Home » Eclipse Projects » EclipseLink » Unstable database connection causes EL to deadlock
Unstable database connection causes EL to deadlock [message #390288] Tue, 14 July 2009 13:56 Go to next message
I am using a database on a VM over a VPN which is a highly unstable
connection. So it happens the either the VPN breaks down or the VM is
too slow to respond. EL does not seem to handle such situations very
well. Is there a method I could be notified when the connection breaks
down and to re-establish the connection? Maybe its just a timeout that
is very high in the default settings of EL that I could reduce to make
my app more responsive even when the connection breaks down.
I would like to create a job then, that tries to re-establish the
connection.
Phil
Re: Unstable database connection causes EL to deadlock [message #390296 is a reply to message #390288] Thu, 16 July 2009 10:13 Go to previous message
You can use an ExceptionHandler in the EclipseLink Session to handle
connection issues, but EclipseLink should attempt to connect automatically
if the connection is lost (on a database failure you should see
EclipseLink pinging the database, then trying to reconnect). You can also
set a timeout on queries, and your JDBC driver may have other timeout
settings.
But in general, you might need to fix your network issues.
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Previous Topic:Problem with Foreign Composite Key sharing a field with a Primary Composite Key?
Next Topic:Calculations of field values using other tables
Current Time: Sat Jul 19 17:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.14961 seconds
