Home » Archived » Buckminster » Headless Build with Subversion
Headless Build with Subversion [message #385767] Fri, 29 May 2009 16:50 Go to next message
Hello - I have recently gone through the following steps to setup a
headless build and I have hit a roadblock with subversion. These are the
steps I executed:
1) Installed the the latest Buckminster Headless from the 3.5 update site.
2) Executed the following command to install the PDE / Java support:
/buckminster install
http://download.eclipse.org/tools/buckminster/headless-3.5/
org.eclipse.buckminster.pde.headless.feature
3) Executed the following command to install the Subversion support:
/buckminster install http://download.cloudsmith.com/buckminster/external
org.eclipse.buckminster.subversive.headless.feature
4) I then attempted to execute a CQuery using the a cquery that functions
properly in the Eclipse GUI.
ERROR [0001] :
org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN
connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available
or install and select pure Java Subversion connector from the plug-in
connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
I have run the listsite on the buckminster executable and this is what I
get:
/buckminster listsite
Features:
org.polarion.eclipse.team.svn.connector.sources (%featureName)
org.eclipse.team.svn.ui.capabilities (%featureName)
org.eclipse.team.svn.nl1.sources (%featureName)
org.eclipse.buckminster.maven.feature (Buckminster - Maven support)
org.eclipse.buckminster.core.headless.feature (Buckminster - Core
Headless)
org.polarion.eclipse.team.svn.connector.svnkit16.sources (%featureName)
org.polarion.eclipse.team.svn.connector.javahl15.win32 (%featureName)
org.eclipse.team.svn.resource.ignore.rules.jdt (%featureName)
org.eclipse.team.svn.source (%featureName)
org.eclipse.buckminster.subclipse.headless.source.feature
org.eclipse.buckminster.cvs.headless.feature (Buckminster - CVS support
for headless operation)
org.polarion.eclipse.team.svn.connector.javahl16.win32 (%featureName)
org.polarion.eclipse.team.svn.connector (%featureName)
org.polarion.eclipse.team.svn.connector.javahl16 (%featureName)
org.eclipse.buckminster.product (Buckminster Product)
org.eclipse.equinox.p2.director.feature (Equinox P2 Director Feature)
org.polarion.eclipse.team.svn.connector.javahl15.sources (%featureName)
org.eclipse.team.svn (%featureName)
org.polarion.eclipse.team.svn.connector.source (%featureName)
org.eclipse.team.svn.mylyn.source (%featureName)
org.eclipse.buckminster.subversive.headless.source.feature
(Buckminster - PDE support for headless operation)
org.polarion.eclipse.team.svn.connector.javahl15 (%featureName)
org.eclipse.buckminster.subclipse.headless.feature
(%featureName)
org.eclipse.team.svn.resource.ignore.rules.jdt.source (%featureName)
org.polarion.eclipse.team.svn.connector.javahl16.sources (%featureName)
org.eclipse.equinox.executable (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit15.sources (%featureName)
org.eclipse.team.svn.nl1 (%featureName)
org.eclipse.team.svn.sources (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit16 (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit15 (%featureName)
Any one have any idea on why this will not work - I am running on Linux
but I do not think that should cause a problem.
Re: Headless Build with Subversion [message #385770 is a reply to message #385767] Fri, 29 May 2009 17:34 Go to previous messageGo to next message
Hi Chase,
You seem to have many more SVN related features then the one you installed in step #3. Please try using *only* our
org.eclipse.buckminster.subversive.headless.feature and nothing else related to SVN.
Kind Regards,
Thomas Hallgren
> the steps I executed:
> functions properly in the Eclipse GUI.
> ERROR [0001] :
> available
> get:
> Features:
> Headless)
> (%featureName)
Re: Headless Build with Subversion [message #385771 is a reply to message #385770] Fri, 29 May 2009 18:43 Go to previous messageGo to next message
Hi Thomas - I switched to Subclipse and that seems to work better but I am
now getting authentication errors when it connects to my SVN repository.
I googled around looking for information on how to set username and
password and so far I have not found anything for a headless subclipse.
Have you been able to do this?
Re: Headless Build with Subversion - Solved Problem [message #385772 is a reply to message #385771] Fri, 29 May 2009 23:46 Go to previous message
Ok - After digging through some bugs etc. I found that the following
-vmargs -Dsvn.user=xxxx -Dsvn.pass=xxxx fixes the problem if you are using
subversive (not in subclipse).
Previous Topic:API Changes in Buckminster
Next Topic:Qualifier Replacement with Local ReaderType
Current Time: Sun Jul 20 18:51:08 EDT 2025
Powered by FUDForum. Page generated in 0.04883 seconds
