Home » Eclipse Projects » SWTBot » Bug in version 2.0.0.329 ?
Bug in version 2.0.0.329 ? [message #37740] Fri, 29 May 2009 10:35 Go to next message
since i have installed the new bot version 2.0.0.329, a simple button
click doesn't funktion any more :-( (e.g. bot.button("bla").click()).
I have reset to the older version (.187), and it functions ok as before ...
Is it a bug, or i made something wrong by update?
This is the exception of .329:
org.eclipse.swtbot.swt.finder.widgets.SWTBotButton.click()Lo rg/eclipse/swtbot/swt/finder/widgets/SWTBotButton;
java.lang.NoSuchMethodError:
at
de.cenit.eb.sm.finca.gui.test.serverconfperspective.TestsFor PluginConfigurationView.testInitButtonsAndMenues(Unknown
Source)
at
org.eclipse.swtbot.swt.finder.SWTBotTestCase.runBare(SWTBotT estCase.java:228)
at
org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:350)
at
org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:208)
at
org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .runTests(UITestApplication.java:190)
at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
Re: Bug in version 2.0.0.329 ? [message #37834 is a reply to message #37740] Fri, 29 May 2009 13:34 Go to previous messageGo to next message
No clue what's wrong here.
Are you able to run from the IDE? Did you setup your headless
environment correctly?
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 29/5/09 20:05, Pavel Cybulskij wrote:
> Hello,
> at
> Source)
> at
> at
> at
> at
> at
Re: Bug in version 2.0.0.329 ? [message #38381 is a reply to message #37834] Mon, 08 June 2009 10:17 Go to previous messageGo to next message
Hello Ketan,
it's me again with my Problem in SWTBotButton.click().
I'm starting swtbot always via ant script. I have already updated to
version .340 (inclusive "Headless Testing Framework"), but the problem
remains the same! :-(
Funnily enough the fact, that ONLY the method button("bla").click()
doesn't function in versions .329 and .340 (it throws still Exception
'NoSuchMethodError'). The other methods of button (e.g. .getText() or
setFocus() function well in new versions!) In v.187 ALL functions are OK!
HELP please!!! :-)
Do you have any documentation for swtbot? i didn't found it on your site
Bye,
Pavel
Re: Bug in version 2.0.0.329 ? [message #38897 is a reply to message #38381] Mon, 15 June 2009 04:51 Go to previous messageGo to next message
There may be no binary compatibility between those two versions, are you
running the same binaries of your source against different versions of
swtbot without recompiling them ?
If your source builds fine then it should execute fine unless the
binaries being used are different.
Ketan
On 8/6/09 19:47, Pavel Cybulskij wrote:
> Hello Ketan,
> remains the same! :-( Funnily enough the fact, that ONLY the method
> button("bla").click() doesn't function in versions .329 and .340 (it
> throws still Exception 'NoSuchMethodError'). The other methods of button
> (e.g. .getText() or setFocus() function well in new versions!) In v.187
> HELP please!!! :-)
> Bye,
> Pavel
Re: Bug in version 2.0.0.329 ? [message #39543 is a reply to message #38897] Fri, 19 June 2009 07:10 Go to previous messageGo to next message
Finally i have solved this problem! All i needed was 'clear' by ant
relaunch. :-)
Re: Bug in version 2.0.0.329 ? [message #39606 is a reply to message #39543] Fri, 19 June 2009 07:57 Go to previous messageGo to next message
Do you mean the -clear command line arg ? I'd recommend using a fresh
workspace and a fresh eclipse install for every new execution.
Ketan
> relaunch. :-)
>> you running the same binaries of your source against different
>> versions of swtbot without recompiling them ?
Re: Bug in version 2.0.0.329 ? [message #39637 is a reply to message #39606] Fri, 19 June 2009 08:12 Go to previous message
i mean clear in Ant Build in eclipse (that i use):
Run/External Tools Config/Ant Build/myStartInitFile -> targets/clean ...
Previous Topic:timing difficulties resolved by sleep -- is there a better way ?
Next Topic:tables in views
Current Time: Sat Jul 19 19:23:24 EDT 2025
Powered by FUDForum. Page generated in 0.06179 seconds
