Home » Eclipse Projects » Rich Client Platform (RCP) » combo box in toolbar
combo box in toolbar [message #387071] Wed, 13 October 2004 19:52 Go to next message
Originally posted by: kelly.francke.com
Hi, I need advice on these:
1. I'm trying to add a label + combo box to the main tool bar by extending
the ControlContribution
class. Is this supported?
2. Can I add a label + combo box on the right top corner of the workbench
window (same line as the
toolbar but all the way to the right)?
I will appreciate any infomation. Thanks.
Re: combo box in toolbar [message #387293 is a reply to message #387071] Sat, 16 October 2004 21:47 Go to previous messageGo to next message
Yes this is the right approach. Here is an example:
package customToolbar;
import org.eclipse.jface.action.ContributionItem;
import org.eclipse.jface.action.IAction;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.*;
public class AddressBarContributionItem extends ContributionItem {
protected Combo addressBox;
protected ToolItem item;
protected IAction action;
protected CoolItem coolItem;
public AddressBarContributionItem(IAction action) {
this.action = action;
public void fill(ToolBar parent, int index) {
item = new ToolItem(parent, SWT.SEPARATOR);
Control box = createAddressBox(parent);
item.setControl(box);
item.setWidth(500);
public void fill(CoolBar coolBar, int index) {
// if (coolItem == null && coolBar != null) {
Control box = createAddressBox(coolBar);
int flags = SWT.DROP_DOWN;
if (index >= 0) {
coolItem = new CoolItem(coolBar, flags, index);
} else {
coolItem = new CoolItem(coolBar, flags);
// sets the back reference
coolItem.setData(this);
// Add the toolbar to the CoolItem widget
coolItem.setControl(box);
// If the toolbar item exists then adjust the size of the cool
// item
Point toolBarSize = box.computeSize(SWT.DEFAULT, SWT.DEFAULT);
// Set the preffered size to the size of the toolbar plus trim
coolItem.setMinimumSize(toolBarSize);
coolItem.setPreferredSize(toolBarSize);
coolItem.setSize(toolBarSize);
private Control createAddressBox(Composite parent) {
Composite top = new Composite(parent, SWT.NULL);
GridLayout layout = new GridLayout();
layout.marginHeight = layout.marginWidth = 0;
layout.verticalSpacing = layout.horizontalSpacing = 0;
layout.numColumns = 2;
top.setLayout(layout);
Label l = new Label(top, SWT.NONE);
l.setText("Help:");
addressBox = new Combo(top, SWT.DROP_DOWN);
addressBox.setText("Type a question here");
action.setText("Type a question here");
addressBox.addKeyListener(new KeyAdapter() {
public void keyPressed(KeyEvent e) {
if (e.keyCode == '\r') {
Event event = new Event();
event.data = addressBox.getText();
action.runWithEvent(event);
addressBox.add(addressBox.getText());
addressBox.setLayoutData(new GridData(GridData.FILL,
GridData.BEGINNING, true, false));
return top;
public void fill(Composite parent) {
* Sets the address bar text
public void setText(String text) {
if(addressBox != null)
addressBox.setText(text);
With a bit of hacking but not really supported. First you override
WorkbenchAdvisor.createWindowContents() and build the entire UI
yourself. You can however call helpers to create the canonical coolbar,
menu bar, and status line. Use a CBanner to put two toolbars one beside
the other. Very nasty hacking, but it will work. I've done it but
have not been able to get correct resizing of the right toolbar. Also,
beware that the workbench has many tricky layouts and control wrappers
that you won't get if you build the UI yourself :)
Re: combo box in toolbar [message #387354 is a reply to message #387293] Mon, 18 October 2004 11:54 Go to previous messageGo to next message
Jean-Michel,
Thanks for your answer, I was able to use your code and it saved me some
time. Just a note, I'm using
3.1M2 and had to tweak the code a bit to compile. For example, fill()
methods in ControlContribution
are final (and cannot be overridden).
Also, I was able to position the control all the way to the right by using
the FormLayout/FormData/
FormAttachment classes.
I appreciate your help very much. Thanks.
Re: combo box in toolbar [message #1810388 is a reply to message #387293] Fri, 09 August 2019 05:15 Go to previous message
Hi Friends,
It is really usefull but I have need one help how to use your code into eclipse E4 ?
Any idea please help me.
Previous Topic:[WARNING] Target location type 'Directory' is not supported
Next Topic:Eclipse in Maven Central
Current Time: Sat Jul 19 15:56:01 EDT 2025
Powered by FUDForum. Page generated in 0.12819 seconds
