Home » Modeling » EMF » DeleteCommand on top level resource contents
DeleteCommand on top level resource contents [message #401427] |
Mon, 29 May 2006 18:11  |
I am trying to make DeleteCommand ( RemoveCommand ) executable on resource
contents. My editor shows a list of top level eobjects in the resource. When
I right-click on an object, I see "delete" command grayed-out. I think, if
the parent is not an EObject, it becomes an Unexecutable command. Is there a
way to enable this command on top level eobjects.
thanks,
Bora
Re: DeleteCommand on top level resource contents [message #401509 is a reply to message #401430] |
Sat, 03 June 2006 16:19   |
Thanks Ed,
that was my original solution. Is there a specific reason, why emf doesn't
allow this command on resources? If not, do you plan to provide a
ResourceItemProvider that supports it?
thanks again,
Bora
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e5g5le$l5l$2@utils.eclipse.org...
> Bora,
> You could specialize the ResourceItemProvider to do this.
> Baybora Aksoy wrote:
>> Hi,
>> resource contents. My editor shows a list of top level eobjects in the
>> resource. When I right-click on an object, I see "delete" command
>> grayed-out. I think, if the parent is not an EObject, it becomes an
>> Unexecutable command. Is there a way to enable this command on top level
>> eobjects.
>> thanks,
>> Bora
Re: DeleteCommand on top level resource contents [message #401511 is a reply to message #401509] |
Sun, 04 June 2006 07:56  |
--------------050505020400050102080306
Bora,
If you allow a delete, it means you likely will end up with an empty
resource. Then there would be the expectation that you could create a
new object, but since the root can allow any EObject, it's hard to offer
useful suggestions without offering to create any type of EObject
possible. We could make it easier by having the command support
factored in to the resource item provider but not yet enabled...
> Thanks Ed,
> thanks again,
> Bora
>> Bora,
>>> Hi,
>>> eobjects.
>>> thanks,
>>> Bora
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Bora,<br>
<br>
offer useful suggestions without offering to create any type of EObject
factored in to the resource item provider but not yet enabled...<br>
<br>
<br>
<blockquote cite="mide5sqf1$j9t$1@utils.eclipse.org" type="cite">
<pre wrap="">Thanks Ed,
thanks again,
Bora
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:e5g5le$l5l$2@utils.eclipse.org">news:e5g5le$l5l$2@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Bora,
</pre>
<pre wrap="">Hi,
eobjects.
thanks,
Bora
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050505020400050102080306--
Current Time: Sat Jul 19 13:45:42 EDT 2025
Powered by FUDForum. Page generated in 0.03827 seconds
