Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] - Eugenia - Generate GMF tool, graph and map model
[Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384815] Thu, 21 August 2008 06:35 Go to next message
Originally posted by: sami.yenice.forte.com.tr
An error occures, If i wanted to generet "gmf tool, graph and map model"
Screencast is here : http://screencast.com/t/onUmz74z
Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384817 is a reply to message #384815] Thu, 21 August 2008 07:19 Go to previous messageGo to next message
Hi Sami,
Could you please send me your Emfatic file (.emf) to see what is wrong?
Dimitrios
> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384818 is a reply to message #384817] Thu, 21 August 2008 07:26 Go to previous messageGo to next message
Hi Dimitrios,
My .emf file is the same as your example. I am trying to make your
example. (filesystem)
@namespace(uri="filesystem", prefix="filesystem")
@gmf
package filesystem;
@gmf.diagram
class Filesystem {
val Drive[*] drives;
val Sync[*] syncs;
class Drive extends Folder {
class Folder extends File {
@gmf.compartment
val File[*] contents;
class Shortcut extends File {
@gmf.link(target.decoration="arrow", style="dash")
ref File target;
@gmf.link(label="lastSync", source="source",
target="target", style="dot", width="2")
class Sync {
ref File source;
ref File target;
attr String lastSync;
@gmf.node(label = "name")
class File {
attr String name;
Thanks for your reply.
Dimitrios Kolovos yazmış:
> Hi Sami,
> Cheers,
> Dimitrios
>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384819 is a reply to message #384818] Thu, 21 August 2008 07:37 Go to previous messageGo to next message
Hi Sami,
I've just noticed you are using an outdated version of Epsilon (1.3.6).
The current version is 0.8 (we had to drop the version number below 1.0
to conform with the Eclipse process). The new update site (since 0.8) is
http://download.eclipse.org/technology/gmt/epsilon/updates/
Could you please try with the latest version and let me know if it works?
If that fails too, could you please check out the source of Epsilon from
the CVS (instructions are provided in
http://www.eclipse.org/gmt/epsilon/doc/EpsilonCVS.pdf) so that you have
the latest version?
Dimitrios
Sami wrote:
> Hi Dimitrios,
> @gmf
> package filesystem;
> @gmf.diagram
> class Filesystem {
> val Sync[*] syncs;
> @gmf.compartment
> ref File target;
> class Sync {
> ref File source;
> ref File target;
> class File {
> attr String name;
>> Hi Sami,
>> Cheers,
>> Dimitrios
>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384821 is a reply to message #384819] Thu, 21 August 2008 09:07 Go to previous messageGo to next message
I dropped the version number below 1.0 and I tried new versions. But it
fails too. I am using "eclipse-modeling-ganymede-incubation-win32". I
will try eclipse 3.3
> Hi Sami,
> the latest version?
> Cheers,
> Dimitrios
> Sami wrote:
>> Hi Dimitrios,
>> @gmf
>> package filesystem;
>> @gmf.diagram
>> class Filesystem {
>> val Sync[*] syncs;
>> @gmf.compartment
>> ref File target;
>> class Sync {
>> ref File source;
>> ref File target;
>> class File {
>> attr String name;
>>> Hi Sami,
>>> Cheers,
>>> Dimitrios
>>>> model"
>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384822 is a reply to message #384821] Thu, 21 August 2008 09:09 Go to previous messageGo to next message
Hi Sami,
There is no need to try 3.3. I have 3.4 in my pc and it works fine. If
0.8 fails could you please try with the CVS source code?
Dimitrios
>> Hi Sami,
>> (1.3.6). The current version is 0.8 (we had to drop the version number
>> below 1.0 to conform with the Eclipse process). The new update site
>> (since 0.8) is
>> from the CVS (instructions are provided in
>> have the latest version?
>> Cheers,
>> Dimitrios
>> Sami wrote:
>>> Hi Dimitrios,
>>> @gmf
>>> package filesystem;
>>> @gmf.diagram
>>> class Filesystem {
>>> val Sync[*] syncs;
>>> @gmf.compartment
>>> ref File target;
>>> class Sync {
>>> ref File source;
>>> ref File target;
>>> class File {
>>> attr String name;
>>>> Hi Sami,
>>>> Cheers,
>>>> Dimitrios
>>>>> model"
>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384823 is a reply to message #384822] Thu, 21 August 2008 09:33 Go to previous messageGo to next message
Hi Sami,
I've investigated a bit more and it seems that it also works with the
0.8.0 binaries from the update site.
