Home » Eclipse Projects » Rich Client Platform (RCP) » How to show Workspace Launcher on Startup ??
How to show Workspace Launcher on Startup ?? [message #397479] Tue, 30 November 2004 09:39 Go to next message
I am developing a RCP Product/Application. It is running fine, but i got a
little problem.
On Startup workspace directory is always created in directory application
is started from.
For multi user support i would like to have the Workspace chooser dialog
from standart eclipse, so i can create active workspace whereever i want.
Is there any way, or better what do i have to do to user Workspace
prompter.
thx
Dennis
Re: How to show Workspace Launcher on Startup ?? [message #397687 is a reply to message #397479] Tue, 30 November 2004 21:09 Go to previous messageGo to next message
It's not too hard to add this to your application. The catch is that the
classes that provide the prompting in the IDE are internal. I suggest
that you copy the interesting function into your own prompter.
Have a look at IDEApplication, and notice that before the workbench
advisor is created, the workspace is configured. Use this same pattern
and use Platform.getInstanceDataLocation() to get/set the workspace
location.
Jean-Michel
Dennis wrote:
> a little problem.
> application is started from.
> prompter.
> thx
> Dennis
Re: How to show Workspace Launcher on Startup ?? [message #397703 is a reply to message #397687] Wed, 01 December 2004 07:46 Go to previous messageGo to next message
I already tried sth like that. Right after creating Display before
workbench is created in my IPlatformRunnable class i tried to set instance
Directory.
All i got was an exception. Perhaps anyone else tried this ?
my run methode :
Display display = PlatformUI.createDisplay();
Location instanceLoc = Platform.getInstanceLocation();
instanceLoc.release();
URL url = promptForInstanceLoc(display);
if (url == null) {
return IPlatformRunnable.EXIT_OK;
instanceLoc.setURL(url, true);
try {
int code = PlatformUI.createAndRunWorkbench(display,
new BXTPWorkbenchAdvisor());
// exit the application with an appropriate return code
return code == PlatformUI.RETURN_RESTART ? EXIT_RESTART :
EXIT_OK;
} finally {
if (display != null) {
display.dispose();
private URL promptForInstanceLoc(Display display) {
Shell shell = new Shell(display);
DirectoryDialog dialog = new DirectoryDialog(shell);
dialog.setText("Select Workspace Directory");
dialog.setMessage("Select the workspace directory to use.");
String dir = dialog.open();
shell.dispose();
try {
return dir == null ? null : new File(dir).toURL();
} catch (MalformedURLException e) {
return null;
and the exception :
!ENTRY org.eclipse.osgi Nov 30, 2004 17:05:11.432
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Cannot change the location once it is set.
at
org.eclipse.core.runtime.adaptor.BasicLocation.setURL(BasicL ocation.java:116)
at
com.bredexsw.bxtp.client.gui.plugin.BXTPLauncher.run(BXTPLau ncher.java:53)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
> location.
> Cheers,
> Jean-Michel
> Dennis wrote:
>> Hi,
>> a little problem.
>> prompter.
>> thx
>> Dennis
Re: How to show Workspace Launcher on Startup ?? [message #398211 is a reply to message #397703] Sun, 05 December 2004 21:19 Go to previous message
This is because when you started your application you specified a value
for the workspace (this is in one of the tab of the "eclipse application
launchers"). To avoid the problem replace the value by "@noDefault".
PaScaL
Dennis wrote:
> instance Directory.
> my run methode :
> if (url == null) {
> try {
> EXIT_OK;
> } finally {
> display.dispose();
> shell.dispose();
> try {
> return null;
> and the exception :
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
>> the classes that provide the prompting in the IDE are internal. I
>> suggest that you copy the interesting function into your own prompter.
>> location.
>> Cheers,
>> Jean-Michel
>> Dennis wrote:
>>> Hi,
>>> got a little problem.
>>> dialog from standart eclipse, so i can create active workspace
>>> whereever i want.
>>> prompter.
>>> thx
>>> Dennis
Previous Topic:Job API: Progress Monitor doesn't work propably
Next Topic:RCP Coolbar Dropdown menu
Current Time: Sun Jul 20 05:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.03791 seconds
