Home » Archived » Buckminster » Using director to install headless buckminster doesn't work with relative paths
Using director to install headless buckminster doesn't work with relative paths [message #388390] Tue, 28 July 2009 12:03 Go to next message
Hi all,
I'm trying to bootstrap my buckminster builds by using scripts to automate
the installation of a headlesss buckminster.
The first thing I do is install headless buckminster using director and then
I issue "buckminster install..." commands as needed by that product build.
This works file if I give director an absolute path for the install folder
(-d option) . However, if I use a relative path with ".." in it,
buckminster appears to install fine and to the correct folder but when I
later issue "buckminster install.." commands I get the following error.
An error occurred while installing the items
[0]session context was:(profile=Buckminster,
phase=org.eclipse.equinox.internal.
provisional.p2.engine.phases.Install, operand=null --> [R]com.ibm.icu.base
4.0.1
..v20090415,
action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBundleAction).
[0]Error while loading manipulator.
Caused by:
Anyone know if this is a bug or am I doing something silly?
Tas
Re: Using director to install headless buckminster doesn't work with relative paths [message #388392 is a reply to message #388390] Tue, 28 July 2009 15:13 Go to previous messageGo to next message
Hi Tas,
You're not doing anything silly :-). This is a bug in the director application. It should normalize the destination path
that is passed to it but it doesn't.
Thomas Hallgren
Tas Frangoullides wrote:
> Hi all,
> automate the installation of a headlesss buckminster.
> then I issue "buckminster install..." commands as needed by that product
> build.
> folder (-d option) . However, if I use a relative path with ".." in it,
> [R]com.ibm.icu.base 4.0.1
> .v20090415,
> Caused by:
> Tas
Re: Using director to install headless buckminster doesn't work with relative paths [message #388398 is a reply to message #388392] Wed, 29 July 2009 03:30 Go to previous message
I take it that means it's a known bug and I don't need to report it?
OK. I'll try and workaround in my script.. though I can't think how.
Tas
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:4A6F4DCD.8060608@tada.se...
> Hi Tas,
> application. It should normalize the destination path that is passed to it
> but it doesn't.
> Regards,
> Thomas Hallgren
>> Hi all,
>> build.
>> .v20090415,
>> Caused by:
>> Thanks,
>> Tas
Previous Topic:local reader type, scm meta-data and qualifier replacement
Next Topic:Materialized Target Platform is missing Plugins
Current Time: Sun Jul 20 09:50:45 EDT 2025
Powered by FUDForum. Page generated in 0.03822 seconds
