Home » Archived » XML Schema Definition (XSD) » Registered resource factory problem
Registered resource factory problem [message #38930] |
Tue, 16 March 2004 10:47  |
I am trying to run the Eclipse XSD parser within Weblogic 8.1 App Server.
I am using XSD 1.1.1 and this version has worked fine in all other
execution environments.
In my code, I register the xsd resource factory with the following code:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "*",
new XSDResourceFactoryImpl());
I use the wildcard '*' since I want all files that go through this parser
to be treated as xsd's to allow for bad file names.
I am getting the following exception when trying to read an xsd which is
called a few lines after the resource factory registry:
java.lang.RuntimeException: Cannot create a resource for
'zip:E:/bea/user_projects/domains/unicorn/myserver/.wlnotdel ete/extract/myserver_unicorn_unicorn/jarfil
es/WEB-INF/lib/xsd.resources36809.jar!/org/eclipse/xsd/plugi n.properties/cache/www.w3.org/2001/XMLSchema-instance.xsd';
a registered resource factory is needed
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:282)
at
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:710)
at
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2039)
at
org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
at
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
at
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
at
org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 88)
at
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
Hayden Marchant
Re: Registered resource factory problem [message #38955 is a reply to message #38930] |
Tue, 16 March 2004 11:30   |
Hayden,
I've never seen a "zip:" protocol before. I've seen "jar:", which is maybe the same? In any event, our URI
implementation has special support for treating "jar:" as a hierarchical URI even though it doesn't conform to the grammar
for a hierarchical URI, i.e., there's no leading "/" after the scheme. This special support is not there for "zip:", so
that will be treated as non-hierarchical and hence it has no file extension that can be used to find a resource factory.
Where did this "zip:" thing come from? Can you use "jar:" instead? You could use the URIConverter to normalize "zip:" to
"jar:"...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Hayden Marchant
Re: Registered resource factory problem [message #39002 is a reply to message #38955] |
Wed, 17 March 2004 06:29   |
I took a different approach to solving this problem by unzipping the
xsd.resources.jar and putting the files in the classpath (and removing the
jar). I now get a different but similar exception. Note that there is a
'directory' called plugin.properties that the code is looking for which
does not exist in the directory hierarchy. Where is this extra
plugin.properties 'directory' coming from?
'file:E:/bea/user_projects/domains/unicorn/applications/unic orn
/WEB-INF/classes/org/eclipse/xsd/plugin.properties/cache/www .w3.org/2001/XMLSchema.xsd';
at
at
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:633)
at
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:708)
Ed Merks wrote:
> Hayden,
> "jar:"...
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Thanks,
> > Hayden Marchant
Re: Registered resource factory problem [message #39026 is a reply to message #39002] |
Wed, 17 March 2004 06:49   |
Hayden,
This is another version of the it's not a hierarchical URI problem. The URI should be file:/E:/..., file://E:/..., or even
file:///E:/..., but file:E:/... is not hierarchical, which is not a good thing. I'm still curious where the "zip:" came
from. Is that something produced by some particular JDK classpath lookup, instead of using "jar:" as I've been seeing?
> at
> at
> at
> Ed Merks wrote:
> > Hayden,
> > "jar:"...
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Thanks,
> > > Hayden Marchant
Re: Registered resource factory problem [message #39053 is a reply to message #39026] |
Thu, 18 March 2004 09:49   |
After some research I have pinned down the problem to one method in
Eclipse. There are 3 methods in XSDSchemaImpl that return XSDSchema
instances that are loaded from the xsd.resources.jar :
getMagicSchemaForSchema(), getSchemaForSchema(), getSchemaInstance(). They
all call XSDPlugin.INSTANCE.getBaseURL().toString(). This method
basically does the following:
1. load plugin.properties resource using class loader.
2. create a URI from it.
3. call segments(1) on it in order to chop of the plugin.properties from
the URI.
