Home » Archived » Buckminster » bundles expanding upon materialization
bundles expanding upon materialization [message #385378] Mon, 18 May 2009 07:29 Go to next message
How do I tell the 'eclipse.import' reader or the 'filesystem' materializer
reader to NOT unpack/unjar the downloaded bundles. E.g. bundles downloaded
via the 'url' or 'maven' readers (some materializer) are not expanded.
Thanks & Regards
Alex
Re: bundles expanding upon materialization [message #385380 is a reply to message #385378] Mon, 18 May 2009 08:42 Go to previous messageGo to next message
Hi Alex,
The import reader will unpack bundles that needs to be unpacked in order to function. There's
currently no way of turning that off. However, most bundles will not need to be unpacked.
What problems do you see with this approach?
- thomas
Alex Chatziparaskewas wrote:
> Hi
> materializer reader to NOT unpack/unjar the downloaded bundles. E.g.
> bundles downloaded via the 'url' or 'maven' readers (some materializer)
> are not expanded.
> Thanks & Regards
> Alex
Re: bundles expanding upon materialization [message #385381 is a reply to message #385380] Mon, 18 May 2009 10:34 Go to previous messageGo to next message
Most of our bundles are read using the eclipse.import reader. There is no
'real' problem, just that in the end the target platform will be checked
into SVN (just too big to be downloaded everytime by every build - and not
the only target platform). The ability of putting in the jars into SVN
would just be a performance benefit when accessing SVN (no one is
interested in hundreds of 'unpacked' bundles).
Anyhow, it does not really matter, would just have been nice.
Thanks & Regards
Alex
Thomas Hallgren wrote:
> Hi Alex,
function. There's
be unpacked.
> - thomas
>> Hi
>> are not expanded.
>> Thanks & Regards
>> Alex
Re: bundles expanding upon materialization [message #385470 is a reply to message #385380] Tue, 19 May 2009 08:20 Go to previous messageGo to next message
Hi Thomas
Actually I now ran into a problem with the eclipse.import reader expanding
the bundles. The problem is that the version information is not retained
as part of the expand process. I.e. I have a dependency for
commons.logging versions 1.0.4 and 1.1.1. The commons.logging bundle is
expanded into a directory org.apache.commons.logging and not something
like 'org.apache.commons.logging_1.0.4/1.1.1'.
Alex
> Hi Alex,
function. There's
be unpacked.
> - thomas
>> Hi
>> are not expanded.
>> Thanks & Regards
>> Alex
Re: bundles expanding upon materialization [message #385472 is a reply to message #385470] Tue, 19 May 2009 08:33 Go to previous messageGo to next message
That sounds very odd. What is the name of the unexpanded jar file? And why is org.apache.commons.logging expanded? It
shouldn't need to be since it doesn't contain nested jars and such.
- thomas
> Hi Thomas
> expanding the bundles. The problem is that the version information is
> not retained as part of the expand process. I.e. I have a dependency for
> Regards
> Alex
>> Hi Alex,
>> order to
> function. There's
>> need to
> be unpacked.
>> - thomas
>>> Hi
>>> Thanks & Regards
>>> Alex
Re: bundles expanding upon materialization [message #385474 is a reply to message #385472] Tue, 19 May 2009 09:29 Go to previous messageGo to next message
It is simply org.apache.commons.logging from the ORBIT website
( http://download.eclipse.org/tools/orbit/downloads/drops/I200 90504052954/)
searchPath looks like this (3rd provider is for ORBIT):
<searchPath name="3rd.party">
<provider readerType="local"
componentTypes="osgi.bundle,eclipse.feature,buckminster" mutable="true"
source="true">
<uri format="file:///Q:/target-platforms/components/{0}">
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
source="true">
<uri format="file:///${CC_LIBS_HOME}/3rd-party2/{0}_{1}">
<bc:replace pattern=".*([0-9]+\.[0-9]+\.[0-9]+).*"
replacement="$1">
<bc:propertyRef key="buckminster.version.designator" />
</bc:replace>
</uri>
</provider>
<provider readerType="eclipse.import" componentTypes="osgi.bundle"
mutable="false" source="false">
<uri
format=" http://download.eclipse.org/tools/orbit/downloads/drops/I200 90504052954/updateSite"/>
</provider>
<provider xsi:type="mp:MavenProvider" readerType="maven2"
componentTypes="maven,osgi.bundle" mutable="false" source="false">
<uri format="http://repo1.maven.org/maven2"/>
<mp:mappings>
<mp:entry name="jcl.over.slf4j" groupId="org.slf4j"
artifactId="jcl-over-slf4j"/>
<mp:entry name="jul.to.slf4j" groupId="org.slf4j"
artifactId="jul-to-slf4j"/>
<mp:entry name="org.apache.activemq.core"
groupId="org.apache.activemq" artifactId="activemq-core"/>
<mp:entry name="slf4j.api" groupId="org.slf4j"
artifactId="slf4j-api"/>
<mp:entry name="slf4j.log4j12" groupId="org.slf4j"
artifactId="slf4j-log4j12"/>
</mp:mappings>
</provider>
</searchPath>
> - thomas
>> Hi Thomas
>> Regards
>> Alex
>>> Hi Alex,
>>> order to
>> function. There's
>>> need to
>> be unpacked.
