Home » Eclipse Projects » EclipseLink » Order of persit operations not preserved?
Order of persit operations not preserved? [message #389746] Fri, 26 June 2009 08:38 Go to next message
have two tables:
Parent_table
PK
Child_table
FK (Parent_table)
I tried to do something like this:
parent.setPk("abc");
em.persist(parent);
child.setFk(parent.getPk());
em.persist(child);
When application server started to commit, EclipseLink executes first the
SQL insert for child which breaks due to a foreign key violation. Adding
an explicit call to flush() method fixed this issue:
em.persist(parent);
em.flush();
em.persist(child);
Why doesn't this work without flush?
I'm using Oracle AS 10g, EclipseLink 1.1.1 and Oracle 11 with thin drivers.
Re: Order of persit operations not preserved? [message #389748 is a reply to message #389746] Fri, 26 June 2009 09:35 Go to previous messageGo to next message
EclipseLink performs writes to the database based on constraint
dependencies interpreted from the relational mappings of an Entity. This
aleviates the need for users to managed operation ordering.
In your case, from the sample code, I suspect you have not actually mapped
this relationship but are managing the FKs yourself. In this case
EclipseLink does not have a mapping between these two Entities to
determine operation ordering. I recommend that you use a mapping here and
let EclipseLink manage the foreign keys for you.
If a mapping is not an option you can use a DescriptorCustomizer to add a
constraint dependency (ClassDescriptor.addConstraintDependency) between
the two Entity classes.
Otherwise continue to use the flush() api.
--Gordon
Re: Order of persit operations not preserved? [message #389749 is a reply to message #389748] Fri, 26 June 2009 10:12 Go to previous message
I apologize, I forgot to include mappings to the pseudo code (yes, we had
those). I didn't have access to the source code when I sent the question,
but now I have and here is a more detailed example:
Table1:
@OneToMany(mappedBy = "table1", cascade = CascadeType.ALL)
private List<Table2> list;
Table2
@ManyToOne
@JoinColumn(name = "table1id", referencedColumnName = "table1id")
private Table1 table1;
Previous Topic:Generics and Eclipselink
Next Topic:transaction not commiting
Current Time: Sun Jul 20 18:34:02 EDT 2025
Powered by FUDForum. Page generated in 0.04540 seconds
