[ATL] what formalism to use to represent model transformation ? [message #38586] |
Wed, 16 May 2007 07:59  |
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi All,
I have a question non directly related to ATL: What is the most
appropriate formalism that can be used to represent a model to model
transformation ?
What is your experience with this ? Do you use UML ? and how ???
Sylvain
Sylvain
Re: [ATL] what formalism to use to represent model transformation ? [message #39109 is a reply to message #38674] |
Fri, 18 May 2007 05:25  |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
As Frédéric said, you can use AMW to represent model transformations in a higher
abstraction level. We create different metamodel extensions with the desired structures,
e.g., the mapping between classes and structural features, attributes, etc.
I have some precisions about a couple of use cases:
- the tool interoperability use case
(http://www.eclipse.org/gmt/amw/usecases/interoperability/) has a relatively complex
weaving model that allows to represent several different transformation expressions.
- the metamodel comparison use case (http://www.eclipse.org/gmt/amw/usecases/compare/) has
simple kinds of links (equality between elements of the same type). The advantage is that
the weaving models are created semi-automatically, and then translated into ATL.
- finally, we have created a simple metamodel extension that has structures very close to
the ATL metamodel (called SimpleATL), e.g., rules, input and output elements, and
bindings. You can get more information about it at
http://wiki.eclipse.org/index.php/AMW#Graphical_development_ of_ATL_transformations.
For the time being, we have developed transformations from weaving models into
transformation models. We intend to do the opposite (from ATL to a more abstract
representation) in a near future.
Marcos D. Del Fabro
ps.: I am copying the message to the AMW newsgroup as well.
Frédéric Jouault wrote:
> > transformation ?
> The best complete representation I can think of that would work for any
> ATL transformation is the ATL textual representation (i.e., the .atl file).
> However, several AMW use cases
> (http://www.eclipse.org/gmt/amw/usecases/) show that model weaving is
> quite appropriate to visually represent transformations:
> - completely: when a weaving extension can be used to represent
> everything that needs to be represented,
> or
> - partially: by mapping metamodel classes and structural features, but
> without detailing complex OCL expressions (you can generate the skeleton
> of the transformation), or by encoding them textually in the Properties
> view (which many UML tools do for OCL constraints).
> Regards,
> Frédéric Jouault
FUDForum. Page generated in 0.03451 seconds
