merge does not copy basic mappings [message #387024] |
Tue, 07 April 2009 10:51  |
Hi !
I have a problem with the merge since 1.1.0.r3634. The merge of the
entityManager seems not to merge primitives attributes like long datatypes.
My source code looks like:
Entity entity = new Entity();
entity.setAId(1000);
Entity mergedEntity = em.merge(en);
Now the aId value of the mergedEntity is null. In the previous 1.0.1
release the primitive attributes were copied.
I looked at the source code of the ObjectBuilder.mergeIntoObject(Object
target, boolean isUnInitialized, Object source, MergeManager mergeManager,
boolean cascadeOnly, boolean isTargetCloneOfOriginal) method, that is part
of the merge logic.
The source code looks a bit strange, because the isTargetCloneOfOriginal
will doesn't take any effect. I think there is a problem in the boolean
logic.
// PERF: Avoid synchronized enumerator as is concurrency bottleneck.
List mappings = this.descriptor.getMappings();
for (int index = 0; index < mappings.size(); index++) {
DatabaseMapping mapping = (DatabaseMapping)mappings.get(index);
if ((!cascadeOnly && !isTargetCloneOfOriginal)
|| (cascadeOnly && mapping.isForeignReferenceMapping())
|| (isTargetCloneOfOriginal && mapping.isCloningRequired())) {
mapping.mergeIntoObject(target, isUnInitialized, source,
mergeManager);
} else if (isTargetCloneOfOriginal && mapping.isCloningRequired()) {
mergeManager);
For me the second "else if" doesn't make sense, because it will never be
reached. The same expression is in the first if statement, so this will be
executed first. Perhaps there was forgotten to negate the
isTargetCloneOfOriginal Boolean in the second if statement ?
Does anyboday agree with that?
FUDForum. Page generated in 0.04126 seconds