Dimitrios
Dimitrios Kolovos wrote:
> Hi Sami,
> Cheers,
> Dimitrios
>> it fails too. I am using "eclipse-modeling-ganymede-incubation-win32".
>> I will try eclipse 3.3
>>> Hi Sami,
>>> number below 1.0 to conform with the Eclipse process). The new update
>>> site (since 0.8) is
>>> works?
>>> Cheers,
>>> Dimitrios
>>> Sami wrote:
>>>> Hi Dimitrios,
>>>> @gmf
>>>> package filesystem;
>>>> @gmf.diagram
>>>> class Filesystem {
>>>> val Sync[*] syncs;
>>>> @gmf.compartment
>>>> ref File target;
>>>> class Sync {
>>>> ref File source;
>>>> ref File target;
>>>> class File {
>>>> attr String name;
>>>>> Hi Sami,
>>>>> wrong?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> model"
>>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384824 is a reply to message #384822] Thu, 21 August 2008 09:49 Go to previous messageGo to next message
With the CVS source code works fine. Thanks but what is the difference?
If I export these plugins as a jar, does it work?
Thanks Kolovos, I think Eugenia is useful and profitable project for gmf
graphing.
> Hi Sami,
> Cheers,
> Dimitrios
>>> Hi Sami,
>>> site (since 0.8) is
>>> works?
>>> Cheers,
>>> Dimitrios
>>> Sami wrote:
>>>> Hi Dimitrios,
>>>> @gmf
>>>> package filesystem;
>>>> @gmf.diagram
>>>> class Filesystem {
>>>> val Sync[*] syncs;
>>>> @gmf.compartment
>>>> ref File target;
>>>> class Sync {
>>>> ref File source;
>>>> ref File target;
>>>> class File {
>>>> attr String name;
>>>>> Hi Sami,
>>>>> wrong?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> model"
>>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #384825 is a reply to message #384824] Thu, 21 August 2008 09:55 Go to previous message
Hi Sami,
Thanks for your encouragement :)
I'm not quite sure what the problem is... I installed Epsilon from the
update site on a clean 3.4 modeling copy, checked out EuGENia from the
SVN and it worked.
In any case, to build the binaries of the current version of the source
code, go to the org.eclipse.epsilon.updatesite project, delete all files
under /plugins and /features (if any), open the site.xml and select
"Build all".
Dimitrios
> graphing.
>> Hi Sami,
>> Cheers,
>> Dimitrios
>>> "eclipse-modeling-ganymede-incubation-win32". I will try eclipse 3.3
>>>> Hi Sami,
>>>> works?
>>>> Cheers,
>>>> Dimitrios
>>>> Sami wrote:
>>>>> Hi Dimitrios,
>>>>> @gmf
>>>>> package filesystem;
>>>>> @gmf.diagram
>>>>> class Filesystem {
>>>>> val Sync[*] syncs;
>>>>> @gmf.compartment
>>>>> ref File target;
>>>>> class Sync {
>>>>> ref File source;
>>>>> ref File target;
>>>>> class File {
>>>>> attr String name;
>>>>>> Hi Sami,
>>>>>> wrong?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> model"
>>>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619933 is a reply to message #384815] Thu, 21 August 2008 07:19 Go to previous message
Hi Sami,
Dimitrios
> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619936 is a reply to message #384817] Thu, 21 August 2008 07:26 Go to previous message
Hi Dimitrios,
@gmf
package filesystem;
@gmf.diagram
class Filesystem {
val Sync[*] syncs;
@gmf.compartment
ref File target;
class Sync {
ref File source;
ref File target;
class File {
attr String name;
> Hi Sami,
> Cheers,
> Dimitrios
>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619938 is a reply to message #384818] Thu, 21 August 2008 07:37 Go to previous message
Hi Sami,
the latest version?