4. The returned URI is really a base URI.
Now, when runnning in the Weblogic 8.1, the URL returned in stage 1 is of
the form file:E:/a/b/c instead of file:/E:/a/b/c. therefore, when calling
segments(), since it is NOT hierarchical, does not work and therefore the
baseURL is not at all a baseURL and therefore everything else goes wrong
after that.
I had to put a hack into the 3 methods in XSDSchemaImpl to ensure that the
baseURL is really a baseURL - I removed the offending plugin.properties,
and made the URI hierarchical by adding the '/'.
I'm really not sure why this happens? Does it have anything to do with the
fact that the call to getClass().getResource("plugin.properties") is with
a relative path to plugin.properties and not an absolute path like
"/org/eclipse/xsd/plugin.properties" ?
By the way, this problem happens also when I unzip the xsd.resources.jar
into the classes folder of the WEB-INF of the webapp. i.e. it's not
related to the fact that the resource is jar'ed.
I do not feel comfortable hacking Eclipse libraries, even if it is very
small local change. Can you suggest a better way of analyzing what went
wrong?
Hayden
Ed Merks wrote:
> Hayden,
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Hayden,
maybe
URI
This
extension
> > > "jar:"...
Server.
code:
parser
is
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > Thanks,
> > > > Hayden Marchant
Re: Registered resource factory problem [message #39087 is a reply to message #39053] |
Thu, 18 March 2004 10:42  |
--------------9CC46910E1656C802F139E75
Content-Type: text/plain; charset=us-ascii
Hayden,
All this strange behavior will keep prompting me to ask what JDK you are using. The JDKs I've been using produce
"file:/..." not "file:..." and "jar:" not "zip:". Both the Sun and the IBM JDKs I use produce this:
baseURL=jar:file:/D:/sandbox/unpackage1_3.0M7/eclipse/plugin s/org.eclipse.xsd/runtime/xsd.resources.jar!/org/eclipse/xsd /
Have a look yourself at the different forms that XSDPlugin.INSTANCE.getBaseURL returns for different JDKs. If we can pin
down a pattern of behavior here, we could consider transforming the baseURL in the basic EMFPlugin implementation to
massage the URL it into an acceptable form even if the JDK doesn't yield it in that form originally.
> the URI.
> after that.
> wrong?
> Hayden
> Ed Merks wrote:
> > Hayden,
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Hayden,
> maybe
> URI
> This
> extension
> > > > "jar:"...
> Server.
> code:
> parser
> is
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > Thanks,
> > > > > Hayden Marchant
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Hayden,
<p>All this strange behavior will keep prompting me to ask what JDK you
are using. The JDKs I've been using produce "file:/..." not "file:..."
this:
<blockquote>baseURL=jar:<A HREF=" file:/D:/sandbox/unpackage1_3.0M7/eclipse/plugins/org.eclips e.xsd/runtime/xsd.resources.jar!/org/eclipse/xsd/ "> file:/D:/sandbox/unpackage1_3.0M7/eclipse/plugins/org.eclips e.xsd/runtime/xsd.resources.jar!/org/eclipse/xsd/ </A></blockquote>
returns for different JDKs. If we can pin down a pattern of behavior
implementation to massage the URL it into an acceptable form even if the
<br>
<p>Hayden Marchant wrote:
<blockquote TYPE=CITE>After some research I have pinned down the problem
to one method in
<br>Eclipse. There are 3 methods in XSDSchemaImpl that return XSDSchema
<br>instances that are loaded from the xsd.resources.jar :
<br>getMagicSchemaForSchema(), getSchemaForSchema(), getSchemaInstance().
They
<br>all call XSDPlugin.INSTANCE.getBaseURL().toString(). This method
<br>basically does the following:
<p>1. load plugin.properties resource using class loader.
<br>2. create a URI from it.
<br>3. call segments(1) on it in order to chop of the plugin.properties
from
<br>the URI.
<br>4. The returned URI is really a base URI.
<p>Now, when runnning in the Weblogic 8.1, the URL returned in stage 1
is of
<br>the form <a href="file:E:/a/b/c">file:E:/a/b/c</a> instead of <a href="file:/E:/a/b/c">file:/E:/a/b/c</a>.
