Home » Eclipse Projects » EclipseLink » Mapping inherited id attribute
Mapping inherited id attribute [message #385404] Tue, 27 January 2009 19:00 Go to next message
Dear fellow members,
I would like to inherit an id attribute from a mapped superclass using a
Table sequence generator. However, I would like the column names and the
sequence names to be different for the subclasses. I found this question
asked here:
http://dev.eclipse.org/newslists/news.eclipse.rt.eclipselink /msg00180.html,
but I could not figure it out. If a DescriptorCustomizer is the way to do
this, could you provide an example? I cannot find anything explicit in
the documentation.
David
Re: Mapping inherited id attribute [message #385408 is a reply to message #385404] Wed, 28 January 2009 08:51 Go to previous message
JPA does not allow you to override a generator in a subclass.
To use a DescriptorCustomizer it would do something like:
public class MyCustomizer implements DescriptorCustomizer {
public void customize(ClassDescriptor descriptor) {
descriptor.setSequenceName("SUB_SEQ");
Where SUB_SEQ was another sequence generator that you defined.
For a list of ClassDescriptor API see,
<a
href=" http://wiki.eclipse.org/Configuring_a_Relational_Descriptor_ (ELUG)#How_to_Configure_Sequencing_at_the_Descriptor_Level_U sing_Java ">User
Guide</a>
James
http://www.nabble.com/EclipseLink---Users-f26658.html
Previous Topic:Caching or Isolations-Level Problem?
Next Topic:JDK 1.4?
Current Time: Sun Jul 20 07:11:50 EDT 2025
Powered by FUDForum. Page generated in 0.03377 seconds
