Home » Archived » Buckminster » Error parsing site stream
Error parsing site stream [message #384851] Fri, 17 April 2009 04:55 Go to next message
I'm trying to resolve features using a "site.feature" reader pointing to a
p2 site that I built with Buckminster. This yields the following error:
[buckminster resolve] ERROR [0002] : No suitable provider for component
de.exxcellent.orchideo.util.ui.feature:site.feature/[1.1.0,2 .0.0)#OSGi was
found in searchPath common
[buckminster resolve] ERROR [0002] : Rejecting provider
site.feature( http://svn.exxcellent.de/projects/orchideo/common/test/ademe lt/site):
No component match was found
[buckminster resolve] ERROR Unable to obtain site from:
[buckminster resolve] ERROR Unable to access
" http://svn.exxcellent.de/projects/orchideo/common/test/ademe lt/site".
[buckminster resolve] ERROR Error parsing site stream. [White
spaces are required between publicId and systemId.]
The site itself seems to be valid. The p2 UI can update from this site
without problems. Any ideas?
Achim
Re: Error parsing site stream [message #384853 is a reply to message #384851] Fri, 17 April 2009 05:02 Go to previous messageGo to next message
Achim Demelt wrote:
Please try the 'eclipse.import' reader type instead. I think it will do a better job.
- thomas
Re: Error parsing site stream [message #384856 is a reply to message #384853] Fri, 17 April 2009 05:13 Go to previous messageGo to next message
Thomas,
The eclipse.import reader yields this:
found in resourceMap
http://svn.exxcellent.de/projects/orchideo/common/test/ademe lt/buckminster/rmaps/common.binary.rmap
eclipse.import( http://svn.exxcellent.de/projects/orchideo/common/test/ademe lt/site):
Achim
> Achim Demelt wrote:
>> Hi,
>> a p2 site that I built with Buckminster. This yields the following error:
>> [component
>> was found in searchPath common
> better job.
> - thomas
Re: Error parsing site stream [message #384857 is a reply to message #384856] Fri, 17 April 2009 05:51 Go to previous messageGo to next message
Do you run with -logLevel DEBUG? If not, please try. It should generate some exception stack traces that might be helpful.
- thomas
Achim Demelt wrote:
> Thomas,
> Regards,
> Achim
>> Achim Demelt wrote:
>>> Hi,
>>> [component
>> better job.
>> - thomas
Re: Error parsing site stream [message #384859 is a reply to message #384857] Fri, 17 April 2009 06:00 Go to previous messageGo to next message
Yes, I tried -logLevel DEBUG. This produces tons of other resolution
messages, but no stacktrace indicating what goes wrong. Only the same error
message. I can send you a ZIP of the site for analysis, if you wish.
Achim
> - thomas
> Achim Demelt wrote:
>> Thomas,
>> was found in resourceMap
>> [component
>> Regards,
>> Achim
>>> Achim Demelt wrote:
>>>> Hi,
>>>> to a p2 site that I built with Buckminster. This yields the following
>>>> error:
>>>> [component
>>>> [[White
>>>> [[White
>>> a better job.
>>> - thomas
Re: Error parsing site stream [message #384862 is a reply to message #384859] Fri, 17 April 2009 09:00 Go to previous message
Okay, I'm one step further. When switching to the eclipse.import reader, I
also have to change the componentTypes from "site.feature" to
"eclipse.feature,osgi.bundle". It seems that my features can now be found.
Now I have different problems because the transitive feature dependencies
are resolved differently between "site.feature" and "eclipse.feature". We
have a (classic, non-P2) mirror site with several external dependencies.
What used to work with the site.feature resolver now fails with the
eclipse.feature resolver. Some features are only present in the features/
directory, but not declared in the site.xml file. So I'll have to fix the
mirror site first...
Achim
> error message. I can send you a ZIP of the site for analysis, if you wish.
> Regards,
> Achim
>> - thomas
>> Achim Demelt wrote:
>>> Thomas,
>>> [component
>>> [component
>>> Regards,
>>> Achim
>>>> Achim Demelt wrote:
>>>>> Hi,
>>>>> error:
>>>>> [component
>>>>> [[White
>>>>> [[White
>>>> a better job.
>>>> - thomas
Previous Topic:Source bundle and roots
Next Topic:How to materialize target platform
Current Time: Sat Jul 19 15:52:31 EDT 2025
Powered by FUDForum. Page generated in 0.04813 seconds
