Minimizing RCP App to System Tray [message #397369] |
Mon, 29 November 2004 23:11  |
Originally posted by: abhay.csdotbu.edu
Hi All,
I am trying to figure out how I can get rid of the application button from
taskbar when it is minimized. I'd like to have an icon in system tray when
it is minimized.
I did play with suggestion mentioned in
http://dev.eclipse.org/newslists/news.eclipse.platform/msg27 866.html. and I
was able to add a system tray icon and get events from it. However, I have
no idea how I can remove the application from taskbar and hide it on
"Minimize".
I'd appreciate any help/hits.
Abhay
Re: Minimizing RCP App to System Tray [message #436114 is a reply to message #436108] |
Wed, 31 August 2005 05:35  |
Originally posted by: mail4zlq.gmail.com
Donot forget to share the way after you got it :-)
> Abhay ha scritto:
>> Thanks Stefan,
>> I've downloaded the source and trying to figure out how it is working.
>> Looks
>> like you have got a mix of SWT/AWT/Swing.
>> I am pretty new to Eclipse and RCP, it'll probably take me a while to
>> get a
>> grip. :-)
>> Thanks
>> Abhay
>> "Stefan Ukena" <7ukena@informatik.uni-hamburg.de> wrote in message
>> news:cohj9t$l5s$1@www.eclipse.org...
>>> Hi Abhay,
>> when
>>>> it is minimized.
>>> Have a look at Bibster (bibster.sf.net). It's a Eclipse-based P2P
>>> bibliography database that has the option to minimize to the systray.
>>> After you close the application it asks you whether it should run in the
>>> background. If you choose "yes" the window will be removed from the
>>> taskbar but the systray-icon will remain. Source is available via CVS.
>>> Hope this helps,
>>> Stefan
> Hi Abhay,
> please can you tell me how you have accomplished your problem?
> My primary doubt is how hide the parent shell and avoid memory leak. The
> solution wrotten by ]-[appy seems to lead there.
> Thanks in advance,
> Pietro
FUDForum. Page generated in 0.04123 seconds
