Headless Build with Subversion [message #385767] |
Fri, 29 May 2009 16:50  |
Hello - I have recently gone through the following steps to setup a
headless build and I have hit a roadblock with subversion. These are the
steps I executed:
1) Installed the the latest Buckminster Headless from the 3.5 update site.
2) Executed the following command to install the PDE / Java support:
/buckminster install
http://download.eclipse.org/tools/buckminster/headless-3.5/
org.eclipse.buckminster.pde.headless.feature
3) Executed the following command to install the Subversion support:
/buckminster install http://download.cloudsmith.com/buckminster/external
org.eclipse.buckminster.subversive.headless.feature
4) I then attempted to execute a CQuery using the a cquery that functions
properly in the Eclipse GUI.
ERROR [0001] :
org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN
connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available
or install and select pure Java Subversion connector from the plug-in
connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
I have run the listsite on the buckminster executable and this is what I
get:
/buckminster listsite
Features:
org.polarion.eclipse.team.svn.connector.sources (%featureName)
org.eclipse.team.svn.ui.capabilities (%featureName)
org.eclipse.team.svn.nl1.sources (%featureName)
org.eclipse.buckminster.maven.feature (Buckminster - Maven support)
org.eclipse.buckminster.core.headless.feature (Buckminster - Core
Headless)
org.polarion.eclipse.team.svn.connector.svnkit16.sources (%featureName)
org.polarion.eclipse.team.svn.connector.javahl15.win32 (%featureName)
org.eclipse.team.svn.resource.ignore.rules.jdt (%featureName)
org.eclipse.team.svn.source (%featureName)
org.eclipse.buckminster.subclipse.headless.source.feature
org.eclipse.buckminster.cvs.headless.feature (Buckminster - CVS support
for headless operation)
org.polarion.eclipse.team.svn.connector.javahl16.win32 (%featureName)
org.polarion.eclipse.team.svn.connector (%featureName)
org.polarion.eclipse.team.svn.connector.javahl16 (%featureName)
org.eclipse.buckminster.product (Buckminster Product)
org.eclipse.equinox.p2.director.feature (Equinox P2 Director Feature)
org.polarion.eclipse.team.svn.connector.javahl15.sources (%featureName)
org.eclipse.team.svn (%featureName)
org.polarion.eclipse.team.svn.connector.source (%featureName)
org.eclipse.team.svn.mylyn.source (%featureName)
org.eclipse.buckminster.subversive.headless.source.feature
(Buckminster - PDE support for headless operation)
org.polarion.eclipse.team.svn.connector.javahl15 (%featureName)
org.eclipse.buckminster.subclipse.headless.feature
(%featureName)
org.eclipse.team.svn.resource.ignore.rules.jdt.source (%featureName)
org.polarion.eclipse.team.svn.connector.javahl16.sources (%featureName)
org.eclipse.equinox.executable (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit15.sources (%featureName)
org.eclipse.team.svn.nl1 (%featureName)
org.eclipse.team.svn.sources (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit16 (%featureName)
org.polarion.eclipse.team.svn.connector.svnkit15 (%featureName)
Any one have any idea on why this will not work - I am running on Linux
but I do not think that should cause a problem.
FUDForum. Page generated in 0.04843 seconds
