Home » Eclipse Projects » DTP » Reusing / extending the DTP SQL parser
Reusing / extending the DTP SQL parser [message #39989] Tue, 18 December 2007 08:10
Originally posted by: cfondacci.free.fr
I would like to re-use the SQL parser from the data tools platform in a
plugin i am developing for implementing color highlighting and SQL proposals
in a custom SQL editor view.
But I am a bit lost in the DTP plugin ecosystem :
After analyzing the DTP sources, I have found several parsers :
- The SQL parser from "org.eclipse.datatools.sqltools.sql.parser" which
seems to be a parser entry point, according to the javadoc
- The SQL parser from "org.eclipse.datatools.sqltools.parsers.sql" which
seems to be a different parser using lpg, but which has a very poor
documentation
- The SQLQueryParser from "org.eclipse.datatools.sqltools.parsers.sql.query"
which has a very poor documentation.
I cannot find out which parser is used when, and which one I should use
though. I have not been able to locate the SQL editor view in the DTP
plugins which would have given me a good entry point in the source code.
Could someone point me out some links / documentation on this and/or tell me
which plugins I should take as dependencies to implement my SQL editor view
Is there a plugin dependency graph available out there ?
Thank you very much.
Christophe.
Previous Topic:Ping Failed Derby Connection
Next Topic:Reusing / extending the DTP SQL parser
Current Time: Sat Jul 19 11:13:22 EDT 2025
Powered by FUDForum. Page generated in 0.03288 seconds
