Home » Archived » Visual Editor (VE) » VE1.0M1 problems with GridBagLayout
VE1.0M1 problems with GridBagLayout [message #39009] Wed, 26 May 2004 16:20 Go to next message
I have just installed VE1.0M1. I defined a panel with a GridBagLayout and
placed a Swing Component on that panel. Now I'm wondering why for that
Swing component the constraint can't be changed on the properties tab. Is
this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39042 is a reply to message #39009] Wed, 26 May 2004 16:30 Go to previous messageGo to next message
Originally posted by: myersj.nospam.us.ibm.com
Are you expanding the contstraint property on the Properties view?
Which particular constraint field can't you set?
You might also want to look at the Customize Layout window for easier
manipulation of a component's constraints.
- Jeff
> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39069 is a reply to message #39042] Wed, 26 May 2004 16:31 Go to previous messageGo to next message
Er, whoops, it's still called the Alignment Window in M1, not Customize
Layout. ;)
- Jeff
Jeff Myers wrote:
> Are you expanding the contstraint property on the Properties view? Which
> - Jeff
>> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39095 is a reply to message #39069] Wed, 26 May 2004 16:45 Go to previous messageGo to next message
Hi Jeff,
yes, I tried to expand the constraint property on the Properties view by
clicking on the +, but it was not expanded. I wanted to change the fill,
the weightx and weighty property but was not allowed to do it. What's
wrong, any idea?
exqusitus
> Layout. ;)
> - Jeff
> > - Jeff
> >> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39126 is a reply to message #39095] Wed, 26 May 2004 17:01 Go to previous messageGo to next message
Let me guess, you're running Eclipse on Linux GTK? The +/- buttons on
the property sheet don't work due to a nasty SWT/GTK bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38855
Unfortunately until it's fixed, you'll need to edit the weights from the
source. The fill property can be changed in the alignment dialog.
Please consider adding a comment to that bugzilla bug, stating your OS
version and gtk level, so we'll have one more voice stating that it
doesn't work for them.
- Jeff
exquisitus wrote:
> Hi Jeff,
> wrong, any idea?
> exqusitus
>>Layout. ;)
>> - Jeff
>>> - Jeff
>>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39157 is a reply to message #39126] Wed, 26 May 2004 16:59 Go to previous messageGo to next message
Hi Jeff,
great guess! You're absolutely right. I'm using Linux GTK.
Although my problem is not fixed, I will add a comment to the bugzilla bug
you've mentioned.
thanks,
exquisitus
> - Jeff
> exquisitus wrote:
> > Hi Jeff,
> > wrong, any idea?
> > exqusitus
> >>Layout. ;)
> >> - Jeff
> >>> - Jeff
> >>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #39187 is a reply to message #39126] Wed, 26 May 2004 17:17 Go to previous message
Actually there's a keyboard shortcut available. Select the constraint
property on the property sheet, and press "Shift +" This will expand the
property sheet item. Pressing the "-" key will collapse the item.
- Jeff
> - Jeff
> exquisitus wrote:
>> Hi Jeff,
>> wrong, any idea?
>> exqusitus
Re: VE1.0M1 problems with GridBagLayout [message #590817 is a reply to message #39009] Wed, 26 May 2004 16:30 Go to previous message
- Jeff
> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590838 is a reply to message #39042] Wed, 26 May 2004 16:31 Go to previous message
Layout. ;)
- Jeff
> - Jeff
>> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590848 is a reply to message #39069] Wed, 26 May 2004 16:45 Go to previous message
Hi Jeff,
wrong, any idea?
exqusitus
> Layout. ;)
> - Jeff
> > - Jeff
> >> this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590859 is a reply to message #39095] Wed, 26 May 2004 17:01 Go to previous message
- Jeff
exquisitus wrote:
> Hi Jeff,
> wrong, any idea?
> exqusitus
>>Layout. ;)
>> - Jeff
>>> - Jeff
>>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590865 is a reply to message #39126] Wed, 26 May 2004 16:59 Go to previous message
Hi Jeff,
you've mentioned.
thanks,
exquisitus
> - Jeff
> exquisitus wrote:
> > Hi Jeff,
> > wrong, any idea?
> > exqusitus
> >>Layout. ;)
> >> - Jeff
> >>> - Jeff
> >>>>this a bug?
Re: VE1.0M1 problems with GridBagLayout [message #590876 is a reply to message #39126] Wed, 26 May 2004 17:17 Go to previous message
- Jeff
> - Jeff
> exquisitus wrote:
>> Hi Jeff,
>> wrong, any idea?
>> exqusitus
Previous Topic:VE1.0M1 problems with GridBagLayout
Next Topic:Creating SWT GUIs
Current Time: Sat Jul 19 06:40:58 EDT 2025
Powered by FUDForum. Page generated in 0.15835 seconds