<br>segments(), since it is NOT hierarchical, does not work and therefore
the
<br>baseURL is not at all a baseURL and therefore everything else goes
wrong
<br>after that.
<p>I had to put a hack into the 3 methods in XSDSchemaImpl to ensure that
the
<br>baseURL is really a baseURL - I removed the offending plugin.properties,
<br>and made the URI hierarchical by adding the '/'.
<p>I'm really not sure why this happens? Does it have anything to do with
the
<br>fact that the call to getClass().getResource("plugin.properties") is
with
<br>a relative path to plugin.properties and not an absolute path like
<br>"/org/eclipse/xsd/plugin.properties" ?
<p>By the way, this problem happens also when I unzip the xsd.resources.jar
<br>into the classes folder of the WEB-INF of the webapp. i.e. it's not
<br>related to the fact that the resource is jar'ed.
<p>I do not feel comfortable hacking Eclipse libraries, even if it is very
<br>small local change. Can you suggest a better way of analyzing what
went
<br>wrong?
<p>Thanks,
<br>Hayden
<p>Ed Merks wrote:
<p>> Hayden,
<p>> This is another version of the it's not a hierarchical URI problem.
The URI
<br>should be <a href="file:/E:/">file:/E:/</a>..., <a href="file://E:/">file://E:/</a>...,
or even
<br>> <a href="file:///E:/">file:///E:/</a>..., but <a href="file:E:/">file:E:/</a>...
<br>thing. I'm still curious where the "zip:" came
<br>> from. Is that something produced by some particular JDK classpath
lookup,
<br>instead of using "jar:" as I've been seeing?
<p>> Hayden Marchant wrote:
<p>> > I took a different approach to solving this problem by unzipping
the
<br>> > xsd.resources.jar and putting the files in the classpath (and removing
the
<br>> > jar). I now get a different but similar exception. Note that there
is a
<br>> > 'directory' called plugin.properties that the code is looking for
which
<br>> > does not exist in the directory hierarchy. Where is this extra
<br>> > plugin.properties 'directory' coming from?
<br>> >
<br>> > java.lang.RuntimeException: Cannot create a resource for
<br>> > '<a href=" file:E:/bea/user_projects/domains/unicorn/applications/unico rn "> file:E:/bea/user_projects/domains/unicorn/applications/unico rn </a>
<br>> >
<br> /WEB-INF/classes/org/eclipse/xsd/plugin.properties/cache/www .w3.org/2001/XMLSchema.xsd';
<br>> > a registered resource factory is needed
<br>> > at
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:282)
<br>> > at
<br>> >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:633)
<br>> > at
<br>> >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:708)
<br>> >
<br>> > Ed Merks wrote:
<br>> >
<br>> > > Hayden,
<br>> >
<br>> > > I've never seen a "zip:" protocol before. I've seen "jar:",
which is
<br>maybe
<br>> > the same? In any event, our URI
<br>> > > implementation has special support for treating "jar:" as a hierarchical
<br>URI
<br>> > even though it doesn't conform to the grammar
<br>> > > for a hierarchical URI, i.e., there's no leading "/" after the
scheme.
<br>This
<br>> > special support is not there for "zip:", so
<br>> > > that will be treated as non-hierarchical and hence it has no
file
<br>extension
<br>> > that can be used to find a resource factory.
<br>> > > Where did this "zip:" thing come from? Can you use "jar:"
instead? You
<br>> > could use the URIConverter to normalize "zip:" to
<br>> > > "jar:"...
<br>> >
<br>> > > Hayden Marchant wrote:
<br>> >
<br>> > > > I am trying to run the Eclipse XSD parser within Weblogic 8.1
App
<br>Server.
<br>> > > > I am using XSD 1.1.1 and this version has worked fine in all
other
<br>> > > > execution environments.
