Prevent p2 materializer from contacting other sites [message #385517] |
Wed, 27 May 2009 09:34  |
We have a local mirror of the Ganymede update site behind our firewall. The
mirror is built using p2's site mirroring capabilities. I use the
eclipse.import reader with an http://... URL. Unfortunately, file:/...
access is not possible, but still, intranet http access should be an
improvement over http access to ecipse.org.
I then used the p2 materializer to fetch some features from this mirror. My
first attempts led to Buckminster hanging indefinitely (both headless and
regular IDE installation). After a while I found out that it tried to
download something from www.eclipse.org. I must assume that this is due to
the p2 materializer, because the old targetPlatform materializer worked
fine.
Setting a proxy solved my problem, of course. But I wonder if there is a way
to prevent the p2 materializer from contacting other sites? This is not only
for performance reasons. If external sources are taken into account, can I
really be sure that Buckminster fetches only the things provided on our
local mirror?
Achim
Re: Prevent p2 materializer from contacting other sites [message #385518 is a reply to message #385517] |
Thu, 28 May 2009 01:46  |
a good night's sleep and some more digging in the p2 documentation revealed
the following:
1) Setting the system property eclipse.p2.mirrors to false will completely
prevent any automatic mirror selection.
2) Providing a policy.xml file on our mirror update site gives more fine-
grained control over mirror selection.
See http://wiki.eclipse.org/Using_Policy_Files
Sorry for the noise.
Achim
Achim Demelt wrote:
> The mirror is built using p2's site mirroring capabilities. I use the
> My first attempts led to Buckminster hanging indefinitely (both headless
> and regular IDE installation). After a while I found out that it tried to
> fine.
> way to prevent the p2 materializer from contacting other sites? This is
> not only for performance reasons. If external sources are taken into
> account, can I really be sure that Buckminster fetches only the things
> provided on our local mirror?
> Cheers,
> Achim
FUDForum. Page generated in 0.06315 seconds