Dimitrios
Sami wrote:
> Hi Dimitrios,
> @gmf
> package filesystem;
> @gmf.diagram
> class Filesystem {
> val Sync[*] syncs;
> @gmf.compartment
> ref File target;
> class Sync {
> ref File source;
> ref File target;
> class File {
> attr String name;
>> Hi Sami,
>> Cheers,
>> Dimitrios
>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619942 is a reply to message #384819] Thu, 21 August 2008 09:07 Go to previous message
> Hi Sami,
> the latest version?
> Cheers,
> Dimitrios
> Sami wrote:
>> Hi Dimitrios,
>> @gmf
>> package filesystem;
>> @gmf.diagram
>> class Filesystem {
>> val Sync[*] syncs;
>> @gmf.compartment
>> ref File target;
>> class Sync {
>> ref File source;
>> ref File target;
>> class File {
>> attr String name;
>>> Hi Sami,
>>> Cheers,
>>> Dimitrios
>>>> model"
>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619945 is a reply to message #384821] Thu, 21 August 2008 09:09 Go to previous message
Hi Sami,
Dimitrios
>> Hi Sami,
>> (since 0.8) is
>> Cheers,
>> Dimitrios
>> Sami wrote:
>>> Hi Dimitrios,
>>> @gmf
>>> package filesystem;
>>> @gmf.diagram
>>> class Filesystem {
>>> val Sync[*] syncs;
>>> @gmf.compartment
>>> ref File target;
>>> class Sync {
>>> ref File source;
>>> ref File target;
>>> class File {
>>> attr String name;
>>>> Hi Sami,
>>>> Cheers,
>>>> Dimitrios
>>>>> model"
>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619946 is a reply to message #384822] Thu, 21 August 2008 09:33 Go to previous message
Hi Sami,
Dimitrios
> Hi Sami,
> Cheers,
> Dimitrios
>>> Hi Sami,
>>> site (since 0.8) is
>>> works?
>>> Cheers,
>>> Dimitrios
>>> Sami wrote:
>>>> Hi Dimitrios,
>>>> @gmf
>>>> package filesystem;
>>>> @gmf.diagram
>>>> class Filesystem {
>>>> val Sync[*] syncs;
>>>> @gmf.compartment
>>>> ref File target;
>>>> class Sync {
>>>> ref File source;
>>>> ref File target;
>>>> class File {
>>>> attr String name;
>>>>> Hi Sami,
>>>>> wrong?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> model"
>>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619949 is a reply to message #384822] Thu, 21 August 2008 09:49 Go to previous message
graphing.
> Hi Sami,
> Cheers,
> Dimitrios
>>> Hi Sami,
>>> site (since 0.8) is
>>> works?
>>> Cheers,
>>> Dimitrios
>>> Sami wrote:
>>>> Hi Dimitrios,
>>>> @gmf
>>>> package filesystem;
>>>> @gmf.diagram
>>>> class Filesystem {
>>>> val Sync[*] syncs;
>>>> @gmf.compartment
>>>> ref File target;
>>>> class Sync {
>>>> ref File source;
>>>> ref File target;
>>>> class File {
>>>> attr String name;
>>>>> Hi Sami,
>>>>> wrong?
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> model"
>>>>>> Thanks.
Re: [Epsilon] - Eugenia - Generate GMF tool, graph and map model [message #619951 is a reply to message #384824] Thu, 21 August 2008 09:55 Go to previous message
Hi Sami,
SVN and it worked.
"Build all".
Dimitrios
> graphing.
>> Hi Sami,
>> Cheers,
>> Dimitrios
>>>> Hi Sami,
>>>> works?
>>>> Cheers,
>>>> Dimitrios
>>>> Sami wrote:
>>>>> Hi Dimitrios,
>>>>> @gmf
>>>>> package filesystem;
>>>>> @gmf.diagram
>>>>> class Filesystem {
>>>>> val Sync[*] syncs;
>>>>> @gmf.compartment
>>>>> ref File target;
>>>>> class Sync {
>>>>> ref File source;
>>>>> ref File target;
>>>>> class File {
>>>>> attr String name;
>>>>>> Hi Sami,
>>>>>> wrong?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> model"
>>>>>>> Thanks.
Previous Topic:[AM3] Wrinting UML models with ANT plugin
Next Topic:[MOFScript] Getting Started
Current Time: Sat Jul 19 12:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.05960 seconds