<br>> > > >
<br>> > > > In my code, I register the xsd resource factory with the following
<br>code:
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>> >
<br> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "*",
<br>> > > >
<br>> > > >
<br>> > > > I use the wildcard '*' since I want all files that go through
this
<br>parser
<br>> > > > to be treated as xsd's to allow for bad file names.
<br>> > > >
<br>> > > > I am getting the following exception when trying to read an
xsd which
<br>is
<br>> > > > called a few lines after the resource factory registry:
<br>> > > >
<br>> > > > java.lang.RuntimeException: Cannot create a resource for
<br>> > > >
<br>> >
<br> 'zip:E:/bea/user_projects/domains/unicorn/myserver/.wlnotdel ete/extract/myserver_unicorn_unicorn/jarfil
<br>> > > >
<br>> >
<br> es/WEB-INF/lib/xsd.resources36809.jar!/org/eclipse/xsd/plugi n.properties/cache/www.w3.org/2001/XMLSchema-instance.xsd';
<br>> > > > a registered resource factory is needed
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:710)
<br>> > > > at
<br>> > > >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2039)
<br>> > > > at
<br>> > > > org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
<br>> > > > at
<br>> > > >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
<br>> > > > at
<br>> > > > org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
<br>> > > > at
<br> org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 88)
<br>> > > > at
<br>> > > > org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
<br>> > > > at
<br>> > > >
<br>> >
<br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
<br>> > > >
<br>> > > > Thanks,
<br>> > > > Hayden Marchant</blockquote>
</html>
--------------9CC46910E1656C802F139E75--
Re: Registered resource factory problem [message #584244 is a reply to message #38930] |
Hayden,
"jar:"...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Hayden Marchant
Re: Registered resource factory problem [message #584257 is a reply to message #38955] |
at
at
at
Ed Merks wrote:
> Hayden,
> "jar:"...
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Thanks,
> > Hayden Marchant
Re: Registered resource factory problem [message #584273 is a reply to message #39002] |
Hayden,
> at
> at
> at
> Ed Merks wrote:
> > Hayden,
> > "jar:"...
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Thanks,
> > > Hayden Marchant
Re: Registered resource factory problem [message #584288 is a reply to message #39026] |
the URI.
after that.
wrong?
Hayden
Ed Merks wrote:
> Hayden,
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Hayden,
maybe
URI
This
extension
> > > "jar:"...
Server.
code:
parser
is
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > Thanks,
> > > > Hayden Marchant
Re: Registered resource factory problem [message #584303 is a reply to message #39053] |
Hayden,
> the URI.
> after that.
> wrong?
> Hayden
> Ed Merks wrote:
> > Hayden,
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Hayden,
> maybe
> URI
> This
> extension
> > > > "jar:"...
> Server.
> code:
> parser
> is
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > Thanks,
> > > > > Hayden Marchant
<html>
Hayden,
this:
<br>
to one method in
They
from
<br>the URI.
is of
the
wrong
<br>after that.
the
the
with
went
<br>wrong?
<p>Thanks,
<br>Hayden
<p>Ed Merks wrote:
<p>> Hayden,
The URI
or even
lookup,
the
the
is a
which
<br>> >
<br>> >
<br>> > at
<br>> >
<br>> > at
<br>> >
<br>> > at
<br>> >
<br>> >
<br>> >
<br>> > > Hayden,
<br>> >
which is
<br>maybe
<br>URI
scheme.
<br>This
file
<br>extension
instead? You
<br>> > > "jar:"...
<br>> >
<br>> >
App
<br>Server.
other
<br>> > > >
<br>code:
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>> >
<br>> > > >
<br>> > > >
this
<br>parser
<br>> > > >
xsd which
<br>is
<br>> > > >
<br>> > > >
<br>> >
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> > > > at
<br>> > > > at
<br>> > > >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > > at
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > > at
<br>> > > >
<br>> >
<br>> > > >
<br>> > > > Thanks,
</html>
Current Time: Sat Jul 19 15:01:44 EDT 2025
Powered by FUDForum. Page generated in 0.05349 seconds
