Missing resource for XSDWildCard [message #398466] |
Fri, 10 February 2006 16:18  |
I have a CreateChildCommand for a New WildCard. When i try to call the getImage method, it gives an exception:
The image resource 'full/obj16/XSDWildcard' could not be located
at org.eclipse.emf.common.EMFPlugin.delegatedGetImage(EMFPlugin .java:323)
at org.eclipse.emf.common.EMFPlugin.getImage(EMFPlugin.java:266 )
at org.eclipse.xsd.provider.XSDItemProviderAdapter.getCreateChi ldImage(XSDItemProviderAdapter.java:960)
at org.eclipse.emf.edit.command.CreateChildCommand.getImage(Cre ateChildCommand.java:334)
I'm using the emf standalone integration build
emf-sdo-xsd-Standalone-I200602090000
I looked inside the emf.edit zip file and there are no images named XSDWildCard. There's only XSDWildCardAttribute and XSDWildCardElement
Re: Missing resource for XSDWildCard [message #398504 is a reply to message #398498] |
Mon, 13 February 2006 13:11   |
When s is an instance of XSDParticleImpl in the following code the error occurs. Specifically, when I trace into it, the error occurs on the instanceof ccc with the label "New Wildcard"
XSDConcreteComponent s = (XSDConcreteComponent)((DefaultMutableTreeNode)selectedNode.getParent()).getUserObject();
ItemProviderAdapter sipa = (ItemProviderAdapter)m_ipaf.createAdapter(s);
Collection sd = sipa.getNewChildDescriptors(s, m_editingDomain, null);
if(sd.size() > 0) {
JMenu newSibling = new JMenu("New Sibling");
Iterator iter = sd.iterator();
CommandParameter cp = null;
while (iter.hasNext()) {
cp = (CommandParameter)iter.next();
CreateChildCommand ccc = new CreateChildCommand(m_editingDomain, s, cp.getEStructuralFeature(), cp.getEValue(), cd, ipa);
Object image = ccc.getImage();
Re: Missing resource for XSDWildCard [message #398506 is a reply to message #398504] |
Mon, 13 February 2006 13:36   |
Frank,
Given that a particle can't exist without a child element, wildcard, or
model group, I expect the particle and its child to be created
simultaneously as our sample editor does. Do you have code that creates
a "bare" particle? I don't think that will work so well and we'd never
expect to find a model in this state...
>if(sd.size() > 0) {
Re: Missing resource for XSDWildCard [message #398513 is a reply to message #398512] |
Mon, 13 February 2006 14:42   |
--------------040206070108040800070400
Frank,
If the particle has an element as the child, it can't also have a
wildcard as the child, so creating a child wildcard is not making much
sense. I really need a meaning set of steps to reproduce your problem
or I'll be forced to return it. After all, if I can't make the problem
happen, I won't know if any change I make fixes it. I could blindly add
more cases to the following to handle XSDParticle and XSDAttributeUse,
but I need to be sure that makes sense and fixes a meaningful problem.
private String getQualifier(Object parent, EReference feature,
Object child)
* else if (child instanceof XSDWildcard)
if (parent instanceof XSDAttributeGroupDefinition ||
parent instanceof XSDComplexTypeDefinition)
qualifier = "attribute";
else if (parent instanceof XSDModelGroup)
qualifier = "element";
frank wrote:
>No, the particle has a element as a child
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Frank,<br>
<br>
add more cases to the following to handle XSDParticle and
XSDAttributeUse, but I need to be sure that makes sense and fixes a
meaningful problem.<br>
<blockquote><small>private String getQualifier(Object parent,
EReference feature, Object child)</small><br>
<small>{</small><br>
<small> ///</small><br>
<br>
<b><small> else if (child instanceof XSDWildcard)</small><br>
<small> {</small><br>
<small> if (parent instanceof XSDAttributeGroupDefinition ||</small><br>
<small> parent instanceof XSDComplexTypeDefinition)</small><br>
<small> qualifier = "attribute";</small><br>
<small> }</small><br>
<small> else if (parent instanceof XSDModelGroup)</small><br>
<small> qualifier = "element";</small><br>
<small> }</small></b><br>
</blockquote>
<br>
<br>
frank wrote:
<blockquote
cite="mid30484895.1139857684445.JavaMail.root@cp1.javalobby.org"
type="cite">
<pre wrap="">No, the particle has a element as a child
</pre>
</blockquote>
<br>
</body>
</html>
--------------040206070108040800070400--
Re: Missing resource for XSDWildCard [message #734884 is a reply to message #734878] |
Mon, 10 October 2011 05:41  |
Vinay,
I don't know anything about creating an exe.
On 10/10/2011 11:25 AM, vinny503 wrote:
> Hi
> I am able to create a working exe file of my plugin project.
> But when I try to run it in another PC, I found the Runtime Exception error.
> Please find the attached error text file.
> Regards,
> Vinay
FUDForum. Page generated in 0.05918 seconds
