugin dependencies and imports to use the net.sf packages;
- add "throws WidgetNotFoundException" to both test methods to make it
compile;
- remove the following section from the testCreateJavaProjet test case:
//Click Next button
bot.button("Next >").click();
bot.sleep(500);
It seems the projectSelectionTree.select("Java Project"); above
already advances to the next (and last) wizard page.
Thanks for your help.
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #484728 is a reply to message #40503] Tue, 08 September 2009 18:16 Go to previous messageGo to next message
>> Thanks.
> compile;
> //Click Next button
> bot.sleep(500);
Can I do the following. I have an eclipse 3.3.2 RCP application.
I am developing it on Eclipse 3.5 and have my target application set to
a subset of 3.3.2 plugins. I added the sf.net plugins above. But I get
the following exception at the end of this post. I see that it is
recommended to add org.eclipse.swtbot.eclipse.core. However, if I add
that, then it depends on org.eclipse.core.runtime; version="3.4.0". But
the target needs to have v3.3.2. Does this have a chance of working?
java.lang.RuntimeException: Application
"org.eclipse.swtbot.eclipse.core.swtbottestapplication" could not be
found in the registry. The applications available are:
org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.equinox.app.error,
net.sf.swtbot.eclipse.ui.swtbottestapplication,
org.eclipse.ant.core.antRunner,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.legacytestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.pde.build.Build, org.eclipse.jdt.core.JavaCodeFormatter.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:98)
at
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:112)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:54)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
at
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #484968 is a reply to message #484728] Wed, 09 September 2009 22:43 Go to previous messageGo to next message
Yes, I think this may just work. Some background:
'org.eclipse.swtbot.eclipse.core' contains the application that
bootstraps swtbot for execution -- which is why it is required in the
target platform. There is a similar plugin in the old swtbot version as
well.
So here's what you may try:
- checkout swtbot source from eclipse.org.
- change the org.eclipse.swtbot.eclipse.ui to launch
net.sf.swtbot.eclipse.ui.swtbottestapplication. You'll notice that this
is listed in the available applications in the error message.
- build swtbot with the change and give it a spin.
Drop in a note if that does not work, and I'll tell you a not so
userfriendly workaround.
Ketan
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #485261 is a reply to message #484968] Thu, 10 September 2009 22:16 Go to previous messageGo to next message
> well.
I followed the build instructions and renamed my
eclipse-modeling-galileo-win32.zip to eclipse-SDK-3.5-win32.zip so that
it appeared to work with the ant scripts. It looked like it built
successfully, passed 5 tests, but had an error on one test:
....\org.eclipse.swtbot.relen
g\artifacts\tests\org.eclipse.swtbot.swt.finder.test\junit\x ml\TEST-org.eclipse.
swtbot.swt.finder.SWTBot2Test.xml is empty.
[java] [junitreport] This can be caused by the test JVM exiting
unexpectedly
I did the following:
- made the change in the Activator to change the APPLICATION_ID
- rebuilt
- confirmed the change was in the zip file under artifacts
- took the org.eclipse.swtbot.eclipse-2.0.0.394-dev-e35.zip file's
plugins and put them in the Eclipse 3.3 target platform
- tried to run a simple swtbot test.
When running the test, I get the same error:
Application "org.eclipse.swtbot.eclipse.core.swtbottestapplication"
could not be found in the registry.
Is there something I am doing wrong?
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #485266 is a reply to message #485261] Fri, 11 September 2009 00:37 Go to previous messageGo to next message
I should have phrased it correctly.
Drop in the swtbot plugins from sf.net into your target -- the sf.net
stuff needs no change.
The eclipse.ui plugin sits in your IDE -- The artifacts that you build
are to be installed in your IDE. This ensures that it launches the
Ketan
> - rebuilt
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #485711 is a reply to message #485266] Mon, 14 September 2009 11:19 Go to previous messageGo to next message
Ketan, thanks. That did work. So I ran a simple test on the target
eclipse 3.3.2 target platform. My next step was to create the simple
rcp mail product. If I launch the test as an application, it runs
the 3.3.2 eclipse IDE. When I change the launcher to select a product
I get an error that the product cannot be found. Is there another
change I need to make to get this to work?
Re: Is SWTbot supposed to work with Eclipse 3.3.2? [message #486047 is a reply to message #485711] Wed, 16 September 2009 01:16 Go to previous message
Ketan, I would still be interested in the answer, but I decided to
convert my RCP app to 3.5. I was able to launch the product with
the SWT Launcher and run it through a few button clicks and tree
selections. I really like the work you've done.
Previous Topic:Key Press: Enter
Next Topic:Building an RCP application including swtbot tests
Current Time: Sat Jul 19 05:31:05 EDT 2025
Powered by FUDForum. Page generated in 0.06595 seconds