>>> - thomas
>>>> Hi
>>>> Thanks & Regards
>>>> Alex
Re: bundles expanding upon materialization [message #385475 is a reply to message #385474] Tue, 19 May 2009 10:13 Go to previous messageGo to next message
I think we talk about different things when we say 'expand'. The org.apache.commons.logging jar file is not expanded.
When the bundle is 'imported' a project is created that contains the jar file of the bundle. That project is named after
the component ID. That results in a collision when you import several versions.
There is a current limitation in Buckminster that will prevent you from importing several bundles with the same name
since the mspec node selection is based to name and component type only. In order to fix this you would either need to
differentiate on version or include the version in a bindingPatternReplacement. Neither is possible right now I'm afraid.
A solution to your problem could be to define a target platform that contains the bundles instead of importing them into
your workspace.
- thomas
> source="true">
> </uri>
> </provider>
> source="true">
> replacement="$1">
> </bc:replace>
> </uri>
> </provider>
> componentTypes="osgi.bundle" mutable="false" source="false">
> <uri
> </provider>
> <mp:mappings>
> </mp:mappings>
> </provider>
> </searchPath>
>> why
>> - thomas
>>> Hi Thomas
>>> for commons.logging versions 1.0.4 and 1.1.1. The commons.logging
>>> bundle is expanded into a directory org.apache.commons.logging and
>>> not something like 'org.apache.commons.logging_1.0.4/1.1.1'.
>>> Regards
>>> Alex
>>>> Hi Alex,
>>>> order to
>>> function. There's
>>>> need to
>>> be unpacked.
>>>> - thomas
>>>>> Hi
>>>>> E.g. bundles downloaded via the 'url' or 'maven' readers (some
>>>>> Thanks & Regards
>>>>> Alex
Re: bundles expanding upon materialization [message #385479 is a reply to message #385475] Wed, 20 May 2009 01:41 Go to previous messageGo to next message
Hi Thomas
Ok, now I understand. So let me slightly rephrase my questions then: What
is then the proposed way of materializing a binary plugin for a target
platform from a download site like
http://download.eclipse.org/eclipse/updates/3.4? Would I need to convert
all 'eclipse.import' reader usages to 'url' readers?
Thanks & Regards
Alex
versions.
> your workspace.
> - thomas
>> source="true">
>> </uri>
>> </provider>
>> source="true">
>> <bc:replace pattern=".*([0-9]+.[0-9]+.[0-9]+).*"
>> replacement="$1">
>> </bc:replace>
>> </uri>
>> </provider>
>> <uri
>> </provider>
>> <mp:mappings>
>> </mp:mappings>
>> </provider>
>> </searchPath>
>>> why
>>> - thomas
>>>> Hi Thomas
>>>> Regards
>>>> Alex
>>>>> Hi Alex,
>>>>> order to
>>>> function. There's
>>>>> need to
>>>> be unpacked.
>>>>> - thomas
>>>>>> Hi
>>>>>> Thanks & Regards
>>>>>> Alex
Re: bundles expanding upon materialization [message #385480 is a reply to message #385479] Wed, 20 May 2009 02:18 Go to previous message
> Hi Thomas
> What is then the proposed way of materializing a binary plugin for a
> target platform from a download site like
No, you keep the 'eclipse.import' but you use an MSPEC to declare that some components should end up in your target
platform rather then in the workspace.
Alternatively, if your target platform is fairly static and you don't want to set it up for each build, you can create
such a platform once and for all in your IDE and then appoint it from Buckminster using the command "setpref
targetPlatformPath=/path/to/your/TP"
Thomas Hallgren
> Thanks & Regards
> Alex
> versions.
>> only. In
>> your workspace.
>> - thomas
>>> mutable="true" source="true">
>>> </uri>
>>> </provider>
>>> replacement="$1">
>>> <bc:propertyRef
>>> </bc:replace>
>>> </uri>
>>> </provider>
>>> <uri
>>> </provider>
>>> <mp:mappings>
>>> </mp:mappings>
>>> </provider>
>>> </searchPath>
>>>> And why
>>>> - thomas
>>>>> Hi Thomas
>>>>> is not retained as part of the expand process. I.e. I have a
>>>>> dependency for commons.logging versions 1.0.4 and 1.1.1. The
>>>>> commons.logging bundle is expanded into a directory
>>>>> org.apache.commons.logging and not something like
>>>>> Regards
>>>>> Alex
>>>>>> Hi Alex,
>>>>>> order to
>>>>> function. There's
>>>>>> not need to
>>>>> be unpacked.
>>>>>> - thomas
>>>>>>> Hi
>>>>>>> Thanks & Regards
>>>>>>> Alex
Previous Topic:Bug in eclipse.build for headless Buckminster 3.4-10097
Next Topic:troubles with headless importtarget/importtargetdefintiion
Current Time: Sat Jul 19 08:42:09 EDT 2025
Powered by FUDForum. Page generated in 0.08841 seconds
